Page 1 of 3 123 LastLast
Results 1 to 10 of 29
  1. #1
    Super Member Iplayfarmer's Avatar
    Join Date
    Jul 2005
    Posts
    5,238
    Idaho
    Massey Ferguson 1215, Toro 266-H, Farmall Cub, Farmall A
    Default I bent some rod into hooks... Now What?
    I heated these rods and bent them into hooks (pictured). Did the process of heating and bending reduce their strength? Do I need to do something to them to put the strength back into them?
    Attached Thumbnails Attached Thumbnails I bent some rod into hooks... Now What?-img_0218-jpg
    From now on I will only buy cars that are a silver/grey color. Then I can make all body repairs with Duct Tape.
  2. #2
    Epic Contributor RoyJackson's Avatar
    Join Date
    Nov 2001
    Posts
    22,284
    Bethel, Vermont
    John Deere 4520 MFWD, Deere 855D UTV, Z920A Zero Turn Mower and assorted implements
    Default Re: I bent some rod into hooks... Now What?
    Depends on how hot you got them. You may have annealed the material.
    Do you know what the rod alloy is? Or the temper?
    I, personally, would be very leery about using them to lift anything. Forged hooks aren't that expensive and are much stronger.
    Roy Jackson
    "There ain't no such thing as a free lunch..."
  3. #3
    Platinum Member rjmack's Avatar
    Join Date
    Jan 2010
    Posts
    709
    cariboo wagon rd
    GC2410
    they really never had any strength to begin with. no reason you can't use them for convenience hooks though, keep chains out of the way or off the ground etc... without relying on them for any pulling/liftng.
    btw, nice job
    2009 mf gc2410
    1972 Patrick Lift Truck
    1949 Allis Chalmers WD
    __________________________________________________ ______________
  4. #4
    Elite Member Code54's Avatar
    Join Date
    Aug 2005
    Posts
    3,282
    Putnam Co. West Virginia
    Kubota MX5100, Kubota BX25D, Kubota KX91-3, BCS 853, MULE FXT Pro
    Quote Originally Posted by rjmack View Post
    btw, nice job
    I agree - what is your planned use for them?
  5. #5
    Join Date
    Jul 2005
    Posts
    5,238
    Idaho
    Quote Originally Posted by Code54 View Post
    These are going to be the hooks on a single tree for a small horse cart.
    If there's anything I can to do strengthen them, I'd like to. It's not like anyone's life or limb is going to be on the line if they fail, but they are what the horse pulls against.
    The rod was cold rolled steel. I heated them up pretty hot to get them to bend. They were glowing red.
  6. #6
    Gold Member
    Join Date
    Dec 2010
    Posts
    270
    Hazelridge, MB
    Kubota L1801 and Massey 65
    Would cold hardening them help?
  7. #7
    Old Timer Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    52,662
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    if you let them cool slowly vs quenching hot.. they are likely more ductile than when rolled.. .. a lil less 'strong' but not brittle.. etc.
    probably ok for your use... I kow a blacksmith that does wrought iron work for some horse cart people. I'd bet some square and round stock got incorporated into a cart now and then..
  8. #8
    Join Date
    Jul 2005
    Posts
    5,238
    Idaho
    Quote Originally Posted by Soundguy View Post
    After I heated and bent them I let them air cool. Does that count as let them cool slowly?
  9. #9
    Join Date
    Nov 2001
    Posts
    22,284
    Bethel, Vermont
    Quote Originally Posted by Iplayfarmer View Post
    Yes, air cooling (vs. water or oil cooling) is slower.
    Considering what you're going to use the hooks for (not a high stress usage), I'd just use 'em and keep an eye on 'em...see if they start to stretch.
    I thought you were going to use them on your tractor...
    Roy Jackson
  10. #10
    Elite Member
    Join Date
    Jun 2011
    Posts
    3,007
    Sunny SW Washington
    LS R4010 & Cub Cadet 7300
    The question would be, are they rated for one horsepower?
    The Corporate Empire is NOT a Constitutional Republic...
    ...but it plays one on TV.
Similar Threads
  1. Yanmar 3TNE68 Bent Connecting Rod
    By Wherewolf in forum Yanmar
    Last Post: 12-16-2014, 10:38 AM
  2. Bent hydraulic cylinder rod
    By Mechanos in forum Hydraulics
    Last Post: 07-07-2011, 05:13 PM
  3. john deere 4310 bent tye rod repair
    By jgraf in forum Parts/Repairs
    Last Post: 05-28-2011, 10:24 PM
  4. Backhoe 375 backhoe, bent bucket cylinder rod
    By jdjllee in forum John Deere Owning/Operating
    Last Post: 12-02-2008, 07:55 PM
  5. DK55 hydraulic rod broke
    By curly in forum Kioti Owning/Operating
    Last Post: 09-13-2008, 03:50 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
