Page 1 of 6 1234 ... LastLast
Results 1 to 10 of 57
  1. #1
    Member JustBob's Avatar
    Join Date
    Mar 2012
    Posts
    48
    Mobile, Alabama
    2005 New Holland TT55
    Default Homemade Tree / Post Puller
    After 3 years of wanting one, I finally decided to buy one. That is until I figured I really couldnt afford it, so i am building my own. I designed it based on my grapple frame, and 3 others I saw online.
    So I went shopping and picked this up from a local machine shop, Snow's Machine & Welding.
    1- 3 1/2" x 3 1/2" x 3/8 square tubing, 6.5' long
    2- 4" x 2" x 3/8 tube, 48" long
    2- 2" x 2" x 5/16 square tubing
    Homemade Tree / Post Puller-smgedc0489-jpg
    I already had the 3/4 plate, so I cut out the 8" x 24" sides for the main frame using some 2" angle for a straight edge.
    Homemade Tree / Post Puller-smgedc0488-jpg
    Homemade Tree / Post Puller-smgedc0491-jpg
    I cut out the holes in the side plates for the crossmembers, then assembled to tack it together... except I somehow cut the cord on my grinder.
    Homemade Tree / Post Puller-smgedc0504-jpg
    Homemade Tree / Post Puller-smgedc0503-jpg
    Still have a lot more to do tomorrow after a short trip for some more oxygen, and another power cord for the grinder, lol.
    Bob...
    2005 New Holland TT55 Tractor, BushHog M300 Loader, Worksaver FLGR-4062S Grapple
    2003 John Deere G100 garden tractor
    2013 Simplicity Prestige garden tractor
  2. #2
    Super Star Member
    Join Date
    Jul 2011
    Posts
    14,436
    Yanceyville, North Carolina
    Kubota L4400
    Default Re: Homemade Tree / Post Puller
    Keep us informed of your progress and how effective it is after completion. Thanks for posting.
    The PUPIL who does not surpass his Master, fails his Master.
  3. #3
    Veteran Member chopped's Avatar
    Join Date
    Dec 2008
    Posts
    1,871
    New England yankeee
    Thanks for posting sounds like a good project to follow.. And a litle solder on the grinder wires and some tape and it should be good to go. Just shows your like us all..lol
  4. #4
    Veteran Member JohnDeere4300's Avatar
    Join Date
    Feb 2005
    Posts
    1,565
    John Deere 4300
    Lookin' forward to see this come together!!!
    Bill
    John 3:16
    01 JohnDeere4300 "Sync-Reverser", Vertical Exhaust, 2 JD Lawn Tractors, JD Walk Behind.
    430-FEL/ 47-Backhoe/ 5' Bush-Hog/ Single Bottom Plow/ 6' Disc/ Aerator Spreader/ HF Quick-Hitch!
    (Homemade Stuff) BH Thumb/ Log-Hitch/ 10' Boom-Pole/ 42'' Pallet Forks ''FEL Quick Attach & 3PH Quick-Hitch-Attach''/ Ballast Box 1381 lbs./ Aluminum Canopy/ Brush-Guard Mod/ 5x10 Firewood Trailer/ Lawn Striper.
  5. #5
    Join Date
    Mar 2008
    Posts
    599
    "I somehow cut the cord to my grinder "
    I can relate to this. Brand new Milwaukee grinder, piece of steel I cut hit the floor and severed the electrical cord to the grinder. Well I guess they are not new very long... and it could have been much worse. Now I am much more aware of my electrical connections.
  6. #6
    Silver Member ametcalf's Avatar
    Join Date
    Apr 2011
    Posts
    175
    Central KY
    Kubota BX23
    Thanks for posting. Anxious to watch your progress.
    ametcalf
    ametcalf
    All I need to be a better mechanic is a bigger hammer.
    2004 BX23, 72" Landpride finish mower, 48" Howse tiller, Home made brush forks, grapple, and plywood skidplate.
    Allis Chalmers 5040, 6 Bushhog, Boom pole, PHD, Box Grader, Rear Blade, 2 bottom plow
    2000 Crewcab Super Duty F250 Powerstroke Diesel 260k miles
  7. #7
    Join Date
    Mar 2012
    Posts
    48
    Mobile, Alabama
    Thanks everyone,
    Not much to update, but I did finish welding the main frame until I get the brackets on. I used what I could find, but I think it is a little too heavy duty, lol. The frame weighs in at 200 lbs! I'm not sure but I think total weight will be between 400-500lbs. The bushings I ordered for the hinged jaw has been delayed, so I will be using it for now without them with the grade 8 3/4 bolts for the hinge.
    In my little shop welding...
    Homemade Tree / Post Puller-smgedc0505-jpg
    Homemade Tree / Post Puller-smgedc0508-jpg
    I dropped off the prints for the jaw tooth plate yesterday, hopefully I will hear back from the machine shop today...
    Homemade Tree / Post Puller-jtblueprint-jpg
    Also, I will be adding 3 point attachments to the rear so it can be used with or without a loader. I will have to decide on cat 1 or cat 2 ?
    Will have more updates later today.
    Bob...
  8. #8
    Join Date
    Apr 2011
    Posts
    775
    Jackson, NY
    none
    Looks like a good start! I must have lead a sheltered life as I had to google what a tree puller looked like LOL
    Happy welding
  9. #9
    Super Star Member J_J's Avatar
    Join Date
    Sep 2003
    Posts
    18,924
    JACKSONVILLE, FL
    Power-Trac 1445, KUBOTA B-9200HST
    3/4 is not enough metal left in the bottom of the V cut.
    If you grab something at the end and apply force, you stand a chance of bending the unit.
    1 in teeth should be sufficient for grabbing and pulling, and that will give you more metal on the backside.
    Attached Thumbnails Attached Thumbnails Homemade Tree / Post Puller-treegrapple-jpg   Homemade Tree / Post Puller-puller6-gif   Homemade Tree / Post Puller-tree-post-puller-1-jpg
    J.J.
    When I works, I works hard. When I sits and thinks, I goes to sleep.
    Git er done.
  10. #10
    Join Date
    Mar 2012
    Posts
    48
    Mobile, Alabama
    Quote Originally Posted by J_J View Post
    Well now you tell me! Just kidding
    The machine shop has already started, so it is to late to change the edge from 3/4 to 1 inch. Since the teeth are cut from 3/4 plate and will be welded full length, would the thickness between the teeth (3/4" vs 1") make much difference in the strength of the teeth against bending? Just curious.
    Bob...
Similar Threads
  1. Homemade post hole digger
    By redneckexplorer in forum Build-It Yourself
    Last Post: 02-20-2013, 10:05 PM
  2. Homemade Post Driver
    By midsetberg in forum Build-It Yourself
    Last Post: 02-24-2012, 06:58 PM
  3. Homemade Post Driver/Pounder
    By HCb in forum Build-It Yourself
    Last Post: 03-08-2011, 10:52 AM
  4. Pipe post puller buddies
    By wroughtn_harv in forum Build-It Yourself
    Last Post: 08-03-2004, 11:06 AM
  5. Laying Out A Fence
    By MikePA in forum Rural Living
    Last Post: 06-25-2002, 05:51 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
