I need to cut some wood
   / I need to cut some wood #1
blueone
Eastern Panhandle WV
KOBOTA L3540
To try this out!! This was inspired from one I saw here, but forgot the posters name as it was a year ago or so, it was yellow and on a FORD.
Mine is similar but has some differences.
The yellow one had slots for chain but that didn't work for me as I have tongs and needed somewhere to hook them up. Also wanted to beef up the blade a bit.
Yes I've read about pulling from the 3pt a lot here but, as I see It if the log is off the ground at the pulled end and you go SLOW and EASY it should work fine. I've done this for 10 years with another rig but this is the thought of 2 years of study and 1 year of scrap hording.
Let me know the GOOD BAD THE UGLY!!!!!
   / I need to cut some wood #2
Shouldnt have posted this, now I wanna make one. :laughing: Great job on the build, i especially like how beefy it is, looks like it can get some serious work done. Great job! :thumbsup::thumbsup:
   / I need to cut some wood #3
Blueone - is that シ" wall tubing? Looks rugged if it is, if not are you concerned about side pulls twisting the tower? I like the log pushing pins.
Jim
   / I need to cut some wood #4
Nice rig.
Why don't you weld some grab hooks on the top of the blade so you can hook the logs lower if you want to. You could drag a bigger hitch and it would be safer for big logs.
Thanks it's alot bigger than what i'd been using [below] for the last 8 years.
Jim
Thanks, It's 3-1/2 x 3/8
Nice rig.
Didn't think of that good idea Thanks.
   / I need to cut some wood #7
hey im inspiring!
hey im inspiring!
Yes you are:thumbsup:
sizzami have you used your a lot and if so have you had any trouble or would you make any mods to your design?
   / I need to cut some wood #9
Nice skidder!
Gas up the saw & go.
   / I need to cut some wood #10
i have used it alot and yhe only mods i made wer hooks down on the bunch blade
(4) Ratchet Straps (A57453)
(4) Ratchet Straps...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
New/Unused MX-MRT14 Mini Stand on Track Loader (A57453)
New/Unused...
New/Unused Quick Attach Rock Hammer (A57454)
New/Unused Quick...
FORKLIFT (A56857)
FORKLIFT (A56857)
2012 Peterbilt 389 Semi (A59814)
2012 Peterbilt 389...
