Utility Storage Box replacing Ballast Box
   / Utility Storage Box replacing Ballast Box #1
LGinIA
Iowa
JD X485 AWS,B2410,RTV900
I mow over 6 acres on property that has trees everywhere. I'm always picking up tree limbs or debris thrown by the general public and need a container that I can toss these items into until I return to the shop area. Other than purchasing a steel ballast box, has anyone built a utility box that would attach to a 3-pt and have a drop down side? Would a wood box hold together using the 3-pt?
   / Utility Storage Box replacing Ballast Box #2
Try a CarryAll and customise it to your needs. There are several post that have delt with them and best of all you can get them cheap.
   / Utility Storage Box replacing Ballast Box #3
LGinIA... Here is a picture of one that I built. I bought the frame from TSC for $74. I made the bottom and back out of 2X6s and a 2X10. Sides and front are white pine slats on regular 2X4 posts. The 2X4s are held in place by stake pockets purchased at TSC.
It took one afternoon to build.
John
   / Utility Storage Box replacing Ballast Box #4
This is the utility box I made. It slips over the pallet forks attached on the 3 point hitch and also fits the pallet forks on my loader. Sides, front, and rear are removable. Couldn't get along without it. I only remove it when mowing.
JackIL
Thanks for the ideas. I'll look into building a smaller version that I can carry on my 3-point while mowing. As usual, the TBN members have great functional ideas. I appreciate the suggestions, thanks.
   / Utility Storage Box replacing Ballast Box #6
Jack,
I like your utility box also. Any more picture's or descriptions?
   / Utility Storage Box replacing Ballast Box #7
Thats a great piece of rig you got there.... That gave me Ideas....Thanks!! /forums/images/graemlins/tongue.gif
