From Red Neck top to Steel Top
   / From Red Neck top to Steel Top #1
Leejohn
Elite Member
Doniphan, Mo.
Kubota L4240, B7800 & BX2660
Back in June 2010 I made a rag top just to see if I would like one. Well I did and I made one.
You can see how the legs are made and how I hooked them to the tractor. Also the inside of the top.
It bolts on and if I sell the tractor I can just unbolt and put the oem rop back on.
I have 4 bolts to put on the front uprights and a cross bar goes between them just above the hood.
All the tubeing for the back, front and uprights are 1/4" wall. The 1 X 2 in the top is 3/16" wall. Top is 3/16" flat stock. The mounts at the bottom is 1/2" and 5/8".
It is heavy, so heavy I just might be able to unload my rear tires.
Lee
   / From Red Neck top to Steel Top #2
Man that looks sweet! Nice job! :thumbsup:
   / From Red Neck top to Steel Top #3
My neighbor has a GEO (I think) hood on his and it looks actually pretty good he mounted it to the roll bar just like normal and if I'm not mistaken it is Aluminum too. junk yard find for 25 bucks or so at pick-a-part.
Mark
2008 Ford F-550 4x4 Dump Truck with Lift Gate (A53422)
2008 Ford F-550...
UNUSED LANDHONOR HPF-11-3000G HYD PALLET FORKS (A54757)
UNUSED LANDHONOR...
2025 IR IRE20 Mini Excavator (A52377)
2025 IR IRE20 Mini...
2020 FREIGHTLINER M2 106 26' BOX TRUCK (A54607)
2020 FREIGHTLINER...
2000 Mercedes-Benz S-Class Sedan (A53424)
2000 Mercedes-Benz...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A53421)
2025 Kivel 48in...
