Skid Steer stick chopper
   / Skid Steer stick chopper #1
Rgillard
Ireland
Fiat 82-94
Hi Guys,
I have designed a log splitter and a kindling splitter to attach to my skid steer. The blade on the end can be rotated depending on what you need to chop. I have attached a 3D pdf of the unit and photos of the valve. The 3D pdf will allow you to rotate the design and hide parts just like a 3D modelling package. When it opens just click on the screen and it will turn from a blue background to a white one. Your left mouse button should let you rotate it and your centre wheel will let you zoom. At the top it will let you pick the view type and show you the model tree. You can isolate individual parts and hide others.
One question I have is regarding the hydraulics. I think I need an open centre valve as the skid steer hydraulics pumps constantly. Is this correct?
I have a valve (pics included) but I am not sure how to check what type it is . It is a chinese brand I believe.... Any help would be great.
Regards,
Ron
  • stick_splitter_25-1-11.pdf
   / Skid Steer stick chopper #2
I'll leave the hydraulics to those better versed in it than me, but I just had to comment that's a pretty neat 3D package. The design looks good and as long as you don't get any gnarly wood, should work fine.
   / Skid Steer stick chopper #3
If you can blow air through the valve in the neutral position, it is an open center valve.
If the valve has plugs in the IN/P or OUT ports, remove them prior to using air to check.
Is that valve a log splitter valve, or just a two spool valve. Otherwise, a detented retract, and shift to neutral.
For faster cycle time, Prince makes a two lever auto cycle valve, and a fast extend valve.
What is the GPM's, and pressure on the SS?
   / Skid Steer stick chopper #4
:thumbsup: I'll let J J do the hydraulic explainin he's much smarter then I
It is a two spool valve that I have lying around doing nothing. The GPM of the SS is 16.4 and the pressure is 190 bar. There is a bolt in the P and T ports. In the ports for the cylinder there is red plastic seals. Do I just need to remove the P and T port bolts and try with the air..Would I be better buying a splitter valve for this? I could use the pedal in the SS temporarily until I get the right valve..
Thanks for the reply J J. I appreciate it a lot.
   / Skid Steer stick chopper #6
Remove the plugs from the P and T ports, and blow air through.
Yes, you can use any open center valve to operate the splitter. You just have to manually operate the handle both ways to retract.
There are three splitter valves that you can use.
Regular splitter valve.
Fast extend splitter valve
Auto split valve, once set..
You can find splitter valves for about $60.00 in the US.
Are you trying to operate the log splitter from the SS seat, or with the valve located on the cylinder?
I had to convert bars to psi. 190 bar = 2755 psi
A 4 in cyl will give you about 17 ton of force.
Extend = 4.8 sec
Retract =3.58 sec
Total cycle time of 8.38 sec
Not to bad .
Your time will be running chasing logs.
Started the build today. Didnt get all the parts cut yet so concentrated on the RSJ side with the cylinder mounts. Hopefully by next week we can get it cutting...Here are some pics of the project so far..You can see in some of my pictures that the oil is milky white (burst a pipe when testing the cylinder). How would the water be getting into the system. The level of the water in the radiator is still full.. This problem was in the machine when I bought it. I completely emptied the oil as much as possible and refilled it with fresh oil but the whole tank is now milky.. Any suggestions would be helpful... Is this going to destroy my skid steer if not dealt with quickly
Ron
   / Skid Steer stick chopper #9
Sometimes with the skid steers when you get water contamination, it takes a couple of cycles to get it out. It takes surprising little water to turn the oil milky, and there is so much stuff for the old oil to cling to in the side tanks of those machines, that it takes a couple times.
Also, take a second and double check the obvious, like a vent cap not installed, or a crack on a lift arm point into the tank.
   / Skid Steer stick chopper #10
If you suspect that you have water in your hydraulic oil here is a suggestion. Drain all the oil into a clean container and let it sit in a quiet corner for maybe a week.Siphon off the oil into another container so that means the first needs to sit about 2' higher. Do it like you were nipping petrol from a storage tank. When you get near the bottom stop and examine for any water. if you had 2 lots of oil you can switch about until the water is stripped away. Are you sure you might not be sucking in rain from some source. Does the machine cool the hydraulic oil through a rad based heat exchanger?
Craig Clayton
DESK (A53843)
DESK (A53843)
2015 UTILITY VS2RS 53FT REEFER TRAILER (A53426)
2015 UTILITY VS2RS...
2018 CATERPILLAR 950GC WHEEL LOADER (A52705)
2018 CATERPILLAR...
2017 FREIGHTLINER M2 106 (A53843)
2017 FREIGHTLINER...
REYNOLDS 100 - 8 YARD PULL TYPE SCRAPER PAN WITH DRAWBAR (A52748)
REYNOLDS 100 - 8...
