Page 2 of 6 FirstFirst 12345 ... LastLast
Results 11 to 20 of 51
  1. #11
    Platinum Member mpham's Avatar
    Join Date
    Oct 2011
    Posts
    615
    Massachusetts
    Kubota B 2650 cab
    Default Re: Ideas needed to turn snow blower chute
    http://www.tractorbynet.com/forums/s...e-control.html
    I did mine a little different. Winch and spring. Check out the thread and movie.
    Phil. from Mass.
  2. #12
    Gold Member rgs03833's Avatar
    Join Date
    Dec 2011
    Posts
    252
    Haverhill, MA
    MTD 660, 690 - John Deere 60, 70, 108, 2 of 111, 111h, STX38
    Quote Originally Posted by PACountryGuy View Post
    My 57-inch, rear-mounted snow blower has a crank to change direction of the chute. I would like to turn it remotely.
    Can anybody show me a picture of how you did it? It seems easy, but my head is not working this week.
    I think you would like this one
    [ame=http://www.youtube.com/watch?v=mdoP9uutw8g&feature=endscreen&NR=1]Ingersoll Garden Tractor SB48 Snowblower with electric R/L chute motor - YouTube[/ame]
  3. #13
    Member
    Join Date
    May 2007
    Posts
    40
    Northwest Pennsylvania, USA
    Kubota
    That is nice. What kind of motor is it?
  4. #14
    Super Member
    Join Date
    Aug 2004
    Posts
    6,753
    North of Mtl,Que,Can (Ste Adele)
    MT180D
    For my 2 cents the most cost effective is to use a 'el cheepo' 2000 lb ATV winch as found on EBay and many other sources.
    Generally in the $50. is range.
    You mount it vertically on the blower frame, shorten the cable to allow some 8 or so turns on the winch and one complete turn around the snow chute (much like the hand crank version).
    The major challenge is to modify the cable attachment on the winch so that the shortened cable is attached centered on the winch drum, doable but can be a challenge to some.
    Those winch kits even include a reversing switch!
    On mine I drilled and fed the cable and then drove in a wedge.
    Have fun and good luck.
  5. #15
    Veteran Member chopped's Avatar
    Join Date
    Dec 2008
    Posts
    1,871
    New England yankeee
    To me it looks like a wiper motor or a door window motor, use a wiper motor and set up similiar and it moves slower so I suspect due to the speed that its a window motor.
    But the OP of the VIDEO will tell us i hope.
  6. #16
    Gold Member SensibleNick's Avatar
    Join Date
    Feb 2010
    Posts
    446
    Ystad, Sweden
    Foton FT254
    Quote Originally Posted by chopped View Post
    -The following is Taken from the video description on youtube
    It is from a car power window motor. There have been others with Case and Ingersoll snowblowers who have used the same type of motor for many years and have been pleased with the performance. I hope to say the same...
    4 Acres, an 1890 Farmhouse and a Foton 254 + bits
  7. #17
    Join Date
    Dec 2011
    Posts
    252
    Haverhill, MA
    This might give you some more ideas
    [ame=http://www.youtube.com/watch?v=Z4ay7mSK2J8&feature=endscreen&NR=1]new power chute - YouTube[/ame]
  8. #18
    Platinum Member mwb's Avatar
    Join Date
    Feb 2008
    Posts
    627
    Ottawa Ont Canada
    3940HST Montana
    Do you have rear hydraulics? If you do then I would suggest using a hydraulic motor. I put a high torque - low speed motor on mine. I connected the motor to the existing handle shaft with a piece of 1" hydraulic hose pushed onto the motor shaft - this creates a nice torque limiter so I don't rip it apart.
  9. #19
    Elite Member
    Join Date
    Nov 2005
    Posts
    3,129
    Huhh ?
    How "remotely" ?
    I assume you will be ON the tractor at the time, or do you want to control that "remotely" as well ?
    That can be done too, mount a web cam on a dummy in the driver's seat, etc.
  10. #20
    Member
    Join Date
    May 2007
    Posts
    40
    Kubota
    I don't have any spare hydraulics on my B2710 kubota. That would be too easy.
    But, geez, you guys are coming up with some good ideas.
Similar Threads
  1. Snowblower dealers in MA?
    By 149owner in forum Kubota Owning/Operating
    Last Post: 09-27-2013, 07:23 PM
  2. Chute deflector operator for snow blower
    By trrjohn in forum Build-It Yourself
    Last Post: 11-01-2010, 04:16 PM
  3. Snow Deere 47 snow blower
    By welcomematt in forum John Deere Owning/Operating
    Last Post: 12-25-2009, 10:00 AM
  4. Kubota Snow Blower chute Controls
    By AKKubota in forum Kubota Buying/Pricing
    Last Post: 02-17-2008, 04:39 PM
  5. Replies: 2
    Last Post: 09-25-2005, 09:17 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
