Results 1 to 10 of 10
04-07-2012, 10:08 PM #1Gold Member
- Join Date
- Dec 2010
- Posts
- 295
- Location
- Central Texas
- Tractor
- Kubota L235
Fire extinguisher mount
I've just added a fire extinguisher to my tractor. Couldn't mount it on the ROPS since I couldn't reach it from the ground, so I put it on the fender. Here's the metal I started with which is left over from building the barn. The bracket mounted and with the extinguisher in place.
Kubota L235
John Deere 5055E
04-08-2012, 09:31 AM #2Veteran Member
- Join Date
- Aug 2008
- Posts
- 1,290
- Location
- W. Central Louisiana
- Tractor
- JD 5085M; NH TN70A; Ford 2600
Re: Fire extinguisher mount
Great idea and good job.
Now, do me a favor. Get a real fire extinguisher. I suggest Amerex or Badger. I serviced extinguishers for 14 years. Real fire extinguishers do not have Kidde or First Alert on the label. Trust me, that Kidde is junk. One day, maybe when you need it the most, it won't work. Plastic is fine for lots of things, but a fire extinguisher valve ain't one of them.'10 JD 5085M Cab MFWD FEL
'07 NH TN70A MFWD FEL
'81 Ford 2600
JD 457 round baler; JD 265 & Kuhn GMD 600 disc mowers; Sitrex V-10 rake; Hardee 10', Rhino 7', & Modern 5' rotary mowers; JD 13' & Ford 6' tandem discs; HayKing 10' rennovator plow (sub-soiler); etc, etc.
My other tractor is a '95 Kenworth.
Don’t ever wrestle with a pig. You’ll both get dirty, but the pig will enjoy it.
04-08-2012, 09:40 AM #3
Nice, I like it. That makes me think about building one myself. I think it may be my be my next project. Thanks
04-08-2012, 11:44 AM #4
Nice install! Definitely something I need to do.
Ford 1620 HST FWD
FEL w/toothbar, Backhoe, 5' Rotary Cutter, 5' Boxblade, 5' Disc Harrow, 2 Bottom Plow, Cultivator, Landscape Rake
06-03-2012, 10:10 AM #5Gold Member
- Join Date
- Oct 2007
- Posts
- 340
- Location
- North Central Mississippi
- Tractor
- JD 4320
Obviously, a fire extinguisher mount on a tractor needs to be much more robust than the typical home mount. I imagine we would need a metal mount with metal straps. What type of mount does one need and where is the best place to purchase it?
Also, I know there is a general concensus that a metal valve is a MUST over the plastic valve. Are these carried at the local stores?
Also, what is the best size? 2lb or 5lb?
Finally, can these be purchased at Lowes, etc? If not, where is the best place to purchase?
06-03-2012, 10:37 AM #6Veteran Member
- Join Date
- Aug 2008
- Posts
- 1,290
- Location
- Tractor
I owned/operated a fire extinguisher service company for 14 years. I speak from experience. Plastic valves are JUNK! Period. Ever notice that the places that sell those things DO NOT have them hanging on the walls of thier store? Think about it.
To answer your other questions, a 2.5 pound extinguisher is better than not having one. A 5# is twice as good. (if you can find a place to mount it)
Go to your local fire extinguisher service. (should be listed in the yellow pages) They will sell you a quality extinguisher, that they will service, and a proper bracket.
I would suggest Amerex, Badger, Ansul or Buckeye. (in that order) Stay away from anything branded Kidde, Flag, or First Alert.'10 JD 5085M Cab MFWD FEL
'81 Ford 2600
06-03-2012, 10:39 AM #7
06-04-2012, 12:18 AM #8Elite Member
- Join Date
- Apr 2012
- Posts
- 2,814
- Location
- Tennessee Vols Country
- Tractor
- My tractor is an old M... F... and red too.
Retired and enjoying life and my grandchildren -robert
"life is too short.. eat your cake first" ~rpk
My 1965 MF 135 Z145 Refurbish project
About ME
06-04-2012, 01:24 AM #9Silver Member
- Join Date
- Mar 2012
- Posts
- 202
- Location
- Taylorsville, GA
- Tractor
- 3000 Ford 66' 260A International Backhoe
Just to let everybody know shipping charges will require a hazardous fee. UPS charges extra $25 I'm not sure but the others are probably about the same. This was on a 5lb abc type from Mcmaster Carr.
I've got a cutting torch and a welder sooo YEAH it'll fit!!
06-04-2012, 11:34 PM #10Elite Member
- Join Date
- Apr 2012
- Posts
- 2,814
- Location
- Tractor
Since we are dealing with a petro fire if it ever occurs, it would be to good to use an ABC type one to two pounder. I keep one in my classic car. Knowing your tractor and how to cut off the fuel is a must. Co2 will also put out a petro fire quickly. The key to using a FE is knowing how to use it. You blast the base of the fire. There are many videos one should watch to prepare him/herself I'm the case of an emergency. Tractors such as the MF 135 that has an exhaust underside could spake a grass fire, so a FE would be a good idea.
About ME
Similar Threads
Need recommendation for fire extinguisher for PT-425
By Clumber in forum Power TracReplies: 14Last Post: 06-06-2011, 04:47 PM -
Misuse of hair dryer to blame for deadly West End fire
By medicshawn in forum SafetyReplies: 0Last Post: 12-29-2010, 06:21 PM -
Fire Extinguisher Checks
By zzvyb6 in forum SafetyReplies: 37Last Post: 03-20-2009, 02:42 PM -
Need opnions... Looking at a 97 F1145 Front Mount Mower
By Jason B in forum General Lawn & GardenReplies: 4Last Post: 02-17-2009, 10:46 AM -
Fire On The Mountain
By MarkV in forum Rural LivingReplies: 11Last Post: 07-15-2001, 10:58 PM
