Results 1 to 8 of 8
  1. #1
    Join Date
    Aug 2006
    Posts
    737
    Buckhannon, WV
    1947 Ford 2N and 2003 Kubota B7500
    Default Plans for my "Carryall-Type Thing"
    I have long wanted a carryall to use while mowing, but with a MMM, the 3PH controls it. So, you would end up with it basically dragging on the ground when mowing.
    So, I stared at the back of my tractor for a while......
    What I came up with is kind of a carryall, but not really. More of a headache rack. It will connect to the tractor via the socket for the fixed drawbar and the toplink. Of course, this means that it will not raise and lower. But, it will give me a place to put some pipes to carry a shovel, rake, etc. As well as some hooks to hang buckets/chains/stray children off of.
    I also put a provision in for a removable floor, but not so sure on that. It's not going to be super strong.
    Anyhow, here is a quick drawing I did. Would love some feedback and thoughts before I buy the steel.
    -=Mark=- 03 Kubota B7500, 47 Ford 2N
  2. #2
    Super Star Member
    Join Date
    Aug 2001
    Posts
    14,767
    Upper Midwest USA
    JD_4x2_Gator, JD_4300, JD_X485, JD_425, JD_455, JD_110
    Default Re: Plans for my "Carryall-Type Thing"
    So far so good.
    Do the 3 ph arms run by on the outside of the carryall?
    When is the build date?
  3. #3
    Join Date
    Aug 2006
    Posts
    737
    Buckhannon, WV
    Quote Originally Posted by beenthere View Post
    So far so good.
    The would run behind it. I it will be far enough out to miss it.
    This weekend isn't good, but maybe next week.
  4. #4
    New Member
    Join Date
    Feb 2009
    Posts
    9
    looks like a good build. I will be following this one to see how it goes.
    Beefie
  5. #5
    Veteran Member Runner's Avatar
    Join Date
    May 2007
    Posts
    1,682
    Missouri
    John Deere 2520, 1989 John Deere 185, 1960 Panzer T70B
    I like your idea, opens up quite a few possibilities.
    I built a kind of mini-carryall to hang on the back of my lawn tractor or CUT to thow trash and what-not in while mowing, or to carry small tools, etc. I call it the tractor tub.
    Attached Thumbnails Attached Thumbnails Plans for my "Carryall-Type Thing"-img_3056-b-jpg
    Runner
  6. #6
    Elite Member
    Join Date
    May 2010
    Posts
    3,940
    of my
    Here
    I don't have a MMM, so I'm not sure: Are the 3PH lower arms directly connected to the MMM arms?
    If not, you could mount the carryall to the 3PH arms, use them to lift the carryall up into place, lock it at that height, & then continue to use your MMM.
    If yes, this idea wouldn't work, as your MMM would also be locked up.
  7. #7
    Join Date
    Aug 2006
    Posts
    737
    Buckhannon, WV
    Quote Originally Posted by beppington View Post
    The MMM lift hooks over the 3ph arms, so they have to move up and down with it.
  8. #8
    Elite Member
    Join Date
    May 2010
    Posts
    3,940
    of my
    Here
    Quote Originally Posted by wvpolekat View Post
    Well drat.
Similar Threads
  1. Replace directional valve type tandem by type float
    By hodinhtran in forum Hydraulics
    Last Post: 11-03-2010, 09:01 AM
  2. shut down
    By kenmac in forum Trailers & Transportation
    Last Post: 12-23-2008, 12:35 AM
  3. GRASS/LEAF VAC/BLOWER--ENGINE or PTO TYPE (which)
    By CampMan in forum Kubota Owning/Operating
    Last Post: 04-23-2006, 10:21 AM
  4. Conceptual Building Plans
    By zekeman in forum Rural Living
    Last Post: 03-29-2005, 01:11 PM
  5. Plans, plans and more plans
    By AndyF in forum Build-It Yourself
    Last Post: 10-07-2002, 11:43 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
