Page 1 of 7 1234 ... LastLast
Results 1 to 10 of 61
  1. #1
    Platinum Member Army grunt's Avatar
    Join Date
    Dec 2009
    Posts
    775
    Georga
    TC 30 Newholland
    Default cable operated dump trailer
    I am using a 12 volt winch to rase my dump trailer. Thought i would share.
    Army Grunt
    Attached Thumbnails Attached Thumbnails cable operated dump trailer-img_3219.jpg   cable operated dump trailer-img_3220.jpg
    "Be who you are, say what you will, those that matter wont mind, those that mind don't matter".
  2. #2
    Elite Member Dmace's Avatar
    Join Date
    Oct 2005
    Posts
    3,838
    Wakefield, NH
    Kioti CK20 HST
    Default Re: cable operated dump trailer
    Interesting, the frame looks good so far. I'm curious how your going to get the cable to lift the dump. Are you going to mount the winch high or have a single pulley mounted high with the winch line running over it...?
    Derek
    Kioti CK20HST
    KL120 FEL // KB2365 BH // 60" JRW 3ph snowblower // 48" HD Boxblade
    Sims-Cab Depot heated cab
    Quote Originally Posted by DiamondPilot
    Now it's time for Ford and GM to step up
  3. #3
    Super Member RobS's Avatar
    Join Date
    Jun 2000
    Posts
    6,212
    SW Michigan
    John Deere 790
    Or have the winch on the tongue and pull forward on the hoist linkage?
    Rob
    John Deere 790, 70 FEL, 7 BH, 513 cutter and other fun stuff
  4. #4
    Join Date
    Jun 2010
    Posts
    96
    Oliver 1655
    In the first picture you can see the cable hooked thru and eye so my guess would be he will have a bar sticking up with a pulley on top.
    Since you plan to use a winch, why did you add a scissor hinge? Is it for stability or to allow for hydraulics in the future?
  5. #5
    Join Date
    Jan 2004
    Posts
    198
    I wonder if the cable will be attached or run through the center post of the scissors hinge, that would make it lift if the winch was mounted on the tongue, pending the angle used.
  6. #6
    Super Member Iplayfarmer's Avatar
    Join Date
    Jul 2005
    Posts
    5,151
    Idaho
    Massey Ferguson 1215, Toro 266-H, Pennsylvania Panzer, Case 444, Craftsman 14/6
    Quote Originally Posted by Army grunt View Post
    Army Grunt
    I LOVE your hinges. That's my kind of design creativity.
    The trailer looks well engineered. I too am eager to hear your reasoning for the scissor mechanism in the middle. It looks like you made provisions for future improvements with that bracket on the side too.
    Please keep us all posted on your progress. This looks like it will be a good build.
    From now on I will only buy cars that are a silver/grey color. Then I can make all body repairs with Duct Tape.
  7. #7
    Join Date
    Dec 2009
    Posts
    775
    Georga
    TC 30 Newholland
    The scissor hinge was for a hydrolick set up from a old Tommie lift, it was really bad a didn't have enough through. so i am going to pull from the center pin with the winch. i am building a gang(3 to 2) block an tackle to accept 14" cable I am using 3" pulleys for this. Today I plan on sawing up a oak log for the trailer floor an sides.A friend is working on the tailgate trip.Time is a factor I leave to go to long island to get a "Veterans Service Dog" in a week or so.So Ill be stopping again.Its very close to taking over to his shop an sandblasting it.Ill more as time goes on,Tks. for the interest.
    Army Grunt
  8. #8
    Veteran Member easygo's Avatar
    Join Date
    Mar 2007
    Posts
    1,374
    Eddington, Maine
    Kubota B7800
    I LIKE IT !!! Looks like you cut apart something else to make the trailer and that earns you a brownie point in my book.
    Just an idea. You might want to add some sort of a stop to the scissor mechanism so you would not pull it too far and over to the other side. That could result in a trailer bed come crashing down onto the frame. I would guess that it will be a slow lift with the 3 to 2 block and tackle but still it does not hurt to be careful.
    It's the going that counts, not the distance!!!
  9. #9
    Join Date
    Dec 2009
    Posts
    775
    Georga
    TC 30 Newholland
    easygo
    Almost everything is "recycled" on the trailer.
    yes a stop is planned, all i was going to do is put a short length of chain to stop any over pull.tks for input
    Army Grunt
  10. #10
    Join Date
    Dec 2009
    Posts
    775
    Georga
    TC 30 Newholland
    I sawed a clear red oak log up into the planking I plan on using for the floor an sides of my dump tr.
    Army Grunt
    Attached Thumbnails Attached Thumbnails cable operated dump trailer-img_3235.jpg
Similar Threads
  1. Taking delivery on 7x12, 14k lb dump trailer
    By jinman in forum Trailers & Transportation
    Last Post: 01-19-2010, 08:03 AM
  2. Small dump trailer re-build
    By SkunkWerX in forum Build-It Yourself
    Last Post: 07-15-2008, 06:58 AM
  3. Overloaded dump trailer
    By scesnick in forum Trailers & Transportation
    Last Post: 05-19-2007, 12:07 PM
  4. dump trailer
    By avclay in forum Trailers & Transportation
    Last Post: 06-08-2004, 12:29 PM
  5. B7500 & Single axle trailer
    By BILLMAN in forum Trailers & Transportation
    Last Post: 11-09-2001, 05:01 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
