Well i have been using this website for many of the ideas i have implemented in the logsplitter i am currently building. I wanted to post some pictures and info so hopefully i can help others with their builds. I also will probably need help along the way. I am doing this build in my single car garage with other projects going on at the same time so progress will vary. I am fairly new to metal fabrication and many things i do will be a first with this project. I am using mostly scrap steel i have been able to gather from the trash or picked up from friends. So far i have had to buy the Ibeam for 100$ and a 4ft by 11 inch plate of 1inch steel for 50$. I have bought a 16gpm pump, 4inch by 24 inch cylinder, wedge, anchor block and a few other items from northern tool. I am just learning how to stick weld and it is my fist box of 7018 rod. It is also my first time layering welds (as i did in the wedge weld). Any pointers or critiques are appreciated. I got the axle from a jetski trailer. I cut the axle a foot shorter and that brings it to about 5 feet wide. It was very difficult to build the trailer frame out of round steel but it was all i had. The lift table was built out of an old section of iron fence. The hydraulic cylinder was from a lawnmower that was marked for garbage. Right now i am waiting for the 1 inch hole to be drilled on the piece that my main cylinder attaches to that is on the push plate. Once i get that piece back i can weld my push plate together. I have been using a combination of my circular saw and plasma cutter to cut the steel. Any other suggestions for getting through this one inch plate?
