Page 5 of 6 FirstFirst ... 23456 LastLast
Results 41 to 50 of 51
  1. #41
    Gold Member
    Join Date
    Jun 2010
    Posts
    277
    Western NY
    BX24
    Default Re: Ideas needed to turn snow blower chute
    That's a lot of current to run directly through a switch. Using relays is often a better method, & gives you more flexibility in wiring & switch options.
    SPDT Relay Wiring Diagrams - Electric Windows
  2. #42
    Gold Member JBourquin's Avatar
    Join Date
    Jan 2013
    Posts
    282
    New York
    MF 1529L
    Seeing that diagram actually makes it very easy to understand. Thanks.
  3. #43
    Platinum Member Mendonsy's Avatar
    Join Date
    Nov 2012
    Posts
    896
    Mendon, NY
    Kubota B7500HST
    Make sure that the switch you select has enough current rating to handle the motor load.
    If your motor is only 10 amps then most of them will work but a bigger motor requires something more substantial.
  4. #44
    Gold Member
    Join Date
    Jun 2010
    Posts
    277
    Western NY
    BX24
    Motor loads are hard on switch contacts. Motor start-up load causes very large current surges of about 3 to 8 times the running current, even more if the chute becomes frozen to the blower housing.
  5. #45
    Silver Member wotalota's Avatar
    Join Date
    Mar 2007
    Posts
    105
    Southwest NH
    BX24
    I got a used Puma this year with a hand crank and a fixed position bolted top flap. After seeing this thread just had to copy theses ideas. Used a Superwinch 3000 from Amazon $114 that includes the remote switch already wired up. The actuator for the flap was from speedwaymotors.com $99. Used a separate battery with fuses sitting on the blower. Tried the spring method first but not strong enough to reliably rotate the chute. Covered things up with a couple of storage containers that make it easier to clean off the snow without disturbing the connections. It really helps to keep at least some of the snow off you when it is windy.Ideas needed to turn snow blower chute-img_0515-jpgIdeas needed to turn snow blower chute-img_0514-jpgIdeas needed to turn snow blower chute-img_0513-jpg
  6. #46
    Elite Member GPintheMitten's Avatar
    Join Date
    Sep 2009
    Posts
    3,337
    Flushing, Michigan
    Kubota B2620 with BH65 backhoe, Ford 2N
    Quote Originally Posted by Mendonsy View Post
    Regarding relays, switches and such, this is a very small motor, just used to raise and lower a window on a mini-van. I put a 10amp fuse on the line from the battery and added a 2 amp fuse downline near the motor. I haven't had any problems except for when I inadvertanly let the motor try to spin past the chute stops, then the 2 amp fuse performed its function.
  7. #47
    Join Date
    Nov 2012
    Posts
    896
    Mendon, NY
    Kubota B7500HST
    I added a new part to my chute rotator today. The rotate switch that came with my winch was nearly impossible to operate with gloves on. I found these joysticks on All Electronics website for $15 each. They are heavy duty four way joysticks with a 5 amp contact rating. Now the rotate operation is really easy!!
  8. #48
    Join Date
    Apr 2011
    Posts
    743
    Jackson, NY
    none
    could you post the website where you got these joysticks? I have been looking for something similar for a while that was affordable.
    thanks,
    dave
  9. #49
    Join Date
    Nov 2012
    Posts
    896
    Mendon, NY
    Kubota B7500HST
    Quote Originally Posted by davedj1 View Post
    thanks,
    dave
    Sure!! Here's a link to the page.
    JOYSTICK | AllElectronics.com
    The joystick comes with four standard snap action micro switches rated at 5 amps. If you need more current they can easily be replaced with a higher rated switch. I have seen them rated up to 25 amps in the same package design.
    It is also possible to add four more switches to that joystick if you need more contacts.
  10. #50
    Join Date
    Jul 2011
    Posts
    92
    Albert County, NB Canada
    135 MF, 7010 LS, 510B John Deere Backhoe, 660 Grizzley, 70 hp Speed Boat
    I just built one about a month ago. About the same idea but I used a couple small pullys. Drilling holes and welding up a bracket took the longest time.
    Ideas needed to turn snow blower chute-chute-cylinder-jpg
Similar Threads
  1. Snowblower dealers in MA?
    By 149owner in forum Kubota Owning/Operating
    Last Post: 09-27-2013, 07:23 PM
  2. Chute deflector operator for snow blower
    By trrjohn in forum Build-It Yourself
    Last Post: 11-01-2010, 04:16 PM
  3. Snow Deere 47 snow blower
    By welcomematt in forum John Deere Owning/Operating
    Last Post: 12-25-2009, 10:00 AM
  4. Kubota Snow Blower chute Controls
    By AKKubota in forum Kubota Buying/Pricing
    Last Post: 02-17-2008, 04:39 PM
  5. Replies: 2
    Last Post: 09-25-2005, 09:17 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
