BHD
built a winch, (it works fine, but have a use for it where knowing the line pull would be appreciated),
using a 50 to 1 reduction worm drive gear box,
Power is with a reversible eclectic drill only chucked to the input shaft, guessing I allow about 30 foot pounds of torque (max) on the input shaft, (holding the drill from spinning),
the drum is about 3" inside diameter, at base, and the rule of thumb is to reduce the line pull about (10%) for ever layer (depending on the number of layers),
what would be the estimated line pull, any one have the formula to figure,
what I am wanting to figure is how much drill torque is to guesstimate the line pull
Is this correct, say the 30 pounds of pull on the drill at 12" from chuck, that 30 FP x 50 reduction, would be 1500 Foot Pounds on the main shaft,, the 3" diameter would be a 1/4 of 12 inches or a foot, (translating foot pounds), so the 1500 FP x 4 would be about, 6000 pounds of pull on first layer,
(as in the picture there is a number layers on the winch, guessing there is 6" diameter so the pull as the picture is would be about 3000 pounds of pull, (not taking into account for friction and other losses.)
is that correct?
is that correct?
