Results 1 to 7 of 7
  1. #1
    Gold Member
    Join Date
    Sep 2011
    Posts
    340
    Corpus Christi. Tx
    Case 485
    Default 3 point sprayer
    I am wanting to build a cheap sprayer using a 55 gallon plastic drum for the tank and basically have the "boom" same width as the tractor but spray a wider swath. I will be using to spray brush. I have searched and found some nice boom sprayers built by members here.
    Do i need the pressure gauge? etc
    Can it be as simple as an electric pump, pipe with spray nozzles and an on./off switch? How do you size the pump to nozzles? I can weld the tank mount /platform, but never have been around a sprayer other than the standard 2 gallon hand pump style.
    Thanks
  2. #2
    Platinum Member KYErik's Avatar
    Join Date
    Dec 2005
    Posts
    822
    South central IL
    1980 JD 2840, 1963 Ford 4000, 1943 Case SC, Case 530CK backhoe
    Default Re: 3 point sprayer
    You should be able to find the specs on the nozzles (gallons per minutes at x psi as well as spray angle) and the pump should also have a gpm rating at x psi.
    Google "ag spray nozzles" and you can see how the specs are given for the nozzles
    "Attitudes are contagious; is yours worth catching?"
  3. #3
    Join Date
    Dec 2007
    Posts
    101
    Cuttingsville, VT
    Ford 850, Ford 1210, Ford 1700, Bobcat 742
    Tee Jet web site should show complete schematic of design and layout, plus calculations for pump, nozzles, valves, etc
  4. #4
    Join Date
    May 2009
    Posts
    240
    SW MO
    1966 John Deere 1020/37 Loader
    Quote Originally Posted by Case485Guy View Post
    Thanks
    Most of the nozzles require a certain PSI, spacing, and height above the ground or brush to get the coverage/results needed for the application. A big majority of the chemicals sprayed are pretty corrosive. Size the pump to nozzles by finding the nozzles you want for the use intended, add up required GPM, and get a little bigger. If you go with a roller pump that's driven off the PTO, you'll have something with more uses than spraying brush, IMHO. I use the roller pump for my boom sprayer pump water from a tote tank, irrigating one of my garden patchs. This link will give you a bunch of good information, as well as diagrams for building what you want. TeeJet - Plumbing Diagrams Hope it helps. Mark
    Attached Thumbnails Attached Thumbnails 3 point sprayer-boomsprayer004-jpg   3 point sprayer-misc007-3-jpg
    Briar Hill Brittanys....."Finest in the Field" www.briarhillbrittanys.com
  5. #5
    Super Member teg's Avatar
    Join Date
    Jul 2005
    Posts
    5,643
    Raleigh, NC Hillsville, VA
    L2800 - HST
    A pressure gauge is nice so you can calibrate the system so you don't waste chemical (either by putting out too much or not enough to get the job done).
    I don't think an electric pump will be the best choice... it depends on how wide of a path you want to spray and for how long of a time... they are better for smaller acreage and spot spraying. Usually they are for 25 gallon tanks and smaller but it could work for you.
    How much spraying are you going to be doing? Seems you have the acreage that 55 gallons might seem small. You say you'll be spraying brush? Acre after acre? or spot spraying here and there?
    Here's an example of one:
    http://www.tractorbynet.com/forums/b...m-sprayer.html
  6. #6
    Gold Member
    Join Date
    Sep 2011
    Posts
    340
    Corpus Christi. Tx
    Case 485
    Quote Originally Posted by teg View Post
    Thanks everyone for the info and links.
    My initial intention was to spray what I have cleared and spray areas that I can drive over. Also spray fence lines. Have been reading up on all the projects and posts I can find on sprayers and starting to think 55 gallon is not enough. I have about 75 acres of natural open area that I want to be able to spray also. getting to the area you have to go through a thick wooded area and across a creek, so transport width is a concern.
    I have some of the 175 gallon tote tanks, thinking that may be better to use or buy a tank. Still looking for used setups, but really thinking of building one.
  7. #7
    Join Date
    Sep 2000
    Posts
    2,059
    russellville, arkansas
    Kubota M4900, B7510 and RTV
    i switched from the boom sprayer to the single spray nozzle that sprays out to each side a long time ago: just so i wouldn't have to watch out for the boom, plus, that way i can drive right against a fence, and get the weeds about 10ft on the other side: has worked great for me, can't spray when its windy: but other than that, it does a heck of a job.
    heehaw
Similar Threads
  1. Do I need a 3 point quick hitch?
    By PapaPerk in forum Attachments
    Last Post: 08-26-2017, 08:07 PM
  2. 3 Point for X749
    By tiger9a in forum John Deere Lawn & Garden
    Last Post: 02-08-2012, 10:35 AM
  3. Craigslist 3 point sprayer for sale
    By chucko in forum Related Topics
    Last Post: 12-14-2011, 09:37 AM
  4. 15 Gal sprayer on a 3 point?
    By Jbbies in forum Build-It Yourself
    Last Post: 11-03-2011, 07:55 PM
  5. 3 Point Lift
    By markh1 in forum Chinese Tractors
    Last Post: 07-27-2010, 03:22 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
