Results 1 to 9 of 9
  1. #1
    Join Date
    Sep 2010
    Posts
    91
    Central NYS
    Kubota B9200
    Default Front end weights
    I have a B9200. I would like to build some front end weights. I need just a little weight up front to counter balance when I'm skidding logs. Have any of you folks done this? Thanks, smoker
  2. #2
    Gold Member 600rider's Avatar
    Join Date
    Jul 2007
    Posts
    361
    union city pa
    2004 kubota b7510
    Default Re: Front end weights
    I use front end weights. I made some from some cutouts at work, they are 3/4" thick and weigh about 25# each and have 8. I only put them on when I need to hold the front down then take them off because I dont want the weight while I am mowing (I have a MMM) Used to have front wheels loaded with calcium but never liked the weight in the summer. we had a job the required us to cut a window in the steel that was about 10"x14" and I grabbed 8 to make the front weights. I cut out the corner and milled a slot to fit over the bumper on my B7510 and they work great! I would never go back to loaded tires!
  3. #3
    Join Date
    Sep 2010
    Posts
    91
    Central NYS
    Kubota B9200
    600rider, sure would like to see a photo of what you did. I read something about using lead that interested me as I used to cast many lead bullets. smoker
  4. #4
    Join Date
    Jul 2007
    Posts
    361
    union city pa
    2004 kubota b7510
    Here are some pics of my weights and a bracket I made.
    The first pics are of the bracket. It just slides over the bumper and then I put the weights on it. No bolts or fasteners of any kind. Simple!!
    Attached Thumbnails Attached Thumbnails Front end weights-0629111613-jpg   Front end weights-0629111614-jpg
  5. #5
    Join Date
    Jul 2007
    Posts
    361
    union city pa
    2004 kubota b7510
    Here are the weights cut from a sheet of 3/4" thick plate. These were actualy scrap cut-outs and were being thrown away and I grabbed 10 of them. I have a friend that ran the machine right next to me (horizontal mill) cut the notches for me. They just slide over the bracket that slides onto the bumper. Again no fasteners just gravity to hold them on. I have had them 6 or 7 years nad never had a problem with them falling off.
    Attached Thumbnails Attached Thumbnails Front end weights-0629111614a-jpg   Front end weights-0629111615-jpg   Front end weights-0629111615a-jpg
  6. #6
    Join Date
    Sep 2010
    Posts
    91
    Central NYS
    Kubota B9200
    Thats really good, outstanding!!! I looked up a picture of your tractor and the front frames appear to be indenticle. Thank you very much for the pictures and giving me a super starting point. smoker
  7. #7
    Join Date
    Sep 2010
    Posts
    91
    Central NYS
    Kubota B9200
    Much to my embarrasment as I was loking at the tractor frame to get some dimensions I find that with the loader full dow there isn't enough room between the loader frame and the tractor frame to throw a barn cat through.....very close.....like less than 6". Thought your idea was going to solve the problem. The loader is a kubota BF350 and the tractor is the B9200, there must be something they do to get front end weights to work??????
  8. #8
    Join Date
    Jul 2007
    Posts
    361
    union city pa
    2004 kubota b7510
    Sorry I can't help anymore as I don't have a FEL (thinking that might be the next big build for me! ) I am thinking they might add weight by way of front wheel weights or liquid in the tires. I guess if ya have the
    FEL on you could just fill the bucket!!!! that should add enough weight to hold the front down!
  9. #9
    Join Date
    Sep 2010
    Posts
    91
    Central NYS
    Kubota B9200
    Weight in the bucket works great......except, before I snag my tree I have to push the brush and tops out of the way which needs an empty bucket. If I did use a stump or chunks for weight I woulod have to continually unload and reload...Gettin kinda old for that drill....know what I mean? I'll contact my dealer in the morning...let you know what he suggests. smoker
Similar Threads
  1. JD 790 front end problems
    By DWCox in forum John Deere Owning/Operating
    Last Post: 05-13-2014, 09:46 PM
  2. Tires Tires sizes
    By Conservation in forum Owning/Operating
    Last Post: 12-26-2008, 09:26 AM
  3. Ballast Front weights for 2630/3030
    By BCNU in forum Kubota Owning/Operating
    Last Post: 09-09-2006, 07:40 PM
  4. Ballast MT372D - front end weights
    By HalReh in forum Mitsubishi/Satoh
    Last Post: 07-22-2006, 10:40 PM
  5. Front weights
    By Anonymous Poster in forum Customization
    Last Post: 04-25-2003, 04:10 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
