HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > General Forums > Build-It Yourself
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 04-04-2003, 01:08 PM   #31 (permalink)
Default Re: Portable Sawmill
here are some photo's.
scottbrrtt72 is offline   Reply With Quote
Old 04-09-2003, 09:45 AM   #32 (permalink)
no picture scott....
gmason is offline   Reply With Quote
Old 04-09-2003, 12:56 PM   #33 (permalink)
My picture files are larger than 100k.
Old 04-09-2003, 02:16 PM   #34 (permalink)
Here is the frame of the saw mill. Finally got the pictures re-sized.
Old 04-09-2003, 02:17 PM   #35 (permalink)
Here is another one.
Old 04-10-2003, 09:45 AM   #36 (permalink)
Very nice, did you start with the trailer part then proceed to the saw or is this just the first of many pictures?
How did you square the trailer up, some carefull welding/tacking?
What's that axile rated for?
thanks
gary
Old 04-10-2003, 12:19 PM   #37 (permalink)
Yes, since this was my first big welding project I started with the frame first. I purchased all the steel cut to specific size. It was more expensive but I didn’t have any thing to cut the steel at that time. I basically tack welded all the sections on and with a t-square and level checked it. The length is 16’ and is supported by the four tube steel columns I have at each end. This holds the weight of the logs. I usually lift the frame off the ground a few inches and level it before I start milling. I’m not sure what the axle supports since it only supports the sawmill frame. It was a left over axle my father had. I will post some photos of the saw. I built a chain saw mill thinking a band saw mill would be too difficult. After completing it I realized the band saw mill wouldn’t be that bad. That is my next project. I will send some more photos.
Old 04-11-2003, 10:32 AM   #38 (permalink)
Scott, I'd be happy to send you some detail pictures of mine with idea's to improve the setup. I started out just the opposite from you, I built the cutting head first and now slowly getting the track system created. I just wanted to have a little proof-of-concept first before jumping in with both feet.
I'm creating a semi perminant set of tracks out of 4"x18' cast iron water pipes left over from a construction site. They are super rigid and HEAVY. I'm going to bolt a couple of angle pieces to align them and then used RR ties to support the logs.
It's been too rainy and wet here the last month to do anything that's not on solid pavement.
gary
Old 04-11-2003, 01:10 PM   #39 (permalink)
That would be great! I definately need ideas on building the cutting head. Here is my e-mail address. scbarret@nortelnetworks.com. I posted some additional photo's of the building phases and my design of the cutting head.
Old 04-11-2003, 01:16 PM   #40 (permalink)
Here is a cap weld on tube steel. I was proud of this one so I figure I'd add it in. [img]/forums/images/graemlins/smile.gif[/img]
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Terms of Use | Privacy Policy | Advertise | © 2009 TractorByNet.com
Safety Warning: TractorByNet.com does not review discussion forum posts for accuracy or safety. Please refer to manufacturer operator and safety manuals before operating tractors or equipment. Additionally, use caution and common sense when applying any advice you receive on TractorByNet.com, and seek professional advice before attempting professional tasks.
Page generated in 0.31169 seconds with 9 queries
