Why didn't I build a toothbar sooner? They're GREAT!
   / Why didn't I build a toothbar sooner? They're GREAT! #1
petes
Bellingham, Washington
Kubota B8200 (21hp) , IH B275 (28hp), JD 1830 (68hp)
2 horses and a big yard at our new house makes for a mountain-sized compost pile. I've been turning it with my Kubota B7100 FEL, but had trouble getting a proper bucketfull - the stringy stuff would sometimes roll out when I lifted, and driving into the pile to fill the bucket packed the compost, so when I dumped it sometimes came out as a large wet brick.... the answer was to build a toothbar. I had enough scraps around that it cost nothing except welding wire, gas and electricty.
Had about 3 hours into fabrication (love that plasma cutter!) and am pleased with how it turned out and works. I wanted to be able to scrape the concrete slab clean with the toothbar mounted, so the design is such that the teeth don't hang below the cutting edge that's integral into the toothbar.
It made it MUCH easier to load a full bucketful (or at least as much as the FEL will lift), and I can jiggle the bucket while dumping causing the load to sift through the teeth which breaks up the clumps and results in a much less compacted pile.
   / Why didn't I build a toothbar sooner? They're GREAT! #2
Very nice job Pete.
Wait till you take it out into real type dirt. Tooth bars really shine out there.
   / Why didn't I build a toothbar sooner? They're GREAT! #3
I get it now! When I think about all the trouble I've had trying to dig out sod, only to have it spill back out of the bucket when I went to lift it... I see that it didn't have to be that way. :thumbsup:
   / Why didn't I build a toothbar sooner? They're GREAT! #4
Do you have it welded to the bucket itself ?
   / Why didn't I build a toothbar sooner? They're GREAT! #6
That's a nice piece of work right there. :thumbsup:
   / Why didn't I build a toothbar sooner? They're GREAT! #7
I looked at the finished product, and I was curious if those tubes were solid, but now I see. How thick are the tubing walls.
Thanks all. I used what I had. Tubing was 1.5 square x .180 wall. I welded on 5/16 thick rectangles to cap the ends.
The whole things slips over the FEL bucket cutting edge then pins to the sides of the bucket with 1/2" bolts. My loader is only rated 500lbs lift, so it was a bit of a balance between making it stout but not too heavy.
Angle was 3x3x1/4. I boxed (triangled?) the bottom with 5/16 T1 plate. I probably should have made the cutting edge out of hardened steel instead of using the front of the angle iron, but this was a quick-n-dirty project and that piece of T1 was already just the right size for where it ended up. If it'd been 1-1/2" wider it would have protruded enough in front of the angle to be the cutting edge... ah well, if it ever wears out I'll figure out how to improve it, or just make another one!
I'm curious how it'll work grubbing out blackberries and grass clumps. I suspect I'll reach the lift limits of my loader frustratingly often. (right now I've got a perfect balance between loader lift capability and boxblade counterweight... if I can't pick it up it would have tipped me over anyway. ;) If I load the rear more and increase hyraulic pressure I'm sure I'll start to bend/break other things... maybe I need a bigger tractor!
   / Why didn't I build a toothbar sooner? They're GREAT! #9
Nice job Pete...
I want to do that myself...
What size plasma cutter did you get?
Kinkaid 1200 LS-PH Towable Hydroseeder (A51691)
Kinkaid 1200 LS-PH...
NEW Woods Reverse Rotation 5ft Tiller (A52748)
NEW Woods Reverse...
2009 IC Corporation PB105 Passenger Bus (A51692)
2009 IC...
2015 Eager Beaver 15HBB-PT T/A Flatbed Equipment Trailer (A50322)
2015 Eager Beaver...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52748)
80in HD Tooth...
(1) 12ft Tarter Gate (A51573)
(1) 12ft Tarter...
