Artisan
I ran into this thread last night late, woke up to it on my monitor this morning...I am glad it is still here. . .
Brandi that valve you bought from Surplus, that is how I found this thread in a search,
I thought Surplus had discontinued that valve. Well, I know they discontinued one
VERY similar, maybe the flow rate was a tad less, now here it is again. Anyways I have a grapple
project I am wanting to power and that valve is a candidate. I would love to
see your mounting of it when it is finished.
In my travels looking for a valve because Surplus had discontinued it,
I landed on the Fasse site. They have an ergonimic handle w/ push button
that is beautiful, I only wish I had found this thread sooner for you.
It really looks nice and I bet it is a pleasure to hold on to and control.
They have a couple of other options as well, a push button that attaches
to the shaft, and a joystick I thunk.
This valve is available in a 30gpm as well.
A PHD hung from the front would be a dream to use. Others have suggested possible issues
bending the FEL arms and rightfully so. Boy if you decide to pull up while turning and if that
bit decides to grab a stuck rock at the same time you could generate enough force to bend
your tractor, IMO. I might suggest you do something to counterweight the FEL on the other side.
How about perhaps you calculate what the Auger and bit weigh, then simply add that much
weight to the extreme other end of the FEL bucket?
I really think it will help a lot. Your call.
I have been building a grapple for my BX25 and I welded a piece of angle to
my bucket and attached the grapples mount. I have not mounted the grapple yet
because I have been utilizing that grapple mount for other things I have dreamed up!
I learned from this thread that I could use the center cylinder mount for the grapple,
to make a holder for a PHD, on center of the bucket! Your side attach has a lot of merit,
as well, if one imagines all the moves running along a fence line it could be a real timesaver.
