Results 1 to 7 of 7
03-20-2012, 12:26 PM #1New Member
- Join Date
- Mar 2012
- Posts
- 2
- Location
- Warren, AR
- Tractor
- TO-20 and 9N ford
engine testing stand
do anyone have a plan to build a engine testing stand for a to-20 and 9n?
thank you
Johnny
03-20-2012, 04:50 PM #2Elite Member
- Join Date
- Oct 2003
- Posts
- 2,762
- Location
- the Steernbos (Holland)
- Tractor
- Zetor 3011, Zetor 5718
Re: engine testing stand
why on earth would you want an engine test stand for a tractor engine, arent there plenty of tractor rear ends available ???
Free scrap is a good investment !!!
“The worst enemy of life, freedom and the common decencies is total anarchy; their second worst enemy is total efficiency” · Aldous Huxley
__________________
1967 Zetor 3011, restoration in progress: Technically new, just needs the cosmetics..
1973 Zetor 5718, home made loader
1998 Volvo S70 TDI
2007 Volvo 440 1.9 TD based dirt buggy, needs time !
03-20-2012, 07:02 PM #3Platinum Member
- Join Date
- May 2005
- Posts
- 970
- Location
- N. E. Florida
30 years ago I bought a used Mercruiser Boat Engine (350 Chevy) from a dealer. I wanted to here it run so they just hooked up a battery and gas plus a water hose and started it up sitting on the concrete floor! I have since done it many times except I just blocked them off the floor with 4 X4's. The concrete scratches the oil pan.
You could just build a wood frame strong enough to hold the engine very easily. They won't move around, just a little vibration.
03-20-2012, 07:09 PM #4Platinum Member
- Join Date
- Feb 2007
- Posts
- 673
If one has a tractor splitter stand I would think you would have one right there,
the stand I built (do not have a picture of it and a neighbor has it), is a cross between these two pictures, it uses a small Hydraulic jack on each side to raise and lower for fine adjustment and has 4 wheels for stability and it has a diagonal brace for moving the front away from the rear, but only has the single up right working much like the trailer jacks, in the one picture.
one picture is from this site, Splitting stands. - Red Power Magazine Community.
the the other is from this site, Sample Page of Photos on Heavy Duty Shop Equipment: Tractor Splitting Stands: Model HR16
03-20-2012, 08:59 PM #5Veteran Member
- Join Date
- Sep 2007
- Posts
- 1,389
- Location
- Doniphan, Mo.
- Tractor
- Kubota L4240, B7800 & BX2660
This is what I came up with. It's hooked up to a B7800 in this picture. It well also fit up to my L4240 for sure, but should work on about any mid HP and down.
03-20-2012, 10:42 PM #6Super Member
- Join Date
- Jun 2005
- Posts
- 5,686
- Location
- Northern California-Tehama Co.
- Tractor
- 2008 Mahindra 5525, 1964 MF-135 diesel, 1951 Farmall Super A, 1951 Minneapolis Moline BF, 1945 Oliver 60 Row Crop, 1949 JD B widefront
03-23-2012, 08:36 PM #7New Member
- Join Date
- Mar 2012
- Posts
- 2
- Location
- Warren, AR
- Tractor
- TO-20 and 9N ford
thank you for your ideal on a engine stand
Similar Threads
Engine changes to Diesel x7xx series.
By JDTank in forum John Deere Lawn & GardenReplies: 43Last Post: 03-11-2012, 07:21 AM -
Anybody know the 1972 Hinomoto Combac?
By jsw44 in forum General Vintage TractorsReplies: 16Last Post: 09-09-2010, 07:01 PM -
Engine Overhaul Kama 554
By 3RRL in forum Chinese TractorsReplies: 288Last Post: 06-25-2010, 03:18 PM -
422 robin engine blew up on 8/28/07
By scarg in forum Power TracReplies: 31Last Post: 09-06-2007, 06:10 AM -
6x4 Gator Diesel surges
By ndblackhawk in forum ATVs & Utility VehiclesReplies: 2Last Post: 10-20-2005, 09:52 PM
