Page 1 of 2 12 LastLast
Results 1 to 10 of 13
  1. #1
    New Member
    Join Date
    Feb 2012
    Posts
    12
    jefferaon city mo.
    Default homemade tracked hi lift/backhoe
    Just some thing I always wanted. A friend told me I can't build tracks so I am building a machine and tracks.
    Attached Thumbnails Attached Thumbnails homemade tracked hi lift/backhoe-wp_000105.jpg   homemade tracked hi lift/backhoe-wp_000092.jpg
  2. # ADS
    Advertisement
    Join Date
    Mar 1998
    TractorByNet.com
    Posts
    Register now to remove this ad.
  3. #2
    Silver Member ametcalf's Avatar
    Join Date
    Apr 2011
    Posts
    162
    Central KY
    Kubota BX23
    Default Re: homemade tracked hi lift/backhoe
    It will be interesting to see this develop. Please keep the pictures coming.
    A. Metcalf
    ametcalf
    All I need to be a better mechanic is a bigger hammer.
    2004 BX23, 72" Landpride finish mower, 48" Howse tiller, Home made brush forks, grapple, and plywood skidplate.
    Allis Chalmers 5040, 6’ Bushhog, Boom pole, PHD, Box Grader, Rear Blade, 2 bottom plow
    2000 Crewcab Super Duty F250 Powerstroke Diesel 260k miles
  4. #3
    Elite Member
    Join Date
    Jul 2006
    Posts
    4,409
    Northwest, WA
    Quote Originally Posted by jjinks View Post
    Wow, that's what happened when a friend said you couldn't ?, Wow.
    Hmmm,,,,,, "YOU CAN'T FINISH THIS PROJECT" thumbsup!
    ::Sent from a standard desktop keyboard::
    My Photobucket
  5. #4
    Gold Member Piperflyer's Avatar
    Join Date
    Dec 2006
    Posts
    254
    USA
    Kubota3030HST
    By all means keep the pictures coming
    'Life's Journey is not to arrive at the grave safely in a
    well preserved body, but rather to skid in sideways, totally worn out, shouting, 'Holy S... What a Ride!!
  6. #5
    Platinum Member Mike476's Avatar
    Join Date
    Jun 2010
    Posts
    862
    Annapolis Valley, Nova Scotia
    MF 135 Z134 Continental, MF 1660 Cab
    Looks interesting, are you working off a set of plans you've drawn up yourself or researched for the lift/backhoe?
  7. #6
    New Member
    Join Date
    Feb 2012
    Posts
    12
    jefferaon city mo.
    I have looked at a bunch of different construction equipment over the years and kind of came up with my own plan. I will have steel tracks around 20' or so in length each made of 54 1/4"/12" dirt plates. I used 3/4"pipe and rod for hinge points. Then I will bolt on c channel grousers or rubber pads. I figure on using steel wheels as rollers/idlers and drive wheels with steel bar welded on as teeth to drive the tracks. To turn the drive wheels i will use a hydraulic motor with built in break (try to get by w/o a finaldrive) a variable Displacement piston pump and i was thinking of using a old 4 Cly 65Hp engine out of a old bobcat.
  8. #7
    Join Date
    Jun 2010
    Posts
    862
    Have you set a timetable for yourself or do you want to just play at it when you have the time? Very ambitious, good luck!
  9. #8
    New Member
    Join Date
    Feb 2012
    Posts
    12
    jefferaon city mo.
    I try to work on it a hour or so every day mostly limited by funds. I have about $600 in steel and accessories per track. I figure there will be about $3200 in steel total. That includes my extendable backhoe and hi lift loader.
    Then $800 in wheel motors $1600in valves the double pump will be at least a grand then my cylinders. Still cheaper than any used equipment around here.
    If this works out will be very useful and easy to transport i estimate the weight to be around 7000 Lb or so with around 45 hp at each drive wheel and top speed of around 12-16 mph max. Hope it will clear small trees and move some dirt. The finished track setup will be similar to a d series cat.
  10. #9
    New Member
    Join Date
    Aug 2007
    Posts
    10
    S.E. MN
    Oliver's
    Can we get some close ups of the track design and build? I am collecting material right now with the hope to get started when the temps rise abit. I dislike cold steel, the old it sticks to skin.
  11. #10
    Elite Member dfkrug's Avatar
    Join Date
    Feb 2004
    Posts
    4,145
    NorCal
    05 Kioti CK30HST w/ Prairie Dog backhoe
    A friend told me I can't build tracks....
    The world is full of folks who tell you that you can't do something.
    They are really just projecting their own lack of ability and/or motivation.
    I'd like to see your details on the tracks, too. You go, JJ!
    See my TBN projects at:
    http://mysite.verizon.net/resyfcgt/
Similar Threads
  1. Yanmar C10r tracked dumper
    By Cord in forum Yanmar
    Last Post: 09-06-2012, 02:51 PM
  2. My Homemade Flail Mower
    By Teigrek in forum Build-It Yourself
    Last Post: 12-27-2011, 06:38 PM
  3. Homemade TPH Hauler '53 John Deere Model 40
    By Glassback in forum Build-It Yourself
    Last Post: 02-07-2011, 11:49 AM
  4. Tracked Skid Steer-High Operating Costs/ Tracks
    By curtisfarmer in forum Kubota Owning/Operating
    Last Post: 01-05-2008, 09:10 PM
  5. Homemade tractor
    By JayC in forum Photos
    Last Post: 09-06-2002, 02:17 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
