Page 1 of 2 12 LastLast
Results 1 to 10 of 13
  1. #1
    New Member
    Join Date
    Oct 2010
    Posts
    8
    Default garden tractor into lever steer??
    i was wondering if anyone has built a mini dozer out of a garden tractor.. if so what kind of brake system could i use for steering??
  2. #2
    Super Star Member
    Join Date
    Aug 2001
    Posts
    14,028
    Upper Midwest USA
    JD_4x2_Gator, JD_4300, JD_X485, JD_425, JD_455, JD_110
    Default Re: garden tractor into lever steer??
    Need a few more details of the design first.
  3. #3
    Super Member Mace Canute's Avatar
    Join Date
    Nov 2006
    Posts
    6,621
    Saskatoon, Saskatchewan
    The easiest ones to convert would be the ones with individual wheel brakes from the factory. Even though you wouldn't have a locked differential, tracks tend to want to drive straight ahead and only a little correcting would be necessary.
    Of all the mini crawlers I have seen, the most impressive one is this one. IH Cub Cadet 100 Crawler Saying the builder is talented is doing him an injustice!
    The neat thing is, there is such a large selection of units to re-do, some are very neat indeed!
    There's these Youtube vids:
    YouTube - Custom built Massey Ferguson 10 crawler
    YouTube - Mini Bulldozer
    YouTube - little crawler
    YouTube - mini dozer
    YouTube - Mini Trattore TSR 130 Taglio ulivi
    YouTube - John Deere Custom Built Track Vehicle
    YouTube - Custom Built John Deere 317 Crawler
    YouTube - bulldozer 2
    YouTube - John Deere 314 modifier
  4. #4
    Platinum Member Craig Clayton's Avatar
    Join Date
    May 2009
    Posts
    863
    Uxbridge Ontario Canada
    L2250 Kubota
    Sir
    What is the make and origin of the green crawler, it is very nicely restored.
    Craig Clayton
  5. #5
    New Member
    Join Date
    Oct 2010
    Posts
    8
    well i think it would be simple but it probably not.. take a regular sears garden tractor with a three speed with reverse transmission with high and low, and make or put some car or truck brakes on each side of the axle and then run a brake line from each side to a couple of master cyliders and then my levers. but im goin to make my own tracks. jus wondering if that setup would work?
  6. #6
    Join Date
    Nov 2006
    Posts
    6,621
    Quote Originally Posted by Craig Clayton View Post
    Sir
    Craig Clayton
    Nertz! I can't find it again! It was originally posted on Antique Engines Antique Tractors Steam Engines and Old Iron That was a tracked walk behind unit originally that a clever fellow converted to a ride-on unit. There was another picture along with that one and the guy had his feet tucked back under the seat resting on a crossbar he added. His toes were roughly above the rear idlers.
  7. #7
    Join Date
    Jan 2009
    Posts
    140
    South Central, PA
    Kioti DK 45SE, 993 Pasquali
    Another option that I have seen, but is more invovled is to lock the rearend so both axles would drive all the time. Then put some sort of hand operated clutch before the final drive to the tracks. I have seen this on some larger conversion and even some older dozers from the factory. Also would probably have to include some sort of brake that would apply with the clutch releasing.
    Like I said a little more invovled, but something else that could work.
  8. #8
    Join Date
    Nov 2006
    Posts
    6,621
    Quote Originally Posted by ben2o1o View Post
    That's why I said "The easiest ones to convert would be the ones with individual wheel brakes from the factory." They have done the hard part for you. Adding backing plates or caliper mounts to an axle that was never designed for them would be difficult, especially if the rear axle was aluminum or cast iron.
  9. #9
    New Member
    Join Date
    Oct 2010
    Posts
    8
    ive welded the gears togather on a lawnmower transmission awhile back to make posi. and then put a pulley on each side of the axle shaft and put two independant axles that had a pulley on each and jus put two seperate idler pulleys to tighten the belts but my project didnt move.. i dont know if it was the belts or the rear pulleys too small?
  10. #10
    Join Date
    Mar 2009
    Posts
    81
    Vermont
    Cub Cadet 1512
    I built one but didn't use the rear end of the tractor. I used a z turn pump/control unit along with hydrualic motors. I posted the full build in an earlier thread. Let me know if you have more questions.
    Good Luck.
    Attached Thumbnails Attached Thumbnails garden tractor into lever steer??-100_2402-jpg
Similar Threads
  1. Garden rebuild
    By Wooddust in forum General Lawn & Garden
    Last Post: 08-28-2010, 07:44 PM
  2. 2010 Garden Peek-tures
    By jinman in forum Photos
    Last Post: 07-18-2010, 08:45 AM
  3. This ain't no Garden of Eden
    By jinman in forum Rural Living
    Last Post: 11-03-2009, 10:17 AM
  4. MF 135 PTO lever broke Help!
    By BobReeves in forum Massey Ferguson Classic/Vintage
    Last Post: 07-14-2004, 06:33 AM
  5. BX 2200 Hydraulic control lever
    By tbennett in forum Kubota Owning/Operating
    Last Post: 08-07-2003, 03:26 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
