Results 1 to 9 of 9
  1. #1
    New Member
    Join Date
    Jun 2008
    Posts
    5
    Default Ford Loader
    I bought this Ford loader,Can't read the info tag,Can anyone identify it??I have a Ford 3000 diesel I want to mount it on,Any info on mounting brackets??
    Attached Thumbnails Attached Thumbnails Ford Loader-imag0037.jpg   Ford Loader-imag0038.jpg
  2. #2
    Elite Member sandman2234's Avatar
    Join Date
    Dec 2005
    Posts
    4,042
    Jacksonville, Florida
    JD2555
    Default Re: Ford Loader
    Well, it isn't bent up enough to be Spiveyman's loader from the tractor he had...
    David from jax
    A serious accident is one that money won't fix.
  3. #3
    Veteran Member Kernopelli's Avatar
    Join Date
    Oct 2006
    Posts
    1,340
    Carterville, Illinois
    Mitsubishi MTE2000D, Dig It 258 Backhoe
    It appears to have all the features of a Ford Model 727. I looked online and it appears they were designed for 4000,5000 series and but I saw them mounted on everything from a 4000 to a 6600. Some of the 727 manuals on ebay have pics that appear different than yours but I found many examples of tractors for sale stating the loaders as being a 727 w/ exact same design as yours. Bottom line, it might be a little big for a 3000 but you can probably make it work.......Well, I know you can "make" it work. That may depend on how much effort you want or can put into the project. On the other hand, it may fit right on. Don't know enough about it. As far as brackets, they may be available for the 3000 but I bet you'll have to make them....and possibly modify the loader a bit. Soundguy will probably see this and chime in pretty quick and have the right answer for you.
    Darryl
  4. #4
    New Member
    Join Date
    Jun 2008
    Posts
    5
    Thanks for the info!!I'm a do it yourself guy.I was thinking it might be a little big,but I got it for$500,So I'm going to make it work.I just use the tractor mainly for mowing and move a little dirt.I really appreciate it..
  5. #5
    Super Member RickB's Avatar
    Join Date
    Sep 2000
    Posts
    6,269
    Eastern NY
    Case 885, JD 730D, Oliver 660 Ford 4000
    It is a 727. You will need to build the proper bracketry for the front mount on a 3000. 8 properly sized bolts and two plates to fit over the rear axle will take care of that end.
    If you can read this, thank a teacher.
    If you are reading this in English, thank a veteran.
  6. #6
    New Member
    Join Date
    Jun 2008
    Posts
    5
    Man thanks for the info!!I don't yet know how I'm going to do the brackets,I'm looking for pics..Thank you for protecting the USA!!
  7. #7
    Epic Contributor Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    42,133
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    torch and welder will be your friend.
    front bolster will be easy, and as rick said sandwich plates parallel over and under the the fender mount portions of the axle will get you there.. think of a 2 tined fork one tine aboe and one below the axle.
    look up superior loader and they mount that way ( as do countless others ).. i googled it and there are plenty of pics out there.
    soundguy
  8. #8
    New Member
    Join Date
    Jun 2008
    Posts
    5
    Thanks for all the help,I'm going to restore my little 3000 all the way,It's my first one..
  9. #9
    Join Date
    Mar 2002
    Posts
    42,133
    Central florida
    good deal.. you will love it. my 3000 has proved usefull
    soundguy
Similar Threads
  1. Rotary Cutter bush hog 2400 qt loader on Ford 860
    By tbutcher in forum Attachments
    Last Post: 11-06-2009, 06:10 AM
  2. Front loader - Ford I9-I18...specs and parts?
    By Specop_007 in forum Attachments
    Last Post: 08-25-2009, 12:18 PM
  3. Smoke or condensation?
    By michaelTS354 in forum Chinese Tractors
    Last Post: 01-16-2006, 03:56 PM
  4. John deere 52 loader
    By Dennisfly in forum John Deere Owning/Operating
    Last Post: 11-09-2003, 09:28 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
