Page 1 of 2 12 LastLast
Results 1 to 10 of 12
  1. #1
    Join Date
    Dec 2009
    Posts
    113
    cataract wi
    2003 New Holland tc 29d
    Default New Quick attach
    Heres some pics of a quick attach setup I'm building for my 7308 loader on my New Holland. Cut the bucket brackets off and replaced with a socket on the bucket for them to fit into, then held on the bottom with a pin similar to whats on my friends JD 970. Also pics of brush grapple I'm working on and the qa socket tacked onto it to check fit. Waiting on hose fitting for that, hopefully be able to give it a test drive on Thursday. What do you think? Go easy on me this is my first project
    Attached Thumbnails Attached Thumbnails New Quick attach-grapple-002-jpg   New Quick attach-grapple-004-jpg   New Quick attach-grapple-003-jpg
  2. #2
    Join Date
    Dec 2009
    Posts
    113
    cataract wi
    Default Re: New Quick attach
    And heres the rest of the pics. ( is there a limit to number of pics per post?)
    Attached Thumbnails Attached Thumbnails New Quick attach-grapple-004-jpg   New Quick attach-grapple-009-jpg   New Quick attach-grapple-011-jpg
  3. #3
    Super Star Member J_J's Avatar
    Join Date
    Sep 2003
    Posts
    18,923
    JACKSONVILLE, FL
    Power-Trac 1445, KUBOTA B-9200HST
    Quote Originally Posted by mroldstyle View Post
    I have not seen a limit as to the numbers of photo. There is also the PHOTO GALLERY at the top of the page.
    J.J.
    When I works, I works hard. When I sits and thinks, I goes to sleep.
    Git er done.
  4. #4
    Silver Member Wheatland KB's Avatar
    Join Date
    Feb 2007
    Posts
    141
    Cluny, Wheatland County, Alberta (east of Calgary)
    Kubota L3400HST
    Looks good. Let us know how it works out as far as strength and anything you would have done differently or would do again.
    I would like to do something similar in the future so I really appreciate the post.
  5. #5
    Veteran Member jimmysisson's Avatar
    Join Date
    Jul 2005
    Posts
    2,344
    W.Mass
    1993 NH 2120 (the best), 1974 MF 135 (sold, but solid), 1947 Farmall A (bought, sold, bought back, sold again), 1956 MH50 lbt (sold, in 1980, darn it)
    Don't know if you're going to rig the hydraulics so the clamp teeth will go down below the rake tines like that, but you will like it if they do. Then you can pull stuff back out of a pile (brush, or logs more likely) and pick up just what you want. Nice looking.
    Jim
    "Anything worth doing is worth doing slowly" Mae West
  6. #6
    Super Member teg's Avatar
    Join Date
    Jul 2005
    Posts
    5,636
    Raleigh, NC Hillsville, VA
    L2800 - HST
    ...is there a limit to number of pics per post?...
    Heck NO!!! the more the merrier
  7. #7
    Gold Member TraderMark's Avatar
    Join Date
    Feb 2001
    Posts
    377
    Southeast Georgia
    Ford 1720
    Good looking work Mroldstyle.!!!
    Looks like you and are thinking along the same lines on the brush grapple. I've been working on one that's very similar to your design. I'll try and post some pics soon!
    Mark
    1720 Ford 4x4 w/ 7108 FEL
    Case 1845 Uni-Loader NO it's NOT a "C"
    190C John Deere
    Various implements, some store bought, some home made.
  8. #8
    Join Date
    Dec 2009
    Posts
    113
    cataract wi
    Quote Originally Posted by jimmysisson View Post
    Jim
    Yup thats what I'm planning. Thinking that way if I'm carrying one or two logs it will clamp down on them tighter. Also plan on making a removable stop on the end of the forks so I can just pinch one log and then pick it up to a comfortable height for blocking into firewood. Allready tried out the hydraulics, temporarily hooked up to my rear remotes and it works good, gotta be carefull to feather the valve or its pretty fast but otherwise works as planned. Now waiting for hose and fittings to reach up to the front. Hopefully there not stuck in a snowdrift between here an Pa. somewhere on the UPS truck!
  9. #9
    Join Date
    Jul 2005
    Posts
    5,636
    L2800 - HST
    ...gotta be carefull to feather the valve or its pretty fast...
    If it becomes a problem, install a needle valve that works in both directions... Surplus Center - N600S 3/8 NPT PARKER NEEDLE VALVE you can slow down the flow..
  10. #10
    Bronze Member UnclePaul's Avatar
    Join Date
    Jul 2008
    Posts
    92
    Unionville, Pa
    John Deere 3720, Z950A, M655, 345, 65' 110
    The only thing I saw that might be a problem is in the 3rd picture in post #2 it looks like the top of the quick hitch welded to the bucket might hit the dump/curl piston. I hope not, because it looks light a cool setup!
Similar Threads
  1. Differences in Quick Attach Bucket Mounts?
    By Dougster in forum Attachments
    Last Post: 10-22-2012, 07:06 PM
  2. new B3030 Quick Attach Question
    By Friver in forum Kubota Buying/Pricing
    Last Post: 02-16-2007, 08:38 PM
  3. FEL bucket conversion to a Quick Attach???
    By Bob_Skurka in forum New Holland Owning/Operating
    Last Post: 09-27-2004, 03:29 PM
  4. ATI "pin type" Quick Attach for NH, Kutota, Case?
    Last Post: 07-04-2004, 07:00 PM
  5. Tach-all quick attach for LA402 loader???
    By Henro in forum Kubota Owning/Operating
    Last Post: 09-22-2003, 12:35 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
