Results 1 to 7 of 7
  1. #1
    Join Date
    Feb 2007
    Posts
    68
    N. California
    Kubota BX1500, BX2230
    Default Low budget home built ring roller
    I've long wanted a ring roller but could never find a decent small one used, and new ones are really pricey. My local kubota dealer happened to mention, "Some guys just get some 10" pipe, buy the rings and make their own." I did and am really pleased with the result.
    I use this for compacting after sowing cover crop seed in my orchard (this next time with my newly built seed drill) . Ring rollers are also great for following a disc to break up clods, or after tilling to compact overly fluffed up seed beds. I used an old home made tongue from a solid roller I'd made from a length of corrugated culvert pipe years ago. It had plain steel "donuts" for bearings. I only use it about 2 hrs. a year so wear is not a problem, I just give each bushing a shot of grease before each use. For heavier duty use it could easily be made with flanged ball bearings. The 26 rings cost me $13.00 each, so the whole project cost under $350.00
    Some construction details:
    - The core is 10" steel pipe which is 10 1/2" OD (got it for free from a friend). This matches what I've measured on commercial ring rollers. The ID of the rings is 11 3/4", so individual rings are able to float over clods or bumps without lifting all the others off the ground.
    - The rings are 2 3/8" wide, and I made the overall length of the pipe to be 2" longer than the total width of all rings (again copied from commercial rollers). This allows the rings to flop around freely and better deal with uneven surfaces.
    - The end plates are 1/4" steel. The left end is welded to the pipe, but I bolted on the right end plate (to a 3" channel cross piece welded in the end of the pipe). I did this thinking I might want to add weight inside the pipe. Another approach would be to weld both ends on tight and add a pipe plug in one end to add water for weight. Or another would be to add the weight to the tongue frame. For my purposes I haven't needed more weight.
    - The axle shaft is 1" steel rod. Each end plate has a 1" shaft collar welded to it, with a set bolt to lock to the axle.
    Attached Thumbnails Attached Thumbnails Low budget home built ring roller-roller1-jpg   Low budget home built ring roller-roller2-jpg   Low budget home built ring roller-roller3-jpg
  2. #2
    Super Member schmism's Avatar
    Join Date
    Jul 2006
    Posts
    5,113
    Peoria IL
    New holland TC(33)
    Default Re: Low budget home built ring roller
    i bet that sucker is noisy
    hows it work?
    Steve - TC33D 4x4 FEL, dual rear remotes with toys
  3. #3
    Join Date
    Feb 2007
    Posts
    68
    N. California
    Yes, very noisy! Works great for compacting and breaking up small clods after a harrow. Leaves a nice dimpled surface ready to soak up rain.
  4. #4
    Platinum Member CBW1999's Avatar
    Join Date
    May 2008
    Posts
    857
    Northern Vermont on the 45th parallel
    Kubota 7510, Toro Groundsmaster 217D
    Nice job!
    Gives me some ideas for a winter project. Although a lengthy project list.....
  5. #5
    Super Star Member Thomas's Avatar
    Join Date
    Apr 2000
    Posts
    17,334
    Lebanon,NH.
    Kubota L2800HST w/Frontloader & CC LTX1046 & Craftman T2200 lawn mower.
    Won't want to be mole/shrew..yikes.
    About how much does it weigh?
  6. #6
    Join Date
    Feb 2007
    Posts
    68
    N. California
    Quote Originally Posted by Thomas View Post
    Weight is around 690 lbs. It's 5 1/2ft. wide, and the 10" pipe weights 40.5lb./ft. The rings are 16# ea. The frame & tongue are much lighter weight than on commercial units, but works fine for my use.
  7. #7
    Join Date
    Apr 2000
    Posts
    17,334
    Lebanon,NH.
    SLT.
    Thanks for info.
Similar Threads
  1. My home built no-till seed drill
    By spurlocktool in forum Build-It Yourself
    Last Post: 07-22-2017, 06:27 PM
  2. Low Budget Bucket Position Indicator
    By Rockyridge in forum Kubota Owning/Operating
    Last Post: 10-15-2007, 08:35 AM
  3. Freinds home built machinery
    By Taylortractornut in forum Build-It Yourself
    Last Post: 03-14-2004, 12:03 AM
  4. Doublewide. How bad are they?
    By B7500 in forum Rural Living
    Last Post: 08-26-2003, 01:03 PM
  5. Home Depot
    By BrokerBob in forum John Deere Buying/Pricing
    Last Post: 07-12-2002, 09:09 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
