Results 1 to 6 of 6
  1. #1
    New Member dsails380's Avatar
    Join Date
    Oct 2010
    Posts
    21
    Pennsylvania
    MF GC2410
    Default Multi-Purpose Ballast
    Rather than use the backhoe on my GC2410 for ballast, I built a ballast box for use with the FEL and quick hitch snow blower. What's unique about this is I can move each of the 100lb cement blocks to my aerator and back as needed. I drilled a hole and drove a length of rebar through each block and welded a flat washer to the bottom and a lifting eye to the top. I can now use a chain attached to the FEL to easily move the blocks back an forth instead of wrestling them by hand. The ballast box give me a smaller footprint allowing me to get into tighter spots if needed. I'm thinking the total ballast box weight is about 600 lb.
    Attached Thumbnails Attached Thumbnails Multi-Purpose Ballast-ballast-box-jpg   Multi-Purpose Ballast-ballast-box-2-jpg   Multi-Purpose Ballast-ballast-box-3-jpg
  2. #2
    Bronze Member danktx's Avatar
    Join Date
    Aug 2009
    Posts
    54
    Hunt County, TX
    Kubota L3940
    Default Re: Multi-Purpose Ballast
    Nice build! I really like the casters for moving it when off the tractor. The ability to use the weights on multiple attachments shows some good planning took place too...
    DanK
  3. #3
    Super Member texasjohn's Avatar
    Join Date
    Oct 2005
    Posts
    6,048
    Central Texas, Jarrell
    Kubota Grand L5030HSTC
    Good job!
    Joy is having the tools you need and needing the tools you have!
    Kubota 5030 HSTC, BB, Danueser PHD, LA853 QA HD FEL w JD toothbar, 3pt chisel, 3 pt disk, 6' shredder, Kubota FEL hay spike, 3pt hay fork w carryall, Kubota RTV 1140
  4. #4
    Super Star Member Thomas's Avatar
    Join Date
    Apr 2000
    Posts
    16,733
    Lebanon,NH.
    Kubota L2800HST w/Frontloader & CC LTX1046 & Craftman T2200 lawn mower.
    Easy to hitch and store..nice job.
  5. #5
    Veteran Member chad22's Avatar
    Join Date
    Nov 2010
    Posts
    1,621
    Kansas
    Sears Garden Tractor
    Great work. I might make something similar but on a smaller scale for my mini backhoe.
    Chad
  6. #6
    Join Date
    Oct 2010
    Posts
    21
    Pennsylvania
    MF GC2410
    Thanks guys. The casters are 5" that I picked up at harbor freight and work fine unless you need to change direction. There's no ball bearings in the swivel, so I have to jack it up and rotate the casters by hand. Kind of a PITA, so I'll be replacing them, but for now, it works.
    I used Tractor Supply M-F red with the enamel hardener to paint this thing and so far seems to be pretty durable. I bought a cheep spray gun from harbor freight ($20) and was able to get a nice gloss. At the same time, I also sprayed a '84 snapper mower. It sure looks a lot better now. Next summer I think I'll paint the chipper and roller.
    Dave
Similar Threads
  1. Recommended Ballast for 3320 with 300CX?
    By Neophyte in forum John Deere Owning/Operating
    Last Post: 07-30-2006, 08:53 AM
  2. Ballast Surprising ballast reqs for 400X/CX FEL on 4x20s!
    By bam747 in forum John Deere Owning/Operating
    Last Post: 04-21-2006, 06:38 PM
  3. Front Ballast Question
    By Lykele in forum Attachments
    Last Post: 06-09-2003, 02:42 PM
  4. Ballast Frame & weights for FEL ballast
    By Curt in forum Owning/Operating
    Last Post: 09-16-2002, 03:03 PM
  5. Grading B7500 ballast box or rear blade
    By texblonigan in forum Kubota Owning/Operating
    Last Post: 03-23-2002, 09:21 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
