Page 1 of 3 123 LastLast
Results 1 to 10 of 23
  1. #1
    Veteran Member chad22's Avatar
    Join Date
    Nov 2010
    Posts
    1,621
    Kansas
    Sears Garden Tractor
    Default Turning an old loader bucket into a backhoe bucket?
    I was gonna buy a new bucket for my home backhoe. But then got to thinking of a new idea.
    I have an old loader bucket that was given to me in some scrap metal. I was gonna use it for the loader I was gonna make. But there's a few rusted through spots in the middle. The rest of it's okay.
    So I was thinking of marking a straight line and use my dads old circular saw with an abrasive wheel and cut it down to shorten it to make a bucket for my backhoe.
    Once shortened down. I'd weld it back together and have a recycled bucket. Total cost would be around $5.00 -$6.00.
    A new buckets almost $300.00 3 Tooth Trencher Bucket
    That's the bucket I was gonna buy until I remembered the loader bucket.
    When I start I'll take some pictures of the progress.
    Chad
  2. #2
    Gold Member NormL's Avatar
    Join Date
    May 2011
    Posts
    475
    Manitoba, Canada
    Craftsman GT18, Ford 601 / FEL, Oliver 550 / FEL
    Default Re: Turning an old loader bucket into a backhoe bucket?
    Quote Originally Posted by chad22 View Post
    I
    Chad
    How about some photos before you start.
    I miss Paul Harvey News!
  3. #3
    Gold Member
    Join Date
    Dec 2010
    Posts
    277
    Hazelridge, MB
    Kubota L1801 and Massey 65
    Good idea and the price is right.
    Can you get 2 new backhoe buckets from the 1 loader bucket?
    Maybe a smaller one will come in handy.
  4. #4
    Platinum Member High Compression's Avatar
    Join Date
    Aug 2010
    Posts
    565
    De Soto, KS
    Kubota L5740-3/ Kubota ZD21 pro60
    Might work. My concern would be the shape of the heal (back) of the bucket. If it is pretty squared off, it might not make an efficient ditching bucket. No doubt it would make an excellent grading bucket though. Post some pix so we can have a look. P.S. be careful on how hot that cutting wheel gets the bucket. It could warp it and you'll have fun welding it back together and having a straight bucket when your done.
    "It is better to be thought a fool, than to open your mouth and prove it."
  5. #5
    Join Date
    Nov 2010
    Posts
    1,621
    Kansas
    I'm not sure. But I probably could. I'll have to measure it and see what I can get out of it. I think the buckets around 3 foot long could be a little over. "Could even be under 3 foot."
    I think the buckets got a slight curve to it. The shapes I think almost like the one in this link. http://www.7zu.info/wp-content/plugi...er-bucket.jpeg
    I'll have to go out and look at it and take a picture of it after while. I guess if it doesn't work as a digging bucket. Like you said it would make an excellent grading bucket.
    And I'll keep that in mind about the heat from the cutting wheel.
    Chad
  6. #6
    Super Member JB4310's Avatar
    Join Date
    Feb 2005
    Posts
    5,645
    Central CT
    J.D. 4310 E-hydro
    It will be alot of work but could be done, gonna be slow with a circular saw though.
    I cut a bucket down with a demo saw, much easier.
    JB
    Attached Thumbnails Attached Thumbnails Turning an old loader bucket into a backhoe bucket?-dscn6013-jpg
    JD 4310; E hydro, 300CX, 48 BH, 60" box, 72" rake, 72" rear blade, cast pallet forks, 48", 61"HD & 73" high volume bucket.
    FORD 1700; 2 WD, 2600 hrs.
    JD 320; Hydra lift, 48" deck and 48" snow blade.
    2007 Dodge Ram 3500, Cummins 6.7L, Aisin 6 speed, 9ft utility body.
  7. #7
    Veteran Member deereman75's Avatar
    Join Date
    Apr 2011
    Posts
    1,754
    canada
    1946 cockshutt 60
    A Skilsaw would be very slow, I would probably use the torch, and find a way to fix the warping. (big rosebud.... sledge hammer.....)
    Never carry gasoline in your car trunk. If you do, atleast use some sort of container.
    -red green
  8. #8
    Join Date
    Nov 2010
    Posts
    1,621
    Kansas
    I lost my camera card otherwise I would of took a pic of the bucket today. I measured it though and it's 2 feet long.
    My dad has one of those demo saws and I may see if I can get the thing running. As it seems like it would make the cutting a lot easier.
    Before cutting it down I may tack weld some ears on it so I can attach it to my backhoe and see how I think it will perform as a digging bucket scooping up some loose dirt.
    If it doesn't work out like I'd hoped. I could always leave the ears on and keep it as a wide clean up bucket.
    Chad
  9. #9
    Join Date
    May 2011
    Posts
    475
    Manitoba, Canada
    Chad
    Have you checked the reader slot for the card? That's where I would leave mine and then forget where it was.
    Two feet... that's probably a little on the huge side for your hoe. With anything in it your outriggers would certainly be earning their keep! Good plan though. You should be able to get a good sense of bucket size to machine capability that way. Good luck!
  10. #10
    Join Date
    Nov 2010
    Posts
    1,621
    Kansas
    Quote Originally Posted by NormL View Post
    That's exactly where it was. I found it but now it gives me a card error.
    I posted the wrong length of the bucket. It's past 2 feet it's more like 32 inches so a bit bigger than 2 feet.
    And that rusted through spot was actually patched up. I didn't really notice it because the bucket had a bunch of rust covering the top of the patch.
    Anyway I think it's gonna make a nice backhoe bucket though. And if I figured right. I can use the rest of the steel to fix my stick mount with.
    It's a thicker steel and the loader buckets a factory made loader. I forgot to mention that the loader arms were still attached to it. So I may be able to utilize the already made loader arms on my loader. "But just shorten the width of them down a bit".
    I would have kept the bucket for the loader but also noticed a bend at the bottom in the middle.
    So decided to salvage it for a new bucket for the backhoe.
    Chad
    Edit: It's so hot out there I had left a red crayon on the ground to mark the line for the saw to follow. And when I went back out there and picked the crayon up it actually was so hot the wax burned my hand a bit.
    Last edited by chad22; 07-18-2011 at 01:36 PM. Reason: It was so hot out a crayon melted in my hand.
Similar Threads
  1. redoing old lane on the farm.
    By boggen in forum Projects
    Last Post: 06-06-2011, 11:17 PM
  2. welding chain links on bucket and loader arms
    By stevef in forum Attachments
    Last Post: 01-19-2010, 07:46 AM
  3. New L3130 with Loader and Backhoe???
    By Evaluator in forum Kubota Buying/Pricing
    Last Post: 09-24-2006, 12:23 AM
  4. Backhoe 5000 series Woods Loader & Backhoe
    By viking65 in forum Cub Cadet Tractors
    Last Post: 03-14-2005, 06:15 PM
  5. 25 Hour report B7610 TLB
    By v8dave in forum Kubota Buying/Pricing
    Last Post: 06-21-2004, 12:16 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
