Page 1 of 2 12 LastLast
Results 1 to 10 of 15
  1. #1
    Member GaryInWA's Avatar
    Join Date
    Jun 2004
    Posts
    41
    Western Washington
    JCB 1400B backhoe, Kubota B21
    Default Yet another home made box scraper
    I have been wanting a box scraper for my tractor for some time and had some free time and materials to build one. I would guess it took me about 15 hours to design, fabricate and weld everything..I havent painted it yet and dont think I will.
    My tractor is a kubota B21 with a detachable backhoe and can only handle 4 foot implements so I built a 4 foot box scraper.
    I used a Dewalt angle grinder with cutting disc to cut most of the metal to length,I have burned up many an angle grinder and so far the dewalts seem to last the longest plus they are bright yellow and easier to find when I misplace them
    I used my trusty Lincoln buzz box and 7018 rod to weld everything together so if the welds doesnt look purdy thats why I have never used a wire feed welder and prefer stick welding as I can reach into spots with the welding rod that arent accessible with a wire feed welder.
    I have a 4 foot brush hog for my tractor so used measurements from its A-frame when building the a-frame for the box scraper. The metal I used for my a-frame is a little heavier duty than that used on a box scraper I saw at my local tractor dealership so I think it can handle the tasks ahead.
    I decided to buy 4 rippers/scarcifiers rather than build them and boy are those things pricey but it would have taken me forever to cut, heat treat, etc my own.
    I tested the scraper out and it worked pretty good, I think I will strap a few cinder blocks to it and try it again as the gravel road I share with my neighbors is very hard packed and the rippers arent digging in enough....I probably will add a cutting edge to the box blades box which will help gather up loosened material and redistribute into the potholes.
    I placed a bunch of photos of the build up and some photos of potholes before and after using the scraper on them at:
    Box Scraper pictures by luvmud85 - Photobucket
    Attached Thumbnails Attached Thumbnails Yet another home made box scraper-100_0164-jpg   Yet another home made box scraper-100_0165-jpg   Yet another home made box scraper-100_0157-jpg
  2. #2
    Gold Member ihuntbear's Avatar
    Join Date
    Jan 2010
    Posts
    430
    new brunswick, canada
    2015 tym T554 and 1999 Kobota m4700
    Default Re: Yet another home made box scraper
    nice job..I think I'll build one when the snow leaves
  3. #3
    Super Star Member ovrszd's Avatar
    Join Date
    May 2006
    Posts
    17,623
    Missouri
    Kubota M9540, Ford 3910FWD, Ford 555A, JD2210
    Looks purdy to me!!! Wish you lived nearby, I'd give you a used grader blade to add for a cutting edge. Nice job. You'll get years of good service from that outfit.
    I welded for forty five years with a Lincoln. Bought a wire welder four years ago. I ran outta wire the other day and finished up a project with the Lincoln. Burned a couple rods before the technique came back to me. I'd forgotten how to weld with stick.
    Richard
    "Happiness isn't having everything you want, it's wanting everything you have."
  4. #4
    Join Date
    May 2010
    Posts
    137
    Brighton, Tn.
    Mahindra 4110 FEL, New Holland TC40 FEL and Backhoe, New Holland TC29, IH Farmall 806 LP with FEL, Exmark Zero Turn
    Your build on the box blade looks good. Definetly add the cutting edge like you described. One question on the hook up to the lift arms. The ends of the left and right lift arms appear to turn out towards the tires. Are they reversed from what they should be?
    Bill Beyer
    Brighton Tn.
  5. #5
    Elite Member
    Join Date
    Aug 2005
    Posts
    3,437
    Maine
    Kubota L3301
    nice, I also plan to build one this summer using iron from an old bush hog.
    You've given me some ideas on what I need to do.
  6. #6
    Super Star Member LD1's Avatar
    Join Date
    Apr 2008
    Posts
    18,198
    Central Ohio
    Kubota MX5100
    Quote Originally Posted by BillBeyer View Post
    I noticed that as we. Good eye
    ".........there is only one way to find out."
    "Ok, hold my beer and watch this.........."
    MX5100 DIY Remotes
    MX5100 Diverter install
    Front Snow Plow Install
    Ford 5500 Backhoe
    Kubota MX5100HST w/LA844
    2005 Dodge 3500 4x4 Diesel
    8N Rebuilt and restored
    Bushhog 306
    3 Homemade wood hauling trailers
    Dolmar 6400 84cc ported
    Sachs-Dolmar 120SI Ported
    (4) Sachs-Dolmar 116SI Ported
    Dolmar PS540
    Sachs-Dolmar 115i
    Sachs-Dolmar 117
    Sachs-Dolmar 112
  7. #7
    Gold Member TraderMark's Avatar
    Join Date
    Feb 2001
    Posts
    377
    Southeast Georgia
    Ford 1720
    Good looking job!!
    +1 on adding the cutting edge
    1720 Ford 4x4 w/ 7108 FEL
    Case 1845 Uni-Loader NO it's NOT a "C"
    190C John Deere
    Various implements, some store bought, some home made.
  8. #8
    Join Date
    Aug 2005
    Posts
    1,491
    Guernsey Co. Ohio
    Ford 3000, JD 2550
    Pins pointing out is normal, but it does appear that they should be reversed to fit the tractor arms better.
    Edit: Never mind, I read that completely wrong. I agree that the arms appear to be backwards.
  9. #9
    Super Member
    Join Date
    Jul 2005
    Posts
    5,801
    nowhere
    s
    Quote Originally Posted by LD1 View Post
    I noticed that as well. Good eye
    Looks like the might be bent... or s I like to call "custom designed".
  10. #10
    Platinum Member bironacad's Avatar
    Join Date
    Jan 2011
    Posts
    659
    Southern Ontario, Can
    New Holland 3045/2010
    Didn't think to build a box blade, beaudy, more for the to do list, lol, I wonder when I will get that done, eh?
    Last edited by bironacad; 03-03-2011 at 04:57 PM. Reason: didn't read then did read but looks like I can't read lol
    “If at first you don't succeed, you are running about average.”
    M. H. Alderson
    New Holland 3045 with cab
Similar Threads
  1. Log cabin construction
    By gcp in forum Rural Living
    Last Post: 04-05-2014, 12:48 AM
  2. Box scraper = chisel plow ?
    By wbyman in forum Attachments
    Last Post: 02-21-2012, 04:52 PM
  3. Box Scraper techniques for basic box scraper
    By WAGIRL in forum Attachments
    Last Post: 05-26-2010, 11:25 AM
  4. Anyone know how I can harden home made skids?
    By BayouMan in forum Customization
    Last Post: 06-27-2009, 09:59 PM
  5. Home Made ROP For Iseki 1900-TL
    By tncruzin in forum Attachments
    Last Post: 03-24-2005, 07:51 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
