Results 1 to 10 of 12
03-17-2012, 08:22 PM #1
Powder Coating question
I am fabricating a couple of relatively small parts for the tractor and am debating on trying to use powder coating instead of enamel paint.
Just how hard is it to powder coat?
Can a conventional oven be used to cure it without smelling up the whole house or is that a very bad idea?
Any toxic off-gassing during the cure?JD 4720 - 400CX FEL, Woods BB-720 Brush Bull and BH90X backhoe, Salsco 6210XT PTO Chipper, Farmi 501 Logging Winch, Bo-Dozer Grapple, LP RBT4096, Cammond Road grader/leveler and Rankin Trash Forks
03-17-2012, 08:36 PM #2Platinum Member
- Join Date
- Jun 2009
- Posts
- 625
- Location
- Nowhere
- Tractor
- 1878 Ford 65N
Re: Powder Coating question
I have a Chicago Electric powder coat system. It is very easy to use and you get good results. I have used an oven to cure. It was an old oven. It does off gas a bit and probably not advisable to PO your spouse. Not sure if any toxic stuff comes out.
If you can get an old oven and do it outside in the garage you'd be better off.
Are they small enough to fit in a small toaster oven?
03-17-2012, 08:39 PM #3Platinum Member
- Join Date
- Apr 2009
- Posts
- 577
- Location
- TN
- Tractor
- NH TD5030, 861 Ford Powermaster, 555A Ford Backhoe, S150x SnapperPro ZTR, Polaris Ranger XP800
I have not powder coated anything myself yet but have been Reading about the process. I have seen this question asked a few times and the answer is always the same. Never use an oven that you intend to cook food in again. Buy an old oven or maybe get one for free from Craigslist or an appliance store (trade in). Use it in your shop or outside. If small parts use an old toaster oven.
Chris
03-17-2012, 08:40 PM #4Elite Member
- Join Date
- Jan 2009
- Posts
- 3,565
- Location
- Preble County, Ohio
- Tractor
- Kubota B7800 with FEL
I have told this can be baked on with a torch also.
........Shoot this thang! Have mercy this thang is killin' me. Just shoot up here amongst us. One of us has got to have some relief..............
jerry clowers-a coon huntin story.
03-17-2012, 08:46 PM #5
03-17-2012, 08:51 PM #6Elite Member
- Join Date
- Jan 2009
- Posts
- 3,565
- Location
- Tractor
Any place that touches the powder before it is cured will be marked. It's better to hang the part by hooking it in an area where a mark wouldn't matter.
03-18-2012, 12:34 AM #7Super Member
- Join Date
- Feb 2008
- Posts
- 7,750
- Location
- somewhere usa
- Tractor
- stuff
Best would be to hang the parts with a small bailing wire as metnioned above. Might be able to fasten your part to the top rack before you spray on the powder, then insert into the oven carefully and bake it.
Just for kicks here is my plumbing truck with powdercoated frame. The whole black frame portion including top racks, front baskets, floor, frame and lift gate with hydraulics removed was baked in one piece. Everything that is black in other words and this was done in 2003. Sure has been better than paint with almost zero maintenance. Took a kingsize oven for this project. Worked well inough compared to painting that I then powdercoated my other two red service trucks, while they have signs of wear after 7 years it has been more durable than paint by a large margin.
03-18-2012, 12:58 AM #8Veteran Member
- Join Date
- Feb 2005
- Posts
- 1,111
- Location
- Edgewood, NM USA
- Tractor
- Jinma 354, Ford 1953 NAA Golden Jubilee, Komatsu Bulldozer
You can 'reverse" power coat. Meaning heat the parts first to about 375 to 400* F no more than 400! ( with a weed burner for big parts or plumbers propane torch for small parts (use an IR temperature gun to measure temp) then spray on the power coating, it melts instantly upon contact with the hot metal.
I did that process to coat my entire landscape rake project build and it came out fantastic.
Be VERY careful not to create sparks from the static of the power coat gun (Don't get to close to the metal with the gun) with this "reverse" process, the hot melting power gives off toxic FLAMABLE fumes that ignite instantly with a spark - (Don't ask me how I know this) You see my avatar on the left, right?
LarryMy Fortune cookies:
If you have to ask if you can do something, you probably can't.
Life is short, especially if you forget to wake up the next day.
He who hurries wastes time.
If you must select between two evils, choose the one you haven't tried before.
Tractor hydraulics is not rocket science.
03-18-2012, 01:35 AM #9Super Member
- Join Date
- Aug 2006
- Posts
- 5,114
- Location
- Front Range of Colorado
- Tractor
- JD 4200 C.U.T. & JD 130L Lawn tractor
Steve:
Those are some trucks you have there with all the cabinet storage.
Larry:
Welcome back...long time, no see.
03-18-2012, 02:24 AM #10
I use the preheat first then cure in the Craigslist oven trick. i customized one of the racks to hold parts. I spray then slide the whole rack back in
Similar Threads
Barb Wire Selection - high tensile vs low carbon and coating choice
By rrb1981 in forum Rural LivingReplies: 9Last Post: 04-07-2011, 07:55 PM -
tough paint
By whitedogone in forum Build-It YourselfReplies: 64Last Post: 07-13-2010, 09:32 PM -
Mulcher Setup Question
By grabroot&growl in forum Land ClearingReplies: 11Last Post: 04-22-2007, 12:29 PM -
4341.1 Zetor Tractor Question
By Cabinholler in forum Zetor, Century & BransonReplies: 10Last Post: 09-18-2005, 10:51 PM -
Compression Fitting Question
By rock in forum Kubota Owning/OperatingReplies: 1Last Post: 06-11-2002, 10:35 PM
