Quick connect jumper cables
   / Quick connect jumper cables #1
bx24
Indiana
I don't know about the rest of you, but my Kubota always has a good battery (since I use it so much) and many of my other battery powered pieces of equipment and ATV's often have dead batteries.
I got tired of taking off the center panel on my Kubota BX to get to the battery to jump it so I canobalized some jumper cables with some quick connects and I can jump and dead item very quickly. I would recommend this to anyone who "jumps" a lot
   / Quick connect jumper cables #2
That is a great idea. Where did you get your quick connects?
   / Quick connect jumper cables #4
I have simlilar but used an old dryer outlet and dryer pigtail , and some old cables.. An extrac connector for yours and you could have an extension cord for other 12 volt uses.(portable lights)
I was going to reply "Now that's some New Yankee thinking!" and then I read where you were from ... Thats great
   / Quick connect jumper cables #6
many have used welder cable plugs and sockets,
for quick connects for jumper cables,
   / Quick connect jumper cables #7
I like the looks of that quick connect. It's not like the grainger one.
bx24, mind sharing where you picked up that quick connect? It looks like it has a weather cap too?
   / Quick connect jumper cables #8
I have a set on most of my vehicles including my travel trailer so I can hook up additional house batterys for long stays with out 120v
or hook the other vehicle to the trailer to charge its battery,
tom
   / Quick connect jumper cables #9
I know what you mean .
Last december I took the panels off both BX1500s so I could jump start the other one .
As I recall, I got them online (here is one I just Google'd)
SB50 SB Series 50 Amp Anderson Powerpole Set - $4.02
I used "SB50 Anderson Power Products" connectors with the optional "T-handle" and dust cover
BTW - The black version of the plug is universal and the other colors only mate with their own color or black so what ever color you chose, you have to stick with it if you plan to use them for other applications
2014 Jeep Grand Cherokee (A56859)
2014 Jeep Grand...
2003 Big Tex 10PI...
2017 Dodge Charger Sedan (A56859)
2017 Dodge Charger...
2018 ARIENS RIDING MOWER (A56859)
2018 ARIENS RIDING...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
Poly Fuel Tank with Electric Pump (A55851)
Poly Fuel Tank...
