Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
  1. #21
    Silver Member Tractor Beam's Avatar
    Join Date
    Feb 2010
    Posts
    151
    Default Re: Tractor Closet!
    UPDATE! Bought a new camera Cannon D1200 with some nice lenses. Here's some more photos of................................................ . TRACTOR CLOSET!!!
    Attached Thumbnails Attached Thumbnails Tractor Closet!-100_0137-jpg   Tractor Closet!-100_0138-jpg   Tractor Closet!-100_0139-jpg
  2. #22
    Member nolewatcher's Avatar
    Join Date
    Jun 2009
    Posts
    32
    North Florida
    5420 JD and 790 JD
    When I bought my JD 5420 it had a nifty toolbox mounted on the right side by the driver access step. Unfortunately, this had to go away as it was in the way for the front end loader bracket. I made a bracket and mounted it behind the driver...but it is somewhat in the way when you are backing up to a piece of equipment. It is hard to see to align the lift arms. Looks like some of your 'inventions' have that same limitations? All good ideas, though.
  3. #23
    Join Date
    Jun 2009
    Posts
    32
    North Florida
    5420 JD and 790 JD
    I put a military ammo box toolbox on the RH fender of my JD 790. It is/was perfect. But now it has shrunk. (I try to put too much in it...snicker)
  4. #24
    Join Date
    Feb 2010
    Posts
    151
    Quote Originally Posted by nolewatcher View Post
    No, mines high enough so that you can easily look under it to see all points behind you, both high and low. I also added mirrors at the corners of the canopy, not pictured, that work great too, for seeing behind you. Oh ya.... I thought of everything here!
  5. #25
    Join Date
    Feb 2010
    Posts
    151
    Hate that when that happens!
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
