Page 3 of 11 FirstFirst 123456 ... LastLast
Results 21 to 30 of 110
  1. #21
    Super Member bindian's Avatar
    Join Date
    Feb 2007
    Posts
    6,955
    Willis, Texas
    Mahindra 6520 4WD
    Default Re: Hydraulic Auger Mount
    JohninCT,
    Thanks. The auger is really an elbow saver.
    Martian,
    Thanks. Do you have a hyd. auger? I got the idea from skid steer loaders having it right off of the quick attachment. But, on a tractor, off to the side gives you a good view of the ground contact point.
    hugs, Brandi
  2. #22
    Elite Member
    Join Date
    Aug 2011
    Posts
    2,687
    Earth
    Deere
    Default
    No, just have a ~20 year old 3pt set up. Could dig the hole with a shovel faster but I guess it's better than being dead from the digging. It's set out in the fence line the last 8 years, so next time I need one I'll be getting something new, whether it be a hydraulic like yours or a newer 3pt is tbd. I really like that set up though
  3. #23
    Join Date
    Feb 2007
    Posts
    6,955
    Willis, Texas
    Mahindra 6520 4WD
    Quote Originally Posted by Martian View Post
    Martian,
    I rented a 3PH auger with a dull cutting edge before. That and me having elbow surgery said to get the hydraulic auger. Just made sense...and no aches and pains.
    Now with it ready for the FEL, I won't need to pull a bucket and thumb off before mounting it.
    hugs, Brandi
  4. #24
    Super Star Member
    Join Date
    Feb 2008
    Posts
    12,424
    somewhere usa
    Deere 110tlb, 4520, x749, L130
    Bindian,
    I will be interested in how this works for you and it looks like a good setup.
    I built an adaptor for Curly Dave to use his hydraulic auger on his 110tlb but haven't been able to come up with a good yoke design. The adaptor that I built is almost a carbon copy of the Frontier adaptor but the yoke on Dave's planetary head requires different dimensions. Sure would like to resolve this.
    Here are a couple of pics of the build I did. Notice the cradle leans back and away from the drive when it is hanging plumb. You can build or add this so that when you curl the bucket it cradles the auger.
  5. #25
    Elite Member Chilly807's Avatar
    Join Date
    Sep 2009
    Posts
    3,258
    Nova Scotia
    Kubota L3400DT
    Quote Originally Posted by bindian View Post
    hugs, Brandi
    I noticed that, on your first picture. You'll have a good view of exactly where the point is starting to dig.
    The only problem I see with the side mount, and I'm not sure how valid the concern is, is that you might be able to twist the loader arms if the auger bites hard under a rock or tree root. The trouble with mounting it on the center line of the bucket is the hood obscuring your view of the auger.
    I doubt it'll pull hard enough to twist the loader permanently unless you held the valve open and let it pull the end of the bucket down. One way to reduce the risk is to adjust the remote pressure relief to a low enough value that it will stall the auger before it can damage the loader. You could set it quite low to begin with and see how well it digs, if it's too lazy simply increase the pressure setting until it works well.
    Nice job overall, it makes me wish I'd gone that way too. I found an older kubota-branded 3 point auger instead. I have my fence built now, so most of my use will be simple repair and reboring existing holes.
    Sean
  6. #26
    Silver Member crackerjack222's Avatar
    Join Date
    Sep 2011
    Posts
    233
    4430, Ford 7000, MF235
    I bought a Lowe's hydraulic auger at an auction. It came with skid-steer mount which we used with my brothers' machine. I only have a green tractor with FEL so I built an adapter to mount the auger on my FEL. As soon as I did this I began seeing everyone else going to the hydraulic post drivers. Now I am having buyer's remorse. The post drivers look so much better.
    ]SOUTH TX, JD 4430, Ford 7000, MF 235, JD 555 JD 310G
  7. #27
    Join Date
    Feb 2007
    Posts
    6,955
    Willis, Texas
    Mahindra 6520 4WD
    Quote Originally Posted by jenkinsph View Post
    Bindian,
    Jenkinsph,
    Can you post a photo with the auger on the cradle? I don't understand the design problem for the yoke?
    hugs, Brandi
  8. #28
    Join Date
    Feb 2007
    Posts
    6,955
    Willis, Texas
    Mahindra 6520 4WD
    Quote Originally Posted by Chilly807 View Post
    Sean
    I'll take my changes, since Danuser has a mount for sale for the side of the bucket.
    Glenn Danuser did suggest to watch the paint on the mount for cracking or distortion.
    hugs, Brandi
  9. #29
    Join Date
    Feb 2007
    Posts
    6,955
    Willis, Texas
    Mahindra 6520 4WD
    Quote Originally Posted by crackerjack222 View Post
    Crackerjack222,
    Hydraulic post drivers are a kick in the pants. However, hyd. augers have more uses. What gpm flow is your Lowe's auger
    hugs, Brandi
  10. #30
    Super Star Member
    Join Date
    Feb 2008
    Posts
    12,424
    somewhere usa
    Jenkinsph,
    hugs, Brandi
    About the yoke, guress I need to make one similar to yours, if you look at mine in the above pics it is about the same size top and bottom whereas your is much wider on the planetary end.
Similar Threads
  1. Backhoe JD 110 Tractor Loader Backhoe
    By bushytlb in forum John Deere Owning/Operating
    Last Post: 01-17-2016, 03:03 PM
  2. Hydraulic Filter Mount
    By city_boy_done_good in forum Parts/Repairs
    Last Post: 12-11-2011, 07:50 AM
  3. Hydraulic Post Hole Auger bad for Kubota?
    By ultrarunner in forum Kubota Owning/Operating
    Last Post: 06-28-2009, 01:10 PM
  4. Hydraulic Auger for L48
    By rcspott in forum Kubota Owning/Operating
    Last Post: 04-24-2006, 03:38 PM
  5. Hydraulic remotes vs hydraulic PTO?
    By davesisk in forum Hydraulics
    Last Post: 10-23-2002, 09:35 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
