Results 1 to 8 of 8
  1. #1
    Join Date
    Nov 2007
    Posts
    154
    N.E Tennessee
    Deere 2320, Bobcat 322 mini-ex, Bobcat 763 skidsteer
    Default Heres my home-made boom pole
    How many of your projects start with an item that you just need to find a use for?
    I had picked up a carpet rod for a forklift (FREE!!!!!!) a while back and needed to find a "use" for it. Its a 10 foot long solid steel dowel about 3" diameter - they use them to move rolls of carpet.
    I thought a boom pole/crane would be handy to lift suplies onto the roof, pick stuff up, etc.
    Aside from the skid steer plate (bought it new), this was all scrap and stuff laying around the shop.
    I painted it today - pictures were before painting. Still need to weld an attachment point on the end of the pole. Figure I will add both an attachment ring and a chain hook at the end, then add a ring about half way up for heavier lifts.
    I was initially concerned about the weight of the thing - not sure how much it could lift with 10 feet of leverage plus the weight of the pole. But the skid steer (Bobcat 763) hoisted about 300 pounds hanging on the end of the pole with no problem. I will gradually increase loads to see how much it takes to get the skid tippy - just so I know. But I don't see me lifting really heavy weight with it anyway.
    The 10 foot pole, plus the skid's lift gives me about 25 feet at max lift.
    Attached Thumbnails Attached Thumbnails Heres my home-made boom pole-img00371-20110310-1320-jpg   Heres my home-made boom pole-img00372-20110310-1320-jpg   Heres my home-made boom pole-img00373-20110310-1320-jpg   Heres my home-made boom pole-img00374-20110310-1320-jpg
  2. #2
    Join Date
    Mar 2005
    Posts
    718
    NE Oklahoma
    Kioti ck30
    Default Re: Heres my home-made boom pole
    Bet that's a stout pole..
    Some ideas..
    Here's what I did on my tip. I've removable attachments for it.
    And added strength with a ring and rebar.
    NE Oklahoma, ck30 kioti BH w/thumb, Broken FEL, toothbar, box blade. JD 60" brush hog, home made forks
    My Photo's
  3. #3
    Padawan Tractor Learner
    Advertiser
    Johndeere3720's Avatar
    Join Date
    Mar 2009
    Posts
    6,385
    NW Oregon
    Bobcat 430 & T140
    Wow, very nice idea. For lifting have you considered a hook near the middle as well? Then if you needed you ocould lift something closer to tour skidsteer and have a better tine with lift capacity and ballance. Also, for counter ballance have you considered putting weights on the back of your skidsteer? My grandpa put weight plates on his skidsteer which is similar to yours and it helps quite a bit for added ballast on the back. He has 2 3/4" plates which are about 10"x2' on each side. But when bolting them on, be careful because one of his bolts rubbed through the auxilary hydraulic hose when he was using the backhoe and spewed hydraulic fluid everywhere. Since it was boxed in the loader arm mounts it took us several hours to replace. Dont put to much on though because once you remove the bucket you will pop a wheelie and wont be able to hook up to your attachments.
    My Fleet:
    2004 Bobcat 430G Excavator
    2006 Bobcat T140 Compact Track Loader
  4. #4
    Join Date
    Mar 2005
    Posts
    718
    NE Oklahoma
    Kioti ck30
    BTW, as for making it before you had a need for it, so did I. However, I just put my trusses up on my new metal building this last year..
    Trusses came in, welded a chain to a piece of tubing that fits on my tip, then welded a piece of heavy rebar that I bent, and walla,, 15 minutes had a truss holder attachment for my pole..
    Worked great on a 13 foot wall building!
    My Photo's
  5. #5
    Super Star Member LD1's Avatar
    Join Date
    Apr 2008
    Posts
    18,343
    Central Ohio
    Kubota MX5100
    Looks great.
    Just keep in mind that it doesn't take very much weight out that far to cause the SS to get a little tippy
    ".........there is only one way to find out."
    "Ok, hold my beer and watch this.........."
    MX5100 DIY Remotes
    MX5100 Diverter install
    Front Snow Plow Install
    Ford 5500 Backhoe
    Kubota MX5100HST w/LA844
    2005 Dodge 3500 4x4 Diesel
    8N Rebuilt and restored
    Bushhog 306
    3 Homemade wood hauling trailers
    Dolmar 6400 84cc ported
    Sachs-Dolmar 120SI Ported
    (4) Sachs-Dolmar 116SI Ported
    Dolmar PS540
    Sachs-Dolmar 115i
    Sachs-Dolmar 117
    Sachs-Dolmar 112
  6. #6
    Elite Member kebo's Avatar
    Join Date
    May 2006
    Posts
    2,905
    Lexington, SC
    2001 John Deere 790 4x4, bar tires
    Looks like you're ready for a jousting match!!
    Nothing could be finer than riding my JD790 in South Carolina!!
    2001 John Deere 790 4x4 with Model 70 FEL, 5ft International World Agritech bush hog, 5ft Wallberg BB, 5ft Frontier disc harrow, 5 1/2ft Cultipacker, 5ft Sitrex finish mower, Leinbach PHD with 9" & 12" augers, Leinbach middlebuster, Leinbach #11 Field Cultivator, custom 3pt handi-hitch, clamp on bucket forks, Pat's Easy Change.
    It's not how slow you mow... it's how well you mow slow!!
  7. #7
    Veteran Member JoelD's Avatar
    Join Date
    Jan 2005
    Posts
    2,138
    Windham, NH and York, ME
    Kioti LK3054xs TLB, 2004
    Default
    May want to consider as in the other example putting something long the top Sid to prevent bending when loaded at the end
    Not sure about the term but it would be for example some flat rolled stock with a piece of square stock in the middle with both ends of the flat stock welded to your pole
    Flat to round my be tough fit but you get the idea
    Nice project and a crane is always useful to have around
    Joel
    Joel
    2004 Kioti LK3054XS TLB
    Woods Box Blade
    King Cutter Tiller
    Three Point Snow Blower
    York rake
    60 inch king kutter tiller
    2000 Dodge Durango 5.9
  8. #8
    Join Date
    Nov 2007
    Posts
    154
    N.E Tennessee
    RCR, thats a good idea about the changable ends! I may adopt that. It will be a bear to drill the hole for the pin though...
    I had thought about making a sleeve (tube) to go over the end to give me more height for lighter stuff. That could be one of the attachments, but I don't think I would use more height that often and the leverage of the weight gets worse as length increases. This gets on top of my house and barn ok as-is. Don't see me needing more than that.
    As for jousting (), on anything but level ground, the skid's short wheelbase gets it pitching front to back with any kind of speed - I would be scared of grounding the end in the dirt as it pitched forward. THAT would be a sudden stop I would NOT want to make!!!
Similar Threads
  1. Home Designed 12'- 24' POLE SAW
    By Craig Clayton in forum Customization
    Last Post: 04-13-2010, 09:58 PM
  2. Home brew boom pole
    By cityfarma in forum Attachments
    Last Post: 09-06-2007, 09:12 PM
  3. FEL boom pole w/basket
    By LetsRoll in forum Build-It Yourself
    Last Post: 12-04-2005, 06:45 PM
  4. Another "want to build a boom pole question" !
    By NM_Mike in forum Build-It Yourself
    Last Post: 11-18-2005, 10:28 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
