Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 44
  1. #21
    Bronze Member Den1952's Avatar
    Join Date
    Feb 2012
    Posts
    83
    Weyauwega Wi
    InternationalHarvestor tlh
    Default Re: Building a Log Arch
    I am still admiring that truss system you worked out. I would want that even if it werent called for. My son just acquired a log arch, seems to be a similar size to yours. not sure but guessing about 6 feet roughly from the wheels forward to the end of the log, maybe more. I made up an inverted vee for him , we will mount that on the forward end of the beam, when he winches up a log the front end can get trapped into the inverted vee, and we can strap it in place, the idea being to prevent any side swing while traveling , also to prevent any teeter tottering of shorter logs. I think we will also mount another winch up front. If he has shorter logs we would have a winch on each end of it, fully suspended. I dont seem to see any like that on the various photos I have ran across. has anybody any ideas why not to do that?
  2. #22
    Join Date
    Dec 2009
    Posts
    64
    central wisconsin
    Case 411b tractor, Dig-it backhoe, John Deere 318 tractor
    Quote Originally Posted by Den1952 View Post
    I don't see a need for a second winch. I back over the logs (about 5ft) and I use a log tongs to winch the log off the ground. I then chain it at the winch and at the front of the log. Like I said it will lift the the log (up to about 14ft) off the ground. I have a picture on my phone that I'll see if I can upload. It has the arch hooked up to my 4 wheeler with 2 long logs on it.
  3. #23
    Join Date
    Feb 2012
    Posts
    83
    Weyauwega Wi
    it would be good to see a photo of that. thanks.
    I was thinking of 2 winches for the events that he would have only 7 foot logs. backed over by 5 feet, he would only be raising the rear end I think.
    centered up, would be a teeter totter. the nose of the log could dig in while traveling, thus the inverted vee idea.
    close by, any cleaning up in the woods wouldnt have any logging trails to drive really long stuff, lots of snaking around to manuever. shorter logs would be much more convenient.
  4. #24
    Elite Member Piston's Avatar
    Join Date
    Sep 2008
    Posts
    3,679
    Lakes Region NH
    Kubota L4610 Hitachi UH083LC
    You can see how I built mine here if you want. I posted a lot of pics.
    http://www.forestryforum.com/board/i...?topic=45388.0
  5. #25
    Silver Member Arky217's Avatar
    Join Date
    May 2009
    Posts
    198
    Greenwood, AR
    Kubota L4200
    How about an extendable log arch for easy maneuverability.
    Short like this for 8-10' logs; extend for longer logs.
    I have hauled as large as 24" x 17' completely off the ground with this one.
    [IMG][/IMG]
    Arky
    Arky
  6. #26
    Super Member
    Join Date
    Jul 2009
    Posts
    8,433
    SW WA
    Kubota BX2360
    Quote Originally Posted by Piston View Post
    Interesting thread. IIRC, you had a ball hitch and were thinking of changing to a clevis hitch.
    Instead of that, weld a hitch receiver tube in place of the coupler, then you can have interchangeable couplers.
    Bruce
  7. #27
    Join Date
    Oct 2011
    Posts
    1,963
    Monrovia, California
    Kubota BX25
    Food for thought...
    [ame=http://www.youtube.com/watch?v=N0XL9-jTP4E&feature=player_embedded]LogRite Junior log Arch Demo - YouTube[/ame]
    Regards,
    Artisan
    Kubota 2012 BX25 (23H.P. / 17.7pto)
    14' Dump / Carson 12K Tow Trailer w/ movable Winch,
    Canopy, Tunes, Stabilizer Soft Pads, 10"-12"BH Buckets, FEL Grapple, Fasse Valved & Switched,
    Fire Extinguisher, ChainSaw Mount, Protective Surround / Enclosure in the works.
    Stayin' Alive (This click could save a life...)
  8. #28
    Join Date
    Dec 2007
    Posts
    101
    Cuttingsville, VT
    Ford 850, Ford 1210, Ford 1700, Bobcat 742
    Trovenn- after seeing all the examples posted, I think you are contemplating something much larger. I have a friend with a logging arch which I believe was commercially manufactured in the 1940s or 50s, not homemade. It is nothing more than a rugged fairlead carried on what looks like 8:00 x 20" rubber. It is comparatively short--8 ft or so- pulled behind a TD6, and uses the dozer's winch. The steel in it is 6" diam or square, and the unit must weigh half a ton. It can carry all the dozer can pull
  9. #29
    Join Date
    Oct 2011
    Posts
    1,963
    Kubota BX25
    Quote Originally Posted by tree grower View Post
    PICTURES!
    Regards,
    Artisan
  10. #30
    Join Date
    Jun 2011
    Posts
    58
    Manamade
    Just a couple of Pics of logging arch
    One still in use behind what looks like a D5 and the other wth an old D4
    I suggested earlier to use duel wheels to give you a bit of flotation You could also mount a PTO winch on the arch so then you can pull the logs as well.
    Sorry havent any photos of the one that I built and used behind a tractor and skidder. It was only used behind the skidder when the logs were too big for the skidder.
    Attached Thumbnails Attached Thumbnails Building a Log Arch-paccar-20arch-20b-jpg
    Attached Images Attached Images
Similar Threads
  1. P-model arch steel building project
    By Dirtnut in forum Projects
    Last Post: 03-20-2012, 08:56 PM
  2. Building an intermediate log splitter hoist
    By NH Mike in forum Build-It Yourself
    Last Post: 03-08-2012, 08:14 AM
  3. Building a Log Splitter with Northern Tool parts
    By LanceH in forum Build-It Yourself
    Last Post: 08-09-2011, 10:23 PM
  4. building a arch gate
    By Regneufeld in forum Build-It Yourself
    Last Post: 03-10-2011, 05:24 PM
  5. Anyone make a log arch for a Skid steer?
    By Rio_Grande in forum Build-It Yourself
    Last Post: 02-21-2011, 10:29 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
