Corel is a PITA but I started with it at 2.0 . Just remember to convert to curves prior to export to vectorization and you should be good.
I am enjoying your posts. No doubt that you are a machinist.
I just noticed this thread. WOW! The best part about this will be the life-long lesson you will have taught your son. From watching and helping my dad around the farm, I learned that with enough time and money, I can figure out how to fix or build just about anything. I decided to become a teacher so I could try to pass this on to any student that will listen. It is unfortunate, but father/son projects are extremely rare these days. When I get to talking with my students about tools and projects, 90% of the time the students mention their grandparents first. I can only assume this is because these skills are not being passed down. Way to go man!
Considering the meticulous attention to detail and heavy-duty nature of this project, I have to ask: What's the deal with that engine? Are you planning for such deep gear reduction that a larger engine would not be needed? I think a 3 cyl diesel would be really nice on there :thumbsup:
Geez.. don't give him ideas. He changes it enough as it is... lol
Weird part is....I'm not. But I like the challenge and I like to learn.
So I'm not wasting anytime on the new sprockets.
Had to finish machine the bore. The sprocket will rest on that instead of relying on the bolts. This will keep it centered and transfer the weight directly to the spindle of the motor.
Then drilled the 5 bolt pattern
Now I have to mount the rotary table and machine a 1/8" recess to clear the hub flange. Need to do this because of stack up issues. Hard to explain. Remember, I got these hubs from the old transmission. So I had to work with what I got. And I also need to cut a chamfer to clear the weld between the hub and the hub flange.
Here is a close up of the cut.
That's from a plasma cutter.
