I need to build 2 6 ft. gates for a customer and have a few questions is anyone is willing to help out. I made the pictured gate a couple of years ago. Now i need to make two more for the space to the right of the column. The customer wants the gates to be attached to, two existing 6' brick columns. I am worried about the gates sagging and not lining up in the center. I am also concerned about the brick columns not being strong enough for anchor points. I planned on using. 7" X .75 threaded J-bolts w/ two part epoxy along with a spring loaded wheel but, still am concerned. Could also use use some hinge advise too. Last time i just made the females with .5" X 1.5" flat bar. Don't think that will cut it this time. Does anyone have any suggestions? I also attached a drawing of the new gate as well. Thx
