HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > General Forums > Build-It Yourself
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 12-04-2002, 10:46 AM   #21 (permalink)
Default Re: Front snowplow bracket help
"But being a mechanical engineer, half the fun of this project is designing it"
Yep, I had to design and build all the brackets for my setup. Took about two weeks and was alot of fun. I sold the tractor, maybe I'll do it again for my new tractor.
Mrwurm is offline   Reply With Quote
Old 12-04-2002, 11:49 AM   #22 (permalink)
At what height are the skids supposed to be set on a snow plow? Do they keep the blade slightly off the ground, or does the blade set on the ground with the shoes set to keep it from digging any deeper?
htiek126 is offline   Reply With Quote
Old 12-04-2002, 12:17 PM   #23 (permalink)
Good question. I guess it would depend on what type of base you are plowing. Gravel, dirt, concrete, asphalt each have their own characteristics. I plow on concrete and use soft steel skid shoes that do not leave marks on the cement like the edge of the blade would. I always adjusted my blade edge to be about a 1/4 inch off the ground. The bad part is that the skid shoes only lasted about half a season of home use. Cost me $30 per set twice each season. I'm not familiar with how skid shoes work on dirt or gravel.
Old 12-04-2002, 12:55 PM   #24 (permalink)
New Member
Shoes on concrete last forever if you run some Stoody hard Surface rod on them, and they don't leave marks on concrete.
As far as setting shoes up for gravel or stone, unless you have a good 4 to 6" of frost in the ground, set the shoes so the blade is a good inch above the paving. If the snow is wet, set the blade higher, or you'll get to rake all the stone back into the drive come spring.
DONOTDELETE is offline   Reply With Quote
Old 12-04-2002, 01:01 PM   #25 (permalink)
New Member
I now understand completely. "But being a mechanical engineer, half the fun of this project is designing it; so I'm apt to go a little overboard Hazmat. "
As we both know MEs do not make mistakes, they merely have design changes. My current setup with the blade pinned to the bucket is revision 7.05 to the original design. Naturally, it's new & improved, and parts are no longer available for the original model.
I'm also contemplating version 8.4A, with side wings and internal braces. When 8.4A comes out, all parts for previous versions will be automaticly deleted from inventory and scrapped.
Old 12-04-2002, 01:45 PM   #26 (permalink)
Super Member
I don't use skid shoes (for 35 years) on my gravel drive or the paved town road. I wait to plow the gravel when it is frozen (as it is now but no snow to speak of) and have no problem. The gravel (crushed limestone) is well packed (I make sure I don't disturb that packed gravel in the fall), and the few loose "marbles" get dusted off into the grass for spring cleaning. I also found out long ago that the grass grows through the gravel on the lawn easily, and hasn't been a major problem if I don't get it broomed back on the drive. I use the skid shoe brackets to put the casters in for moving the blade around the shop (shed) for storage and hook-up.
beenthere is offline   Reply With Quote
Old 12-05-2002, 05:03 PM   #27 (permalink)
Elite Member
hazmat's Avatar
I've had some more time to work on the design. I've got the lift part nailed, but the power angle is giving me a headache!
I found dimensions of chief brand cylinders on the web so I could model them up. To get 30 degrees of angle I need 8" of stroke, but the retracted length doesn't fit. If I go for 20 degrees I can use 6" stroke cylinders & they will fit.
Snowplow cylinders listed in the northern catalog have shorter retracted lengths & are probably the solution, but not enough data to model them, plus they require more elaborate bracketry to attach. Well, probably hold off on the angle for now, to save the money for xmas presents if nothing else.
I attached a pic
hazmat is offline   Reply With Quote
Old 12-05-2002, 06:28 PM   #28 (permalink)
Super Member
What retracted length are you looking for? The snow plow rams are a bit shorter because they don't have the clevis ends (which the Prince have, I think). The clevis ears can be added to the framework however. From your pic, that looks possible (but looks are deceiving, I realize). The Surplus Center catalog has rams that are retracted 17 1/4" (2 x 10 x 2) for $49.95. Push is 7854#'s They also list a (1 1/2 x 10 x 1 1/2) with retracted length of 16 3/4 which are military surplus and said good for plow angle cylinders for $69.95. The 1" pin holes are bored in the end of the rod. Push is 4415 #'s.
Great graphics. I'd sure like to be able to do that. Guessing the cost of the software is out of my reach.
Are you knee deep in snow yet?
Old 12-05-2002, 10:17 PM   #29 (permalink)
Elite Member
hazmat's Avatar
Well I'll have to call Surplus center (I know i bookmarked their number from somebody's previous post here maybe it was you).
I can easily add a clevis where needed. The chief cylinders where 10.25" + stroke for retracted center to center, so an 8" was a whopping 18.25"
Romour has it that the pro E software cost about $30K per person. Not sure if it is really that much, but it is quite expensive. Just looked up one option "flexible design II total was $25K. We've got more of the modules.
They have a "light" version called prodesktop that is $1,500 <A target="_blank" HREF=http://www.ptc.com>Parametric Technologies</A>
I haven't ever shopped for home use software, but they did give us a student version for free at one of the training sessions. Needs a good amount of Horse power to run.
If you decide you want to buy one, I'd be happy to offer opinions on any affordable packages you come accross.
Only 1" so far, but still coming down. The storm passed south of us. My parents are near the cape and have 4" so far.
Due to the cold weather this week, the local ski mountain (next town over) is supposed to open this weekend. Usually they are happy if they get open for x-mas. Might have to take a day off from the home renovations to get some turns in.
Old 12-05-2002, 10:54 PM   #30 (permalink)
Super Member
Surplus Center 1-402-474-4055 Lincoln, NE
I will just dream about the software. Enjoyed your renditions of your design very much.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com
