Dongerosa
I've been building a CDP model mid600 hoe. want to make a subframe, verse the 3pt mount as designed for the B-7510. My plan is to weld bracket to the loader mounts for the front connection, the rear I was planning on using the 4 threaded holes on each end of the axle housing. I would have a steel plate mounted to these 4 hole, this plate would be weld to one of the two frame rails running parellel from the loader mount to the axle, then use this as the mount for the backhoe. thats the plan....my question is...are these axle threaded holes strong enought to support the loading of the backhoe?
