Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 34
  1. #11
    Gold Member NH-Rob's Avatar
    Join Date
    Feb 2008
    Posts
    319
    Northern NH
    Kubota B7510HSD(sold) B3200(new 6/15/09)
    Default Re: LA 302 bucket quick hitch
    wow that works better then the factory one on my b3200. my pins hardly ever just slide in. I hope to build a skid steer style one of these days. Wish i had the metal shop access that you do it sure would make it a much easier build
    Rob
    b3200, 60" land pride finish mower, 3pt log spitter, pallet forks, lawn sweeper, bottom plow, Loader mounted snow plow, 3pt quick hitch.
  2. # ADS
    Advertisement
    Join Date
    Mar 1998
    TractorByNet.com
    Posts
    Register now to remove this ad.
  3. #12
    Join Date
    Sep 2007
    Posts
    1,428
    Doniphan, Mo.
    Kubota L4240, B7800 & BX2660
    Wow I'm doing the same thing right now for my B7800. I got the hookup brackets made now and just have to go and get the other flat stock. Mine are little different but hookup like yours, but the hookup pin is above the lower pin. Yours is going to be better then mine and when I get them done I well post a picture and then you can see what I mean.
  4. #13
    Gold Member 600rider's Avatar
    Join Date
    Jul 2007
    Posts
    317
    union city pa
    2004 kubota b7510
    You know why I made the QH for the loader don't you? Yep next on the agenda is a set of FEL forks! I got a set of 42" forks last summer from our jitney repair man for scrap price $.15 a lb. x 80 lbs ea = $24.00! I got started on them tonight. Sorry no pics (phone was on charge!) I am using 2.5"x2.5"x.5" angle for the top and bottom rail that the forks slide on with 2.5"x.375" flat bar for the uprights. I notched the top bar from the center to the outside edge 2.50" on center, 7 notches each side. I made a 4" notch in the bottom center to facilitate removal. That's about all I got done tonight. I will post pics tomorrow.
  5. #14
    Join Date
    Jul 2007
    Posts
    317
    union city pa
    2004 kubota b7510
    here is the thread for the Fork build, http://www.tractorbynet.com/forums/b...tch-forks.html
  6. #15
    Silver Member zmansmac's Avatar
    Join Date
    May 2003
    Posts
    139
    SE Michigan
    Kubota B7500
    What a great project, and well executed too. I've been thinking about doing something like this for my LA302 as well but it seemed like all the quick attaches I've seen add more weight than I would want. But this design is elegant and simple. I do have a couple of questions though. Since you didn't post any pics with the bucket attached, I'm trying to figure out the purpose of that little piece of metal on the outboard sides that is welded on an angle and has a crescent shaped cut on the end. In the video I see you putting in and taking out the 3/4 inch pins but what holds them in, or did you just slide them in for the purposes of showing how easy they go in? Also, what is the diameter of the solid rod connecting the sides. I haven't looked at your fork project yet but that is next on my list as well. But based on this project I'm sure it will also be great.
    JohnZ
    B7500
  7. #16
    Join Date
    Jul 2007
    Posts
    317
    union city pa
    2004 kubota b7510
    Thanks zmansmac, I copied this from the BL1676 hitch Kubota offers for the LA402 loader and others. I just down sized it to fit the LA302.
    First Question; That little piece of metal is a stop that after you hook the top then roll the hitch back the bushing material that the pins go through locates it self and makes the holes line up to be able to insert the pins.
    Second Question; The pins are held in with a 1/4" lynch pin I just didn't put them in while I was demonstrating how quick and easy it was to put on and take off the bucket.
    The diameter of the rod is immaterial as all it does is hold the hooks and keeps them parallel. I picked something of the shelf and drilled the holes and welded it in. In this case it was 7/8" but you could use 3/4" or 5/8" or even 1". I put the bucket clamps on the arms and the bucket on the clamps then disconnected the battery inserted the rod and welded it there in place to make sure the clamps were positioned correctly.
  8. #17
    Join Date
    Jul 2007
    Posts
    317
    union city pa
    2004 kubota b7510
    zmansmac, here is a couple of pics of how that "crescent" stop works. and also of my lynch pin.
    you put the hook on the top of the QH under the top pin, lift up and roll the QH back and the bushing goes against the stop and then slide the pin in and put the lynch pin in.
    Simple as that! and all takes less than a minute!
    I can't take credit for the design as it is Kubota's.
    Attached Thumbnails Attached Thumbnails LA 302 bucket quick hitch-0225121322.jpg   LA 302 bucket quick hitch-0225121321.jpg   LA 302 bucket quick hitch-0225121520.jpg
  9. #18
    Join Date
    May 2003
    Posts
    139
    SE Michigan
    Kubota B7500
    Thanks for the explanations and the pics. I don't have any close neighbors with this set up and, although I haven't been to my local dealer in a while, I never looked because I thought Kubota's quick hitches were only on larger tractors, and that they are a different set up. I figured the cross piece size didn't matter too much. I have some tube stock that I think I'll use. That way it will be easier to weld a receiver box in the middle of the cross piece for use when towing a trailer.
    JohnZ
    B7500
  10. #19
    Join Date
    Jul 2007
    Posts
    317
    union city pa
    2004 kubota b7510
    "I figured the cross piece size didn't matter too much. I have some tube stock that I think I'll use."
    I thought about using a tube instead of solid bar but the bar is what I grabbed off the shelf! The one thing you want to check before you weld it in place is to make sure when you roll the bucket all the way back it does not hit the cylinder ends. I didn't take this into consideration and mine hit the ends but took the 7" wildcat and a stone to it and made some clearance on the bar and now it doesn't touch it. Also roll the bucket down all the way to check for clearance on the arm ends. Fortunately I had clearance there so only the grinding on the one side was all I needed. My 7/8" round bar has a flat spot on each side now but only took about 1/4" off to get the clearance.
  11. #20
    Veteran Member magicheater's Avatar
    Join Date
    Jul 2009
    Posts
    1,665
    central Wisconsin
    Kubota B7800
    Nice Job! What is the final weight of your Q/A?
    Working to increase the scope of the small tractor experience, one quick attach at a time.
Similar Threads
  1. Pat's Easy Change Vs Quick Hitch
    By deere5105 in forum Attachments
    Last Post: 02-22-2012, 08:49 PM
  2. Kubota L-2072 Quick Hitch plow / grader blade
    By WayneB in forum Private Party Ads Archive
    Last Post: 12-10-2011, 03:59 PM
  3. Loader Mounted Quick Hitch
    By Runner in forum Build-It Yourself
    Last Post: 07-23-2011, 04:57 PM
  4. 3 pt quick hitch to bucket
    By Jw5875 in forum Kubota Owning/Operating
    Last Post: 02-08-2009, 11:27 AM
  5. Pat's Easy Change Pats Easy Change or the Quick Hitch????
    By smittyd3 in forum Attachments
    Last Post: 01-24-2005, 07:57 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
