BX25 GrappleOmatic
   / BX25 GrappleOmatic #1
Artisan
Monrovia, California
Kubota BX25
Santa brought me a FEL grapple. Anyone seeing me doing anything wrong here, or shall I carry on? The tips of the grapple just barely touch the front edge of the toothbar, not the teeth, the horizontal bar that lays parrallel w/ the bucket, left/right. You can see the business end, the grapple itself in the background in top pic.
   / BX25 GrappleOmatic #2
Looks good so far. Can't wait to see the finished project!:thumbsup:
Joe
   / BX25 GrappleOmatic #4
You are doing a nice job. How much does all that weigh?
Weight? I am probably loosing a good 100 pounds off my capacity (when it is on)but I don't care much, just a couple more trips if I am moving material, I want the vesatility. The grapple mount to the bucket is just a piece of 3.5 x 3.5 x .250 Structural angle, it weighs maybe 15# ? Somewhere close, everything else strips off if I wish. The grapple forks are going to be quick release, just 2 cylinder pins w/ clips like a class 2 trailer hitch and the hoses are going to be QD's (Quick Disconnects) so if I want, I am almost back to stock, again, that versatility I seek. Perhaps it will be powered with THIS. (Scroll to bottom, look at 700-5032-4080 )
   / BX25 GrappleOmatic #6
Looks good. I have a friend that is just itching to do some fabrication for me and this is a project I want to do as well. First he is going to build a set of debris forks to bolt onto the bucket. Following that will be the grapple. As for myself I think I want the grapple to extend out beyond the bucket but not beyond the debris forks.
Anyone have a grapple that would offer an opinion?
Campbell I have been chewing on this very thing, that is the length of the grapple in relation to the bucket. I had Santa get me the smallest one for weight issues, and should I feel I want it longer, it will be a small task to weld on some extensions, maybe some extensions w/ a certain "cool" factor to them.
I to would like an opinion from someone who has a grapple as well.
Albeit I am not a class act when it comes to fabricating, I am however testiment to the fact that one needs to BUY A WELDER and START WELDING to learn. Some basic tools, a grinder and drill press and a saw and your going to be making stuff you see others make. I say this because lately it seems I have been reading a lot of guys proclaiming no welding skills, like I used too, till I maned up and bought a used inexpensive welder. Now look! HA! I make all kinds of stuff! Bird Turd welds and All! But it works and I didn't pay the man to do it for me. Little by little, my welds improve... :thumbsup:
Anywho, the GrappleOmatic continues.
Below is a reveal for the cylinder reinforcement plate OE on the bucket.
Below is a reveal for the OE welds on the bucket at the top so angle iron sits flush to top edge of bucket.
I had to know so before I weld it up I dragged the scales out there and weighed it ALL.
The 3.5 x 3.5 x .250 Angle Iron w/ 4-5/8 x 2" bolts including nuts and washers, the lower grapple mount, and the top cylinder pin weight 47 pounds.
The cylinder and the 2 pins to afix the grapple forks to the grapple mount weigh 15 pounds.
The grapple forks and the cylinder pin weigh 36 pounds.
The welds will prob weigh 2 pounds.
47
15
36
02
___
100 pounds on the nose! HA! Now I didn't add the 2 pounds for welds to make it weigh 100 pounds, I did all my calcs then totaled it. So this set up on a BX25 weighs almost exacly 100 pounds.
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
ELECTRIC GOLF CART (A58216)
2011 NORAM POWER SYSTEMS 100KW GENERATOR (A58214)
2011 NORAM POWER...
2013 Komatsu WA470 Wheel Loader (A59213)
2013 Komatsu WA470...
1653 (A58375)
1653 (A58375)
1191 (A56859)
1191 (A56859)
