Page 1 of 2 12 LastLast
Results 1 to 10 of 14
  1. #1
    Super Star Member LD1's Avatar
    Join Date
    Apr 2008
    Posts
    18,262
    Central Ohio
    Kubota MX5100
    Default What is this electric motor for???
    Not really sure where to post this but.........
    I aquired this electric motor out of an old "farm" bar of a buddys.
    I assume it must go to some peice of shop equipment like a drill press or????????
    It has no nameplate on it. It is a gear reduction motor. And with two wires as far as I can tell it is 120v. At least I know it runs ut I give it 120v.
    Just wondering if anyone has any idea what it might be for?? It's not very big. Shaft is about 1" diameter and is physically about the size of an aternator.
    Attached Thumbnails Attached Thumbnails What is this electric motor for???-oct20_0001-jpg   What is this electric motor for???-oct20_0002-jpg   What is this electric motor for???-oct20_0003-jpg
    ".........there is only one way to find out."
    "Ok, hold my beer and watch this.........."
    MX5100 DIY Remotes
    MX5100 Diverter install
    Front Snow Plow Install
    Ford 5500 Backhoe
    Kubota MX5100HST w/LA844
    2005 Dodge 3500 4x4 Diesel
    8N Rebuilt and restored
    Bushhog 306
    3 Homemade wood hauling trailers
    Dolmar 6400 84cc ported
    Sachs-Dolmar 120SI Ported
    (4) Sachs-Dolmar 116SI Ported
    Dolmar PS540
    Sachs-Dolmar 115i
    Sachs-Dolmar 117
    Sachs-Dolmar 112
  2. #2
    Super Star Member
    Join Date
    Feb 2008
    Posts
    12,465
    somewhere usa
    Deere 110tlb, 4520, x749, L130
    Default Re: What is this electric motor for???
    Just guessing but it appears to be lowspeed gear motor about 6:1 reduction looking at the housing. Might be a motor for an old conveyor.
  3. #3
    Elite Member
    Join Date
    Sep 2007
    Posts
    3,430
    Doniphan, Mo.
    Kubota L4240, B7800 & BX2660
    Looks more like it came out of a washing machine.
  4. #4
    Platinum Member Craig Clayton's Avatar
    Join Date
    May 2009
    Posts
    863
    Uxbridge Ontario Canada
    L2250 Kubota
    All proper motors have a nameplate . By the size of the lead wires I think it is for the lower voltages 12,24 36 VDC. If it has a commutator then it is DC or a universal that runs on AC.( I.E. your electric drill runs on AC and has brushes.)
    Craig Clayton
  5. #5
    Veteran Member Treemonkey1000's Avatar
    Join Date
    Jan 2008
    Posts
    1,894
    Renton, Washington
    Kubota L3750
    Windshield wiper motor? On closer inspection it is too big for a windshielf wiper not with a fan and shaft that big. I think washing machine would be about right.
    1st Peter 1:6-9
  6. #6
    Join Date
    Apr 2008
    Posts
    18,262
    Central Ohio
    Kubota MX5100
    I will say that I dont think it is from any household appliances. It is a very noisy motor. Has a whinning sound. It sounds almost exactally like running an electric drill. just a little louder. Noisier than any washing machine I have seen.
    MX5100 DIY Remotes
    Ford 5500 Backhoe
    Bushhog 306
    Dolmar PS540
    Sachs-Dolmar 115i
    Sachs-Dolmar 117
    Sachs-Dolmar 112
  7. #7
    Join Date
    Jul 2004
    Posts
    1,986
    Bancroft, Ontario
    JD4300
    By running it with an ammeter you can get an idea of what it will do. What is the final speed of the output shaft? Is it a series motor? Looks like it may be handy to use for something....
  8. #8
    Join Date
    Apr 2008
    Posts
    18,262
    Central Ohio
    Kubota MX5100
    Quote Originally Posted by pat32rf View Post
    That is what I am contemplating myself. Either that or jsut selling it. But it would help to know what it is off of.
    I'll go out to the garage now and see if I can gather any more info, like RPM and amps and such.
    MX5100 DIY Remotes
    Ford 5500 Backhoe
    Bushhog 306
    Dolmar PS540
    Sachs-Dolmar 115i
    Sachs-Dolmar 117
    Sachs-Dolmar 112
  9. #9
    Elite Member
    Join Date
    Sep 2007
    Posts
    3,430
    Doniphan, Mo.
    Quote Originally Posted by LD1 View Post
    If it isn't new, that might be why it's not in the machine. If new it's still a guessing game.
  10. #10
    Join Date
    Apr 2008
    Posts
    18,262
    Central Ohio
    Kubota MX5100
    Quote Originally Posted by Leejohn View Post
    It's not new. Don't know if it has ever been used, but it is definatally not new.
    With no load, it pulls 7 amps @ 120v. So that's about a 1 HP motor.
    It has a 4.5/1 reduction that reverses the direction of the shaft. (looking at the shaft, the motor spins CW and the shaft CCW)
    The shaft is 7/8" and 2.5" long with two .150" by 5/8 woodruf keys.
    It has two brushes in the back (opposite the output shaft) that are 180 degrees appart. You can see where they are in some of the pics. There is actually vent holes over the part that the brushes contact. (sorry it's been too long ang I forgot all the termonoligy. Stator, commutator, rotor?????)
    As to how it's wound??? Not sure either without brushing up on electric motors again. But the ohms between the two wires is nil. Only about 1-2 ohms if that helps.
    MX5100 DIY Remotes
    Ford 5500 Backhoe
    Bushhog 306
    Dolmar PS540
    Sachs-Dolmar 115i
    Sachs-Dolmar 117
    Sachs-Dolmar 112
Similar Threads
  1. Full-size electric wood splitter
    By EdK in forum Build-It Yourself
    Last Post: 04-06-2010, 08:47 PM
  2. Electric cylinder instead of hydraulic HELP!!!
    By deere_x475guy in forum Build-It Yourself
    Last Post: 06-19-2007, 12:12 PM
  3. massey electric front PTO smoked
    By tractorshawn in forum Parts/Repairs
    Last Post: 05-17-2007, 08:49 PM
  4. Electric controller for TCC/Top & Tilt?
    By Gary_in_Indiana in forum Attachments
    Last Post: 10-02-2004, 08:49 AM
  5. Electric gate question
    By Billc in forum Rural Living
    Last Post: 01-10-2001, 07:50 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
