Page 1 of 3 123 LastLast
Results 1 to 10 of 24
  1. #1
    Veteran Member bakerg's Avatar
    Join Date
    Jan 2011
    Posts
    1,054
    Woodslee Ontario Canada
    2010 Massey GC2400
    Default Scafer for Boxblade
    Started building a boxblade in the fall and had put it away for the winter as I do not have a heated garage to work on it. After reading some forums on here, I got it out and have been using it to move snow. I still need to install scafers on it in the spring and I was just wondering what I should use. I do not want to spend alot of money on this and I am trying to use scraps I have around the farm. I have some scrap steel and was going to try to make my own scafers but was wondering if I could use tines off a triple K that I have lying around. Would they hold up when I do my laneway or would they just snap in half? Here are some pics of the boxblade, I will need to make some modifications to the 3 point hitch in the spring.
    Attached Thumbnails Attached Thumbnails Scafer for Boxblade-01-23-11_1017.jpg   Scafer for Boxblade-01-23-11_1018.jpg
    GC2400,FEL,MMM, BOX BLADE,& SCRAPER BLADE
    Nothing runs like a Deere, but I love my Massey Ferguson
    http://www.canadianantiquetractor.com/
    Uploaded with ImageShack.us
  2. #2
    Bronze Member chumly2071's Avatar
    Join Date
    Mar 2006
    Posts
    64
    Lexington, IL
    Default Re: Scafer for Boxblade
    I think you are meaning "scarifier". I am going to be building my own box blade this spring, and I am gong to make them out of 2-1/2 x 3/4 bar stock to mimic commercially available ones. not sure if I am going to try to put cutting teeth on, or just cover the "J" portion cutting tooth with hard face welding for abrasion resistance.
  3. #3
    teg
    teg is offline
    Elite Member
    Join Date
    Jul 2005
    Posts
    3,943
    dsfasdf
    sdfadfa
    Quote Originally Posted by bakerg View Post
    ...was wondering if I could use tines off a triple K...
    Not sure what that is, you have photos of what you are thinking about using???
    TractorByNet.com, WAS next best thing to seat time - not any more.
  4. #4
    Join Date
    Jan 2011
    Posts
    1,054
    2010 Massey GC2400
    Quote Originally Posted by teg View Post
    The tines look like what is on this culivator.
    Attached Thumbnails Attached Thumbnails Scafer for Boxblade-1448435-634073526700226602.jpg
  5. #5
    Join Date
    Jan 2011
    Posts
    1,054
    2010 Massey GC2400
    Quote Originally Posted by chumly2071 View Post
    Yes that what I meant, I think
  6. #6
    teg
    teg is offline
    Elite Member
    Join Date
    Jul 2005
    Posts
    3,943
    dsfasdf
    sdfadfa
    Those are designed to "give" I think they are called "S" tines and have spring to them. You could use it but it's very different from the very ridged box blade tines. If you are looking for aggressive deep digging, the S tines will not work that well. S tines break up dirt clogs very well.
  7. #7
    Join Date
    Jan 2011
    Posts
    1,054
    2010 Massey GC2400
    Just want to use it to level out the driveway, I will not be using it on a regular bases. Drive way is based sand and gravel with 3/4 clear top.
  8. #8
    teg
    teg is offline
    Elite Member
    Join Date
    Jul 2005
    Posts
    3,943
    dsfasdf
    sdfadfa
    Should be good to go... How many were you planning to use?
  9. #9
    Join Date
    May 2008
    Posts
    125
    NEK Vermont
    '49 Ford 8N & '08 Kubota L3400
    I bought a used box blade a few years ago to do our driveway (800+') as well as neighbors plus family members & I think I have used the scarifiers grading twice. I will cut ALOT more than you think.
    Mine is a Woods/Gill blade with the flip over scarifiers, which make it easier to engage the rippers than the standard type, & I still don't really use them very often.
    I'd try yours as-is & see if you really need them.
  10. #10
    Join Date
    Jan 2011
    Posts
    1,054
    2010 Massey GC2400
    Blade is 54" wide and was planning to use 4 or 5 at about 1 to 2 inch depth.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
