Results 1 to 10 of 27
08-17-2010, 08:44 PM #1Member
- Join Date
- Apr 2009
- Posts
- 38
- Location
- Upstate NY
Building SS Quick attach latch "HELP WANTED"
Trying to understand how the latch assembly works, copying the bobcat style. I don't know how to build it or how the spring keeps force on the latch pin. Any help or pictures would be great. I see lots of people making this style of latch.
08-17-2010, 10:16 PM #2New Member
- Join Date
- Oct 2009
- Posts
- 1
Re: Building SS Quick attach latch "HELP WANTED"
Try this thread...
http://www.tractorbynet.com/forums/b...qa-kubota.html
09-11-2010, 09:55 PM #3Member
- Join Date
- Apr 2009
- Posts
- 38
- Location
- Upstate NY
I was finally able to complete the quick attach for the bucket which I retro fitted and forks I built, THANK YOU Tractobynet and all others who I copied from. Now I hope it all holds together this was the first real project I welded of any value. I'll post a few pictures and maybe it might help someone else down the road. Forks came from ATV express with slide plates
09-11-2010, 10:17 PM #4Member
- Join Date
- Apr 2009
- Posts
- 38
- Location
- Upstate NY
This was the part I had a hard time sorting out, and planing kinda hard just looking at pictures and figuring out dimentions.
09-11-2010, 10:25 PM #5Member
- Join Date
- Apr 2009
- Posts
- 38
- Location
- Upstate NY
Some pictures of bucket, cut off tractor mounts I wanted to mount everything as close as possible, to save bucket power, it's a small tractor. The bucket mount plates where cut from a mount plate from ATV express, I thought I needed to start to shave some weight parts are starting to get heavy as pieced it together.
09-11-2010, 10:38 PM #6Member
- Join Date
- Apr 2009
- Posts
- 38
- Location
- Upstate NY
Making the fork frame so many differant variations to get ideas from
09-11-2010, 10:52 PM #7
Nice workmanship!
Realist "It is a half glass of water"
11-22-2010, 12:33 PM #8Member
- Join Date
- Apr 2009
- Posts
- 48
I am planning on doing the same thing to my bucket, I was looking at the JD style on locking it, they just use a dowel thru the bracket and then a pin. what do you think of that style?
11-22-2010, 06:50 PM #9Gold Member
- Join Date
- Jun 2005
- Posts
- 409
- Location
- Southeast Missouri
- Tractor
- Kubota L3410
Looks really good, let us know how it all works for you. Should hold up nice, and you will really like having it. I have found that it has been one of the best additions to my tractor.
If your going to be a Bear, Be a Grizzly!
11-25-2010, 11:06 PM #10
KTM010: In Post # 5, the last picture shows one side of the bucket side of the Q/A. Can I make one suggestion? I would run a piece of 1" strip, or angle iron vertically on the inside, similar to the way it is on the outside. I did a conversion on my tractor & bucket 3 years ago & just ran into a problem with the bracket on my bucket. The very top weld where the q/a first meets & curls into the bracket started to pull apart. I repaired the weld & reinforced both sides with a piece of angle iron on mine. Just a head's up.. It can be a weak spot.. Now to beef up the one on my snowplow.. I'm gonna need more orange paint!
2006 Kubota L3400DT
LA463 FEL with Q/A.
Woods BH80X BH W/Thumb
Bradco Pallet forks
6' KK Landscape Rake
Husqvarna 365 & 455
Wallenstein FX65 Skidding Winch
2001 Yamaha Wolverine
1 hungry wood boiler
Similar Threads
B7100 Quick Attach
By charlz in forum Build-It YourselfReplies: 28Last Post: 02-05-2010, 09:34 AM -
new B3030 Quick Attach Question
By Friver in forum Kubota Buying/PricingReplies: 18Last Post: 02-16-2007, 07:38 PM -
FEL bucket conversion to a Quick Attach???
By Bob_Skurka in forum New Holland Owning/OperatingReplies: 8Last Post: 09-27-2004, 02:29 PM -
ATI "pin type" Quick Attach for NH, Kutota, Case?
By Bob_Skurka in forum New Holland Owning/OperatingReplies: 7Last Post: 07-04-2004, 06:00 PM -
quick attach bucket
By Anonymous Poster in forum Kubota Owning/OperatingReplies: 2Last Post: 12-04-2000, 09:29 AM
