Page 2 of 11 FirstFirst 12345 ... LastLast
Results 11 to 20 of 110
  1. #11
    Elite Member Chilly807's Avatar
    Join Date
    Sep 2009
    Posts
    3,258
    Nova Scotia
    Kubota L3400DT
    Default Re: Hydraulic Auger Mount
    I made a bucket mount for skid shoes (snow removal) a couple of years ago, I drilled through the reinforced bucket bottom and filed the holes square to use carriage bolts. Plow bolts would work well, but is there really anything to gain by having a truly flush surface?
    It's late in the game to make this suggestion, but it would have been nice to be able to simply add a couple of low profile rails on the side of the bucket to slide the new hanger bracket into. If it had been done that way, you would have been able to simply slide the bracket in place and lock it with a single small bolt. The rails wouldn't impede using the bucket normally, and you could have either welded or bolted them in place.
    The more bolts you add the more of a PITA it's going to be to put it on and take it off, so you'll try to avoid using it. That's been my experience, anyway.
    I take it you're going to use the bucket curl hoses to run the auger?
    Sean
  2. #12
    Super Member bindian's Avatar
    Join Date
    Feb 2007
    Posts
    6,972
    Willis, Texas
    Mahindra 6520 4WD
    Quote Originally Posted by Chilly807 View Post
    Sean
    Sean,
    No, I want to keep curl function. I will run it to the second remote.
    hugs, Brandi
  3. #13
    Join Date
    Feb 2007
    Posts
    6,972
    Willis, Texas
    Mahindra 6520 4WD
    I bought the grade 8 hardware today at Lowes. TSC was out of all 1/2 inch bolts. I now realize that the welder did weld it up with the washer in. The fit problem comes from a very basic no-no from welding 101............Use equal heat on both sides of a flange. As it is, the flange leans in on the forward end. After drilling the bolt holes out to 1/2 inch, I took it all apart and put half of the hole of the forward flange on the bench grinder. Now it falls apart when I pull the pin. All this drilling went quick with my 18 volt Makita cordless drill and a good bit that was continually dipped in Boelube.
    Saturday I will mount the motor and gearbox on the mounts.
    hugs, Brandi
    Attached Thumbnails Attached Thumbnails Hydraulic Auger Mount-1-4-12-auger-mount   Hydraulic Auger Mount-1-4-12-auger-mount
  4. #14
    Join Date
    Jan 2006
    Posts
    963
    West Central Idaho
    Kubota L5740HSTC3; B3000HSDCC
    Default
    Ma'am,
    What is your overall impression of the Danuser product? I am planning on a future hydro auger purchase and I am looking at several products to include Danuser and McMillen (Everything Attachments) so user feedback is important to me.
    Thank you.
  5. #15
    Join Date
    Feb 2007
    Posts
    6,972
    Willis, Texas
    Mahindra 6520 4WD
    Quote Originally Posted by RFB View Post
    Ma'am,
    Thank you.
    RFB,
    I think it is well worth the money. Especially over PTO augers. Buy the longest extension you can buy with it to get 4 feet depth. I bought a 12 inch extension and have to dig down for motor clearance to hit four feet.
    More importantly, I made a phone call to Danuser and Steve (or Glenn, can't remember first name) Danuser ansnwered my questions.
    hugs, Brandi
    Attached Thumbnails Attached Thumbnails Hydraulic Auger Mount-4-22-11-augering-new
  6. #16
    Super Member woodlandfarms's Avatar
    Join Date
    Jul 2006
    Posts
    5,595
    Los Angeles / SW Washington
    PowerTrac 1850, Kubota RTV x900
    I built my own hydraulic auger. Came in with a hd bit at just under 1k.
    Power-Trac 1850, grapple, hoe, 90" mower, 72" box blade
  7. #17
    Join Date
    Feb 2007
    Posts
    6,972
    Willis, Texas
    Mahindra 6520 4WD
    Quote Originally Posted by woodlandfarms View Post
    That is an good price and you had the satisfaction of building it. In 2007, the auger motor was $1446. The 9 inch bit was $206 and the 12 inch bit was $242. The 14 inch extension was $103. One of my (slow boat) projects is to make another extension. I will have to find some drill stem for a coupling. The solid round stock for the shaft is only around $25. Problem is finding the right size thick wall coupling. But then again, I only looked at the local mill supply. I might buy some solid round stock the diameter of the coupling and have it machined. That might turn out to be the easiest.
    hugs, Brandi
  8. #18
    Join Date
    Feb 2007
    Posts
    6,972
    Willis, Texas
    Mahindra 6520 4WD
    I got the auger motor assembly installed today and measured for 3/8 inch lines to the remote. I will need 16 feet x 2. First photo is the view from the seat. The 2nd and 3rd photos show overall installation, while the last photo shows a good close up of the bracket profiles. This rig definitely needs a cradle on wheels. So I will be designing and building a cradle for the auger/motor assy. with the extension installed.
    hugs, Brandi
    Attached Thumbnails Attached Thumbnails Hydraulic Auger Mount-1-7-12-auger-seat   Hydraulic Auger Mount-1-7-12-auger-installed   Hydraulic Auger Mount-1-7-12-auger-fel   Hydraulic Auger Mount-1-7-12-auger-fel
  9. #19
    Platinum Member JohninCT's Avatar
    Join Date
    Jul 2001
    Posts
    984
    Central CT
    Struck Magnatrac 6000, Kioti DK40SE
    Default
    Nice job Brandi. That hyd digger sure is sweet.
    "I don't do landscaping... I do battle with vegetation"
  10. #20
    Elite Member
    Join Date
    Aug 2011
    Posts
    2,687
    Earth
    Deere
    Default
    That will be doing some fast drilling! Wish I'd thought of that 8 years ago when I put in a fence.
Similar Threads
  1. Backhoe JD 110 Tractor Loader Backhoe
    By bushytlb in forum John Deere Owning/Operating
    Last Post: 01-17-2016, 02:03 PM
  2. Hydraulic Filter Mount
    By city_boy_done_good in forum Parts/Repairs
    Last Post: 12-11-2011, 06:50 AM
  3. Hydraulic Post Hole Auger bad for Kubota?
    By ultrarunner in forum Kubota Owning/Operating
    Last Post: 06-28-2009, 12:10 PM
  4. Hydraulic Auger for L48
    By rcspott in forum Kubota Owning/Operating
    Last Post: 04-24-2006, 02:38 PM
  5. Hydraulic remotes vs hydraulic PTO?
    By davesisk in forum Hydraulics
    Last Post: 10-23-2002, 08:35 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
