Results 1 to 7 of 7
  1. #1
    Join Date
    Feb 2004
    Posts
    202
    missouri
    Default trailer gate
    I'm making a 4x6 gate for a trailer that is 6x8 in size. I'm looking for ideas on how to mount it to the back of the trailer. Maybe something other than welding a number of little barrels to slide a round stock through. My idea is to get some round stock and slide it through some type of tube material and bend the ends of the stock to go into a bracket welded onto the trailer. The gate will be lower to the ground to remove mowers. Any ideas ? This gate will welded to the tube material.
  2. #2
    Gold Member
    Join Date
    Aug 2010
    Posts
    326
    Norway
    Same Explorer 65, MF 135, MF 30, MF165, Volvo BM 55, Volvo BM 425, Volvo BM 2254, Terengmester skidder, Ford 3000, Fordson major, Derreng unknown model, IH B275, MAN 4R2, Gutbord sub compact.
    Default Re: trailer gate
    Hey why dont you use hinges like these? Has the same type on all the tractor trailers I own, so durability should not be a problem
    Attached Thumbnails Attached Thumbnails trailer gate-hengsle-jpg
  3. #3
    Join Date
    Sep 2010
    Posts
    131
    How about using the mounts from a pickup truck tailgate? They work well and make it easy to remove the rear gate.
    You can get them at any junk yard!
    I enjoy my cars, garden and tractors!
  4. #4
    Silver Member Low Bucket's Avatar
    Join Date
    Nov 2009
    Posts
    222
    Mountains of West Virginia
    John Deere 110 TLB-John Deere X595- John Deere ATV
    GTT sux!
    Quote Originally Posted by mechanic View Post
    How about using these?- Would be quick and easy to fix.
    1/2" Diameter Greasable Hinge Pin, 4-1/2" Long with 3/4" Base Redline Enclosed Trailer Parts HP12412G
    You can make your own very easy like these.- Very simple.
    A piece of angle bolted or welded to the ramp where the red arrow and black box are.- This keeps the ramp from sliding off the pins.
    Attached Thumbnails Attached Thumbnails trailer gate-hinge_2-jpg
  5. #5
    Gold Member
    Join Date
    Sep 2011
    Posts
    340
    Corpus Christi. Tx
    Case 485
    I use leaf spring hangers alot for removable hinges. Find a long wide hanger and then a short narrow hanger that will slide into the longer one, use a hitch pin or bolt through the bolt hole in the hangers, Have to radius the corners with a grinder some to allow full swivel. I just bought 2 pair for 5200 lb springs from the trailer shop here for 14.00 to use on my drag harrow. Have used them for tow bar mounts etc,removeable trailer gates among other things.
  6. #6
    Super Member
    Join Date
    Aug 2004
    Posts
    6,338
    North of Mtl,Que,Can (Ste Adele)
    MT180D
    If you can't or don't want to weld, I think you are best to consider ramps.
    To fab a hinge system my preference would be 3 short lengths of 1/2" pipe (say 2-3" ea) welded to rear trailer frame and 2 welded to the ramp. A length of 1/2" rod would then be the hinge pin, one end bent 90 deg and a hole at the other end for a cotter pin and a washer.
    You do want that pin to be a lose fit otherwise it will bind due to rust.
    Sure you can use biggest hinges out there but eventually they will pull loose and probably bind up due to rust.
  7. #7
    Gold Member Pete6114's Avatar
    Join Date
    Dec 2000
    Posts
    342
    SW Ontario, Canada
    F2690 GR2120(Sold) L3240(sold) B1700(sold)
    Quote Originally Posted by Low Bucket View Post
    GTT sux!
    X2
    Simple, easy and strong , just drill a hole for a pin, so it cant slide off
Similar Threads
  1. Trailer gate
    By Grammargarcia in forum Trailers & Transportation
    Last Post: 05-25-2010, 05:49 PM
  2. Ford Truck & Trailer Wiring
    By Lloyd_E in forum Rural Living
    Last Post: 05-02-2009, 02:09 AM
  3. Trailer advice needed
    By npaden in forum Trailers & Transportation
    Last Post: 03-21-2006, 04:53 PM
  4. Need Dump Trailer info.
    By Pird in forum Trailers & Transportation
    Last Post: 03-20-2005, 07:57 AM
  5. New trailer needs a lift, help
    By JohnJohn in forum Trailers & Transportation
    Last Post: 10-12-2004, 09:25 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
