Page 5 of 30 FirstFirst ... 234567815 ... LastLast
Results 41 to 50 of 293
  1. #41
    Veteran Member ericher69's Avatar
    Join Date
    Aug 2008
    Posts
    1,670
    Ontario Canada
    2008 Kubota b2920
    Default
    Is that seat going to be suspended? Springs or only the inherent cushioning in the foam?
    Looks great!
    ericher69
    IAFF Local 849
  2. #42
    Join Date
    Jan 2012
    Posts
    66
    Default Re: Scale Cat Twenty Two Dozer Ride On For My Son
    Quote Originally Posted by ericher69 View Post
    Nope, just 2" of foam.
    I originally bought pulleys for flat belts (since I needed them to ride on the backside of the v-belt). They were a little wide and they are crowned in the center. So they didn't quite work how I wanted. So I had to make my own. Out of some scrap of course.
    Started on the fuel tank. It's shorter than I want. Oh well. I'll sleep on it before I work on it any further.
    And got the handles tack welded.
    There really is a lot of crap in a small space.
  3. #43
    Join Date
    Jan 2012
    Posts
    66
    I've been playing around with sheet metal lately. Way back, I first showed a trial of the fuel/oil tank. It was too straight. I wanted the top to have a little crown to it. Then the second tank I made, it was too short. I can't help it. I'm picky and I want things a certain way.
    So this time, I used a digital angle finder and a little gauge. So I'd bend the center to 7 degrees then the outer edges (using the gauge to get the distance from the center even) to 68 degrees. If you notice that doesn't add up, it's because when I put the piece on the table between two clamped pieces of steel spaced 16 inches apart, I get a real nice, and consistent crown. It worked really well.
    Here is the fuel/oil tank with one end welded on as well as the front grill surround.
    When I laid them on top of each other, they matched up perfectly. I was very happy with they way they turned out this time. And when I mean this time, it wasn't without some failures before I used the angle finder and gauge. Good thing I have a bunch of scrap panels.
    However, the next problem I ran into was the hood. I'm using 14 gauge sheet. It was free and nice and heavy duty. The tank was 7 inches wide and the grill is 4 inches wide. It bent fine. The hood....it's 19 inches long. And my bender just wasn't having any of that. I tried a few different things and it just wasn't working. And even if I got the bends, I still probably wouldn't be able to bow it to get that nice crown. I think I'm going to have to try something thinner. I'll go to Menards tomorrow to see if I can find a decent sheet of 18 gauge that I can try out.
    As for the sprockets and idler wheels, I'm still waiting on the guy that's going to burn them out. He ordered a hi-def plasma cutter for his shop back in January. It's been delayed a few times but it's supposed to be in by June. I want it to be a nice cut and supposedly hi-def plasma cutters are close to laser. So I'm on hold until then.
  4. #44
    Super Member mjncad's Avatar
    Join Date
    Aug 2006
    Posts
    5,114
    In the civilized First World
    A couple
    Great looking sheet metal work, and your redneck bender did a dam good job.
    Where did you get the digital angle gauge?
    Paraphrasing Douglas Adams - So long and thanks for all the bacon.
  5. #45
    Elite Member Redneck in training's Avatar
    Join Date
    Nov 2008
    Posts
    4,192
    South Central Iowa
    TYM 330 HST with FEL
    Show us your shop too. Here is an idea for your tracks made of radial tire with cut off sides.
    Attached Thumbnails Attached Thumbnails Scale Cat Twenty Two Dozer Ride On For My Son-big-gusenici08-1-jpg
  6. #46
    Silver Member linrick1's Avatar
    Join Date
    Aug 2008
    Posts
    141
    Ashburnham, Mass.
    Ford 1900, Steiner 430
    That is some beautiful work, well done.
    Ford 1900 FWD with 771 FEL
    Woods 750 BH
    Steiner 430, 60" deck, 48" snow blower, cab
    CTI Forks
    7.5' Fisher P/A plow
    Timberwolf TW-P1 Splitter
    Stihl 026 Pro/036 Pro/HT101/BR 340
    Honda Foreman ES
    Lincoln Weldanpower AC 225
    Simplicity 870 28" Snowblower
    Meteor 66" Snowblower
    Gravely LI/30" Brush Deck/Sulky
    Gravely 5665/50" Finish Deck/Steering Sulky
  7. #47
    Gold Member davygp38's Avatar
    Join Date
    May 2009
    Posts
    478
    where NY,NJ, and PA all meet
    Kubota L4400
    Nice. I use EMD Locomotives every day. After seeing your work on this project, I hope they put you in charge of designing the cabs on the new engines.
    How do you like me now?
  8. #48
    Elite Member
    Join Date
    Jan 2002
    Posts
    4,607
    SE Wa
    [QUOTE=Emdtrainguy;2772924]Nope, just 2" of foam.
    From my recollection of some 65 years ago 2" of foam only would be pretty scale. I don't recall any springs. Of course my 'forgetter' is rather unreliable these days.
    Harry K
  9. #49
    Join Date
    Apr 2008
    Posts
    78
    This is a very well designed and built project. I have a struck mini dozer lying in pieces in my garage and the quality does not come close to approaching this
  10. #50
    Super Member Iplayfarmer's Avatar
    Join Date
    Jul 2005
    Posts
    5,238
    Idaho
    Massey Ferguson 1215, Toro 266-H, Farmall Cub, Farmall A
    Quote Originally Posted by amashinga View Post
    ... I have a struck mini dozer lying in pieces in my garage ...
    It this a new build or a tear-down?
    From now on I will only buy cars that are a silver/grey color. Then I can make all body repairs with Duct Tape.
Similar Threads
  1. Alabama Cat D3G LGP Dozer, New undercarriage! $26,900- AL
    By rutwad in forum Private Party Ads
    Last Post: 03-27-2011, 07:34 AM
  2. Need to tow a CAT D3 dozer with my non-dually F350
    By ncoracing in forum Trailers & Transportation
    Last Post: 06-19-2009, 10:23 PM
  3. What to look for when buying a dozer
    By Flatheadyoungin in forum Construction Equipment
    Last Post: 01-20-2009, 11:37 PM
  4. Help choosing the right dozer.
    By Jeff244 in forum Construction Equipment
    Last Post: 06-05-2008, 10:24 AM
  5. How to trap a skunk
    By roxynoodle in forum Related Topics
    Last Post: 10-22-2006, 09:38 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
