MikePA
Super Moderator
Hi Bill, based upon the little square boxes in your reply, I assume you're using some type of word processor to compose your replies? If so, this information from CBN might help.
Change curly quotes to straight quotes and vice versa. Microsoft Word automatically changes straight quotation marks to curly quotes as you type. You might not want curly quotes in some cases, for example, if you're using quotation marks to designate feet and inches. To turn this feature on or off:
On the Tools menu, click AutoCorrect, and then click the AutoFormat As You Type tab.
Under Replace as you type, select or clear the "Straight quotes" with "smart quotes" check box.
Note: You can find and replace all instances of single or double curly quotes with straight quotes in your document. To do this, clear the "Straight quotes" with "smart quotes" check box on the AutoFormat As You Type tab. On the Edit menu, click Replace. In both the Find what and Replace with boxes, type ' or ", and then click Find Next or Replace All.
To replace all straight quotes with curly quotes, select the "Straight quotes" with "smart quotes" check box, and repeat the find and replace procedure.
