Page 1 of 4 1234 LastLast
Results 1 to 10 of 39
  1. #1
    Veteran Member chad22's Avatar
    Join Date
    Nov 2010
    Posts
    1,621
    Kansas
    Sears Garden Tractor
    Default My homemade backhoe made from a riding mower
    This isn't finished quite yet. But I thought I would show some pics of my backhoe. I still have to get the cylinders and some hoses. But I basically got everything welded up.
    As well as put in some bigger bolts. I just got some small ones in there to hold the thing up.
    I also need to make a connector for the cylinder to attach to the bucket.
    I'll post more pictures as well as a video of it in action when it's finished.
    Chad
    Attached Thumbnails Attached Thumbnails My homemade backhoe made from a riding mower-tnimg_0035-jpg   My homemade backhoe made from a riding mower-tnimg_0036-jpg   My homemade backhoe made from a riding mower-tnimg_0037-jpg   My homemade backhoe made from a riding mower-tnimg_0038-jpg
  2. #2
    Platinum Member Qapla's Avatar
    Join Date
    Sep 2008
    Posts
    953
    Gator Country
    New Holland TC40D HST 4WD FEL/BH
    Default Re: My homemade backhoe made from a riding mower
    Might want some rear stabilizer feet on there to keep it from flipping over backward when you hit some hard dirt. (unless I just couldn't see them)
    New Holland Workmaster 45 2WD Gear
    Massey Ferguson 240
    NewHolland 16LA FEL
    Woods BH 70-X Sub-frame Backhoe
    Troybuilt Super Bronco w/42" mower
    Husqvarna DRT 900 Tiller
    Ariens 6.5 HP String Mower
    Husqvarna HU625WT String Mower
    3 point hitch attachments:
    single plow, double plow, 5' & 6' deck mower, tiller, 2 cultivators, planter, fertilizer spreader, disk set, sprayer, and a few homemade attachments
    30 acres, 15 acres, 5 acres
  3. #3
    Join Date
    Nov 2010
    Posts
    1,621
    Kansas
    Quote Originally Posted by Qapla View Post
    I'll add some stabilizers to it soon. That's something I don't want " for it To flip over".
    I'm planning on doing manual stabilizers and then later make some hydraulic ones. I'm also now thinking of adding a front bucket to it. A friend of mine has a loader bucket that I might buy from him and rig it on the front.
    Also was gonna buy a hydraulic tank, and a friend brought one over and gave it to me.
  4. #4
    Gold Member HiTechTed's Avatar
    Join Date
    Aug 2010
    Posts
    296
    Indiana
    Kubota L3400
    I'm wondering what you are going to run the hydraulics with? How are you going to set all that up?
  5. #5
    Join Date
    Sep 2008
    Posts
    850
    Central, AR
    Did you strengthen the mower framer?
  6. #6
    Join Date
    Nov 2010
    Posts
    1,621
    Kansas
    Quote Originally Posted by HiTechTed View Post
    I'm gonna mount the hydraulic pump on the frame of the mower and run the pump off the deck pulley. So the v-twin motor that runs the mower will be running the hydraulic pump.
    I don't have the deck to the mower anymore so I won't be mowing with it. So I figure the deck pulley will be perfect.
    I'm gonna mount the hydraulic fluid tank on the front so that way they'll be some extra weight on the front.
    Quote Originally Posted by BruceWard View Post
    I haven't done that yet. But I was thinking about it.
  7. #7
    Join Date
    Jul 2010
    Posts
    1,627
    Central Coast of CA
    Massey Ferguson 1010
    Interesting build. Have thought of something like this before, myself. Keep us updated.
  8. #8
    Join Date
    Mar 2002
    Posts
    576
    Jackson County, Michigan
    Bolens HT-20
    Neat way to escape jamming the foot on the shovel and the back break from the lifting! I like it!!
  9. #9
    Join Date
    Sep 2008
    Posts
    850
    Central, AR
    Quote Originally Posted by chad22 View Post
    Impressive work so far!
    I think that you could end up with a pretzel if you do not strengthen the frame. Especially if you put a bucket on the front.
    You might consider installing four stabilisers, two at the front and two at the back. I would give them sharp feet. The backhoe will be pulling against the stabilisers. When the front of the bucket pushes into the soil it places stress on the front axle or front bucket. When you pull the bucket out with the spoils it places stress on the rear axle or stabilisers. Pulling the bucket forward will likely drag the mower backward, sharp feet on the stabilisers may help hold it in place.
  10. #10
    Gold Member kday64's Avatar
    Join Date
    Nov 2010
    Posts
    350
    South Eastern Connecticut
    Kubota BX2360
    Hi all,
    I am thinking that the bucket might need some teeth, to help you dig through that tough top soil. You might want to weld some CAT 6/7? washers on either side of the bolts to prevent shearing the square tubing from the force the hydralics.
    ~Kevin
    Kubota BX2360, 54" Fine Cut MMM, LA243 FEL, BX2789 Rear Snow Thrower
Similar Threads
  1. tym 433 with FEL, Backhoe, Cab, Mower and post hole digger
    By AustinTX in forum TYM Buying/Pricing
    Last Post: 02-18-2010, 03:45 PM
  2. Backhoe Can I leave the backhoe on with a M-M mower?
    By Dick Calland in forum Kubota Owning/Operating
    Last Post: 05-12-2009, 09:06 PM
  3. Backhoe 2615 Backhoe with mid mower
    By gp1200x in forum Mahindra Owning/Operating
    Last Post: 04-02-2008, 02:16 AM
  4. John Deere JX75 Push Mower Performance Analysis
    By rancar in forum John Deere Lawn & Garden
    Last Post: 06-16-2003, 08:54 PM
  5. Backhoe Backhoe Installation vs. Belly Mower Operation
    By glennmac in forum Attachments
    Last Post: 11-17-2000, 10:39 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
