Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 34
  1. #21
    Gold Member 600rider's Avatar
    Join Date
    Jul 2007
    Posts
    361
    union city pa
    2004 kubota b7510
    Default Re: LA 302 bucket quick hitch
    Quote Originally Posted by magicheater View Post
    Nice Job! What is the final weight of your Q/A?
    Well that's a good question! I have not weighed it but am sure it is less than 25#. I we take it off to paint and weigh it then, but not sure when that would be. I think the round bar probably weighs as much as the hooks together!
  2. #22
    Gold Member Grayson Klassen's Avatar
    Join Date
    Mar 2011
    Posts
    271
    Fort St John, BC
    John Deere 4020
    I think that you did a great job
    Grayson Klassen
    Fort St John, BC, Canada
    JD4020
    JD148 FEL
  3. #23
    Join Date
    Jul 2007
    Posts
    361
    union city pa
    2004 kubota b7510
    I took it off to paint it today and weighed it up and it comes in at about 19 lbs. Even less than I thought!!!
    I couldn't wait for the warm weather so here it is with a coat of paint on it.
    I might get a second coat on it Monday.
    Attached Thumbnails Attached Thumbnails LA 302 bucket quick hitch-0303121906-jpg   LA 302 bucket quick hitch-0303121752-jpg   LA 302 bucket quick hitch-0303121753-jpg
  4. #24
    Elite Member
    Join Date
    Sep 2007
    Posts
    3,377
    Doniphan, Mo.
    Kubota L4240, B7800 & BX2660
    Here is the way I did mine. Yours looks alot nicer, but if they do the job that's all that counts. I don't have the tools that you could use. I used a drill press, chop saw, 4 1/2" grinder and a welder.
    The last picture I just had to show, Eddie has a pig and I have 2 turkeys on my heels when I let them out.
    Attached Thumbnails Attached Thumbnails LA 302 bucket quick hitch-b7800-loader-quick-hitch-002a   LA 302 bucket quick hitch-b7800-loader-quick-hitch-010a   LA 302 bucket quick hitch-b7800-loader-quick-hitch-011a   LA 302 bucket quick hitch-b7800-loader-quick-hitch-003a
  5. #25
    Join Date
    Jul 2007
    Posts
    361
    union city pa
    2004 kubota b7510
    Leejohn, I don't under the extra set of holes on the bucket. Do You use the original lower holes to line up the pins for the middle holes to pin it on?
    Here are some pics I took tonight after I re installed the QH, level indicator and fork frame after I painted them.
    I also installed the 36" forks I traded my 42" forks for.
    Attached Thumbnails Attached Thumbnails LA 302 bucket quick hitch-0305121917-jpg   LA 302 bucket quick hitch-0305121918-jpg   LA 302 bucket quick hitch-0305121918a-jpg   LA 302 bucket quick hitch-0305121918b-jpg
  6. #26
    Elite Member
    Join Date
    Sep 2007
    Posts
    3,377
    Doniphan, Mo.
    Yes the pin in the bucket is what I use to lock it all together. The bottom pin is for pushing and it helps also on it moving up and down. I'm using 3/4" pins in the bucket for when I back drag, hoping they are strong enough (seem to be right now).
  7. #27
    Join Date
    Jul 2007
    Posts
    361
    union city pa
    2004 kubota b7510
    Quote Originally Posted by Leejohn View Post
    You are very correct Leejohn, if they work that's all that counts! I was going to make mine with a piece of rectangle tube and some flat plates but I liked this way a little better and since I had access to the press brake I made mine more like OEM kubota QH.
  8. #28
    Veteran Member JohnDeere4300's Avatar
    Join Date
    Feb 2005
    Posts
    1,565
    John Deere 4300
    Quote Originally Posted by 600rider View Post
    You did a great job!!!... Having a "Quick Attach" on a FEL is great!!.. I think all tractors should come that way!.. IMHO!
    Now you can switch from your bucket to your forks QUICK!!
    John 3:16
    01 JohnDeere4300 "Sync-Reverser", Vertical Exhaust, 2 JD Lawn Tractors, JD Walk Behind.
    430-FEL/ 47-Backhoe/ 5' Bush-Hog/ Single Bottom Plow/ 6' Disc/ Aerator Spreader/ HF Quick-Hitch!
    (Homemade Stuff) BH Thumb/ Log-Hitch/ 10' Boom-Pole/ 42'' Pallet Forks ''FEL Quick Attach & 3PH Quick-Hitch-Attach''/ Ballast Box 1381 lbs./ Aluminum Canopy/ Brush-Guard Mod/ 5x10 Firewood Trailer/ Lawn Striper.
  9. #29
    New Member
    Join Date
    Oct 2011
    Posts
    14
    Kubota L245DT
    Hello,
    I am starting a QH for my FEL.
    What thickness of steel did you use for the side plates?
    I cannot read the tape measure accurately.
    Thank you,
    Kenan
  10. #30
    Join Date
    May 2011
    Posts
    50
    NE OH
    Kubota B2320 John Deere 318
    600rider,
    Very nice work. This is the type of thing I like about TBN, a place where talent and similar interests come togther from people who would not otherwise meet.
    I was wondering if you had to modify the bucket at all, or just use the stock pins and locations.
    Keep up the good work..
Similar Threads
  1. Pat's Easy Change Vs Quick Hitch
    By deere5105 in forum Attachments
    Last Post: 06-16-2014, 10:57 PM
  2. Kubota L-2072 Quick Hitch plow / grader blade
    By WayneB in forum Private Party Ads Archive
    Last Post: 12-10-2011, 04:59 PM
  3. Loader Mounted Quick Hitch
    By Runner in forum Build-It Yourself
    Last Post: 07-23-2011, 05:57 PM
  4. 3 pt quick hitch to bucket
    By Jw5875 in forum Kubota Owning/Operating
    Last Post: 02-08-2009, 12:27 PM
  5. Pat's Easy Change Pats Easy Change or the Quick Hitch????
    By smittyd3 in forum Attachments
    Last Post: 01-24-2005, 08:57 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
