Page 1 of 5 1234 ... LastLast
Results 1 to 10 of 41
  1. #1
    Join Date
    May 2011
    Posts
    82
    Colorado
    Kubota B2620
    Default 15 Gal sprayer on a 3 point?
    Has anyone built or converted a little 15 gal ATV sprayer to hook onto their tractor via 3 point or other. I have 5 acres and a small spayer I would like to use on my tractor. Just looking for some ideas.
    B
  2. #2
    Bronze Member j t huskins's Avatar
    Join Date
    Sep 2011
    Posts
    95
    Boone N.C.
    Ford 1210 4x4 With Ford Front 3 Way Snow Blade ,Newholland TC40A 4x4 With NH 16LA FEL,Kubota B7100 4x4 With Kubota FEL Project Tractor, Ford 1210 4x4 Parts Tractor.
    Default Re: 15 Gal sprayer on a 3 point?
    Haven't done it yet but that is one of my future project plans. I plan to go a little larger if I can find a good 30 gal tank to start with. It will be very easy to build a 3pt frame to carry it on. Looking for a PTO pump at a reasonable price rather than the electric that ATV sprayers use.
    NHTC40A 16LA FEL
    Ford 1210 4x4 Front Blade
    Kubota B7100 Kubota FEL
    CubCadet 1554
  3. #3
    Join Date
    Jan 2011
    Posts
    101
    massey ferguson
    nope but shouldnt be 2 hard to build a wee frame for it
  4. #4
    Join Date
    Apr 2008
    Posts
    577
    B2920 TLB turfs and loaded ags
    I thought about doing the same thing but I went with the 25 gallon unit from BXpanded. Not too much $ and its a really good design. I did not think my finished product would be comparable in design or quality.
    B2920 TLB, turfs and loaded ags, thumb, 60 & 50" QA buckets, Kubota QA forks, toothbar, BX42 chipper, 60" front hydro blade and hitch, Herd M96 spreader, turf vent 48" 3pt aerator, Woods LRC 60" rake and Woods 48" estate BB, County Line 60" rear blade, rear spacers, pats easy change. Polaris 800 w/60" Blizzard plow & John Deere 717a ZTR
  5. #5
    Epic Contributor k0ua's Avatar
    Join Date
    Jun 2009
    Posts
    28,356
    Branson, Mo.
    Kioti DK35se Hydrostat
    This is what I did, put the 15 gal on a little cart to "cart it around" and put a piece of angle iron under the card that just fits a 2 inch reciever I had in my hombuilt ballast barrel. I hooked to the aux. wires for aux rear lights that is under the fender for power. Works well.
    http://www.tractorbynet.com/forums/b...ilt-today.html
    James K0UA
    James K0UA
    Kioti DK35se hydrostat with 2 QA buckets, 48 inch. King Kutter Rotary Cutter. 750 lbs ballast box. Loaded tires, Construction Attachments SSQA Lightweight Pallet forks. EA 50 inch single lid "wicked" Grapple. Satisfied Everlast PA160 welder owner NRA Life Member How to add a link to a post . Best way to search TBN . Igitur qui desiderat pacem praeparet bellum
  6. #6
    Old Timer Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    52,748
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    sounds like a carry-all would convert it.. or would be able to be made up easilly with some angle iron, torch and welder.
    soundguy
  7. #7
    Super Star Member brin's Avatar
    Join Date
    Jul 2009
    Posts
    10,866
    Georgia - Mt. Vernon by The Store just 5 miles east and right by the big oak tree then to the creek.
    Here is what I was thinking of doing....I was thinking of using my TC-29 D and putting the 15 gallon sprayer in my FEL bucket..just setting it in there...then lift the hood and connect the jumpers to the tractor battery and then drive around an spray...I just wonder how long the hose is, I wonder if it would reach back far enough to the tractor seat..probably 6 or 7 feet...Any thoughts about my idea ? and does anyone know how long the TSC or HF 15 gallon sprayer hoses are ?
    Bob
    WORRYING does not take away tomorrow's TROUBLES, it takes away today's PEACE.
    NH - TC-29 , FEL, Bush hog, Bush hog brand finishing mower, Post hole digger, 6' Back blade, sub-soiler, Pallet forks, 20KW PTO Generator , 21 hp Murray Mower
    JD -3020 with FEL and a 16 HP. K-Grow Lawn Tractor (bought from K Mart 1994) and runs great !
    Clark 130 EN Mig Welder
  8. #8
    Join Date
    May 2011
    Posts
    82
    Colorado
    Kubota B2620
    I thought about doing the same thing as you with putting it in the bucket. I just didnt feel like having chemicals spray back as I was driving around all over my
    Tractor. I also feel like having it on the back would make it very easy to see. Im thinking I will just build a simple carry all. and mount it on the three point. I like having it on the three point because I can get the spray nozzles as close to the ground as I want.
    B
  9. #9
    Super Member dodge man's Avatar
    Join Date
    Oct 2008
    Posts
    5,288
    West central Illinois
    Kubota BX2350
    I just use some bungess and kind of strap it to the 3 points arms. To be honest its a crappy setup, but its easy. The only real problem is that some times it gets a little twisted, so it won't pick up the last half gallon or so of material.
    Dave,
    BX2350
  10. #10
    Join Date
    Jul 2009
    Posts
    10,866
    Quote Originally Posted by Jbbies View Post
    B
    I don't see how chemicals would spray back....because you or I would be holding the hose and sprayer in our hand and why would it matter if the tank was in the front in the bucket or in the back on the 3 pt. ? the tank is sealed ..it has a cap...Am I missing something...?
    Bob
Similar Threads
  1. Do I need a 3 point quick hitch?
    By PapaPerk in forum Attachments
    Last Post: 08-26-2017, 07:07 PM
  2. 3-Point Hitch Newbie Question on 3 Point w/ post hole digger
    By BoomerBaby in forum New Holland Owning/Operating
    Last Post: 10-10-2016, 11:51 PM
  3. 3 point sprayer for vines
    By GeorgeBranch in forum New Member Introductions
    Last Post: 04-22-2010, 11:00 AM
  4. Sprayer Yard Sprayer Questions
    By robertm in forum Attachments
    Last Post: 06-12-2009, 11:01 AM
  5. Buy or build 15 gal spot sprayer?
    By sixdogs in forum Build-It Yourself
    Last Post: 03-14-2008, 07:44 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
