Results 1 to 10 of 10
  1. #1
    Member
    Join Date
    Sep 2007
    Posts
    31
    north providence, RI
    ford 1210
    Default HOMEMADE SNOW CAB
    I thought I might post some photos of my recent project.
    I saw alot of post on this topic and thought do it.
    it is for a ford 1210
    I made this out of all stuff laying around in the garage.
    Frame is made out of angle iron (bed frames)
    covered w/ 1/4 plywood
    windows are clear plastic ( the kind on the old lady couches) just stapled to the plywood.
    One hinged door, carpet in side to keep out cold.
    Lights front and rear
    not bad for under $ 50.00 bucks
    Attached Thumbnails Attached Thumbnails HOMEMADE SNOW CAB-christmas-2010-049-jpg   HOMEMADE SNOW CAB-tractor-photos-012-jpg
  2. #2
    Gold Member
    Join Date
    Dec 2008
    Posts
    276
    Central Kansas
    B7800
    Default Re: HOMEMADE SNOW CAB
    I like it. Being a carpenter i like it when can use up plywood and leftovers .Coat of paint every few years will last longtime .Good job.
  3. #3
    Super Member JB4310's Avatar
    Join Date
    Feb 2005
    Posts
    5,645
    Central CT
    J.D. 4310 E-hydro
    Looks very effective, especially for blowing snow. No more coming in looking like a walking snowman! I like the carpet idea to.
    Those homemade cabs are never pretty, but so what.
    JB.
    JD 4310; E hydro, 300CX, 48 BH, 60" box, 72" rake, 72" rear blade, cast pallet forks, 48", 61"HD & 73" high volume bucket.
    FORD 1700; 2 WD, 2600 hrs.
    JD 320; Hydra lift, 48" deck and 48" snow blade.
    2007 Dodge Ram 3500, Cummins 6.7L, Aisin 6 speed, 9ft utility body.
  4. #4
    Member
    Join Date
    Sep 2007
    Posts
    31
    ford 1210
    Thanks guys.
    not bad for a chef i would say.
    had fun making it
    needed a reason to play w/ the new welder.
    next project is getting some heat in the cab
  5. #5
    Member
    Join Date
    Oct 2010
    Posts
    37
    Alberta
    would it not work to tarp the over the sides of the engine so the heat from it blow back into the cab. I have seen that on larger tractors.
    Reg
    Bobcat 743
    Miller Regency 250
    sorry no tractor here
  6. #6
    Platinum Member mcd176's Avatar
    Join Date
    Nov 2007
    Posts
    500
    Wheeling, WV
    Kubota M6800HD / Kubota B2150
    Nice job I love my homemade cab, you will like not being turned into a popcicle, especially with a blower.
    Kubota B2150
    Link to my custom cab: http://www.tractorbynet.com/forums/b...completed.html
  7. #7
    Member
    Join Date
    Sep 2007
    Posts
    31
    ford 1210
    I have a heater for cab but i need to find out were to tape into heater lines
    I have two 1/2 plugs on the top of the water pump.
    i am assuming they can be removed and I bought a kit for plumbing the lines.
    I can't find any info in my owners manual
    need to find out if anyone has done this before for the ford 1210 tractor.
    It's like anything else you learn by trial by error
  8. #8
    Platinum Member Craig Clayton's Avatar
    Join Date
    May 2009
    Posts
    863
    Uxbridge Ontario Canada
    L2250 Kubota
    The soft clear vinyl for couches is a good idea. Several years ago while blowing at night I had a sharp tree branch pierce my soft side cab. It opened a rip 2' long, thank goodness for duct tape.
    My concern about the cab is CO which is Carbon Monoxide , I would not seal yourself in too tight.
    Craig Clayton
  9. #9
    Member
    Join Date
    Sep 2007
    Posts
    31
    ford 1210
    Craig thanks for the concern
    i have a small area done on the pedal area that allows fresh air in
    also built the cab to have air flow threw the cab at top by 1/2 inch in the middle works great
  10. #10
    Super Member scott_vt's Avatar
    Join Date
    Oct 2004
    Posts
    5,145
    east wells,vt
    1986 MF 1040, 1942 Farmall A, 1949 Farmall Super A
    Good Evenin Chefirv,
    Very nice job, I like the color and paint job along with that custom carpet !
    Now all you need is a seat with arm rests, of course rolled and pleated !
    scotty
    ,,,course,,it is gas,and gas is,,well,gas,,so,,but it kills the @#$$ oughta them yellow jackets,,,thingy
    http://www.tractorbynet.com/content/...onth-scott_vt/
Similar Threads
  1. Snow Equipment Owning/Operating Compact tractor for snow removal
    By Grande in forum Snow Removal
    Last Post: 02-23-2012, 07:22 PM
  2. Snow Equipment Buying/Pricing 30ish hp cab tractor for mowing and snow clearing
    By Robert_in_NY in forum Snow Removal
    Last Post: 05-21-2010, 08:44 PM
  3. Rear chains
    By andrewimbrogno in forum Attachments
    Last Post: 12-30-2009, 11:40 AM
  4. Kubota B3030HSDCC cab or John Deere 3720 cab? Please help!
    By FRIZ in forum Buying/Pricing/Comparisons
    Last Post: 07-16-2009, 04:03 PM
  5. Welders don't read this one ! Homemade cab
    By wawajake in forum Build-It Yourself
    Last Post: 12-01-2008, 08:00 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
